7 Series - E23 / E32 (1977 - 1994)
I have a problem with Mine i have a 1993 740Il and the RPM's Don't work and the Speedometer has a lag to it, as well as the temperature needle of the engine it does not state weather it cold or hot when i start the car it just barely goes up but doesn't show anything else.. Any Help?
BMW E32 FAN 4 EVER 93 740iL FTW! |
The most likely cause is that the backup battery in the service indicator board has failed, The best solution is to buy a new si board from BMW, Trying to fit a non genuine battery is a waste of time as most times it will not work properly, You may be able to find re built boards elsewhere but again I have found that they are not very good, Peter
Thank you Appreciate it!
| Tags |
| odometer spedometer 1993 |
