Missing cross-bar?!? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-22-2011, 05:38 PM
Tidan Tidan is offline
Mein Auto: T/A and a '97 328is
I think my car is missing the cross-bar behind the front cross member. The piece seen in this pic:
http://www.pelicanparts.com/BMW/tech...Flush/pic3.jpg
Mine is missing, but I can see where it used to be bolted up. I'm wondering if when the prior owner changed the clutch, he forgot to put it back on.
Does anyone know the proper name of this piece so I can order a new one or is there a better option?
Thanks.
Old 09-22-2011, 05:45 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
It's called the "crossover", and it's part number 7 in the diagram below:
Part number: 51718135880
It's cheap to buy new, bud I'd definitely just buy one from a scrap yard instead. You can probably get one for a few dollars. You'll also need the hardware, of course.
1998 BMW 328is
1966 Pontiac GTO
Old 09-22-2011, 06:21 PM
Thanks ZG!
I wonder if the crossover(or lack of) is contributing to my understeer problem?!?
Is there a hop up or anything that improves on the stock crossover?
Old 09-22-2011, 06:53 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, a true cross-brace is the way to go if you want to stiffen things up.
LINK
1998 BMW 328is
1966 Pontiac GTO
Old 09-22-2011, 07:25 PM
Do alot of people run the cross-brace? Does it make any difference in handling?
Not sure where to look for the standard brace/crossover. Not having much luck finding one.
Old 09-22-2011, 07:30 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
No, it won't make a difference, at least one you can feel, but it looks nice
Turbo Build Here
Old 09-22-2011, 07:33 PM
ZeGerman's Avatar
Warm Leatherette
Do you have a cross brace, Matt?
Of course, I've heard different things from different people regarding whether or not a difference can be felt with an x-brace installed. Same thing for strut tower braces in the E36.
1998 BMW 328is
1966 Pontiac GTO
Old 09-22-2011, 07:40 PM
Needs Boost
Mein Auto: Red Sled
No, but I know numerous people with them. I'd like to get one eventually, mainly to protect my turbo and lines from debris as it sits almost right above it.
I kind of rate these things at pretty much pointless/will never notice the difference.
Front strut brace
Rear strut brace
X Brace
Intake
Exhaust
Turbo Build Here
Old 09-22-2011, 07:41 PM
Needs Boost
Mein Auto: Red Sled
I don't really see how a thin metal brace can keep the whole underbody of a car from moving, ya know?
Turbo Build Here
Old 09-22-2011, 07:49 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I didn't notice any difference before and after installing the bar OP is referring to. I just installed it because it might take a little of the blow away from the oil pan on large speedbumps.
-CJ
Old 09-22-2011, 07:51 PM
ZeGerman's Avatar
Warm Leatherette
I dunno. I think bracing things up has the potential to make a good bit of difference. The unibody is essentially split down the middle by the trans tunnel, which I imagine greatly affects structural integrity. Seems like bracing those two sides together can make a difference.
An S54 Z3M roadster owner I know swears the front strut tower brace he installed made a huge difference.
1998 BMW 328is
1966 Pontiac GTO
Old 09-22-2011, 07:54 PM
Needs Boost
Mein Auto: Red Sled
I've heard of owners swearing by strut braces too, I normally just chuckle. However I do plan on getting a nicer one eventually.
Karl, you remember the guy who was going to start making titanium ones around here?
Turbo Build Here
Old 09-22-2011, 08:03 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, it's Rooster1986. Thread HERE. I'm assuming the plan fell through.
1998 BMW 328is
1966 Pontiac GTO
Old 09-22-2011, 08:58 PM
Well, at this point I'd be happy with having the plain old stock bar that I appear to be missing.
Old 09-22-2011, 09:39 PM
cj.surr's Avatar
some kid
I have one that I can ship to you if you really can't find one on craigslist...
-CJ
Old 09-22-2011, 11:23 PM
ZeGerman's Avatar
Warm Leatherette
No junkyards in your neck of the woods, Tidan?
1998 BMW 328is
1966 Pontiac GTO
Old 09-23-2011, 07:29 AM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
I've seen a braced up m3 (front strut brace, rear tower brace, and cross brace) where the owner put the oem jack in the front jack spot, and lifted the entire side of the car. The was hardly any flex in the thing at all.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 09-23-2011, 07:31 AM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
If you're in SoCal (I'm on my phone so I can't see your location), you can have mine. Off 97 328i. There's also 2 BMW junkyards located here if you want their info I can provide.
Old 09-23-2011, 08:23 AM
Wow, thank you for all the generous offers!
I'm in SoCal, outside of San Diego (in the mountains).
I'd like to get it taken care of while I have the car up on the jack stands - I'm doing the radiator, hoses, front sway bar, etc....
Old 09-23-2011, 09:08 AM
ZeGerman's Avatar
Warm Leatherette
On a side note, if you're replacing the radiator, double check ahead of time to see if you have the crimp on hose clamps for the small coolant overflow hose which runs along the top of the radiator and into the expansion tank. You'll want to replace that with a screw-type hose clamp (which BMW should have used in the first place...).
1998 BMW 328is
1966 Pontiac GTO
Old 09-23-2011, 09:34 AM
IgotBMW's Avatar
BE IRIE
I'm in Cerritos. 91/605 if you want to come by pick it up this weekend.
The two junkyards for future needs are
Bavarian Auto Recycling
3688 Omec Circle Rancho Cordova, CA 95742
From outside the US call: (916) 635-4269
Pride Auto Parts
12300 Branford
Sun valley ca
818-890-1600 Gary
Old 09-23-2011, 10:04 AM
Looks like its a couple hour drive each way for me.
Let me see if I can get the radiator, swaybar, etc... done by tomorrow.
Thanks!
Old 09-28-2011, 11:27 AM
Finally found a junk yard down in Chula Vista that had ONE E36 that still had the crossover bar. And, appearantly someone had allready removed the bell housing or clutch and tossed the bar aside so I didn't even have to crawl under in the oily dirt to get it!
Not sure what bolts were needed but I grabbed some off the chassis that fit the threads.
$4 entry fee
$10 for the bar
$1 tax
$20 in gas driving damn near to the international border
Total: $35.00
Though I did find some nice turns to drift around on the way to and from. So it wasn't a total wash!
Old 09-30-2011, 08:04 PM
jmo69 jmo69 is offline
Mein Auto: 98 328is 2003 325xi
I replaced my bar with an X-brace, the one pictured in post #4, tightened up my front end considerably along with my Sparco solid strut brace. Plus the extra protection under my oil pan.
98 328is Cosmos Schwarz Metallic 55w 6000K HID w/angel eyes smoked headlights, tails, corners, fogs and side markers Sparco strut brace, X-brace, Eibach Pro Kit springs, CAI, Prosport gauges, LEDs where ever they work, DDM pedals, 35% tint all round, HD lip, M3 style rear diffuser.
Old 09-30-2011, 11:08 PM
Nice! Did you notice any handling difference? Did it reduce any understeer?
chassis, cross-bar, crossbar, suspension
