Old 10-02-2011, 02:55 PM
redbull713's Avatar
redbull713 redbull713 is offline
Mein Auto: '97 540i/6
Good replacement fuel pump 540i E39?
My 540i has 140K miles and I want to change the fuel pump and fuel filter. What can I use?
Old 10-02-2011, 03:01 PM
Fragzem's Avatar
Fragzem Fragzem is offline
Ouch
Send a message via MSN to Fragzem Send a message via Skype™ to Fragzem
Mein Auto: 2000 540i/6, 1964 Wildcat
Def. not one of those
  • 2000 BMW 540i/6 (Anthrazit Metallic 397)
  • 1995 BMW 525iA (Schwarz II)
  • 2001 Buick Park Avenue Ultra (Bronzemist Metallic)
  • 1964 Buick Wildcat (Sunburst Yellow / Arctic White)
Fan Blades Can Explode.. Read My Thread
Old 10-02-2011, 09:50 PM
bluebee bluebee is online now
I'm going to give the same answer I gave in your other thread on this subject:
Is there a good diy for changing the fuel pump on a 540?
What you can use should be listed in one of these threads:
- Testing (1) and replacing the fuel pump (1) (2) (3) (4) (5) & your available fuelpump options (1) & a DIY for replacing the fuel filter (1) (2) (3) (4) (5) (6)
Old 10-03-2011, 01:19 PM
bricas45's Avatar
bricas45 bricas45 is offline
Mein Auto: '01 540i6, '94 325is
walbro F20000169 is an easy install and low cost and works great
2001 540i - Orient Blue
M5 bumpers, wheels, mirrors
S/C, water/air IC
A1 Headers, Random Technology Cats, Eissenmann Exhaust
3.15 diff, evosport power pullies
Koni Sports, Eibach Springs/Sway Bars
Old 10-03-2011, 02:56 PM
BTW, how does the OP know he needs a new fuel pump and filter?
I'm debugging lean codes and wondering myself:
- Just curious: Does the ORDER of pcodes listed in an OBDII scanner actually matter?
I'm tempted to rent the $150 Autozone fuel system tester (if it works for our vehicles) to see what that tells me:
- How do I test fuel pressure?
Did the OP do debugging or is it just a standard maintenance thing?
Old 10-04-2011, 07:11 AM
redbull713's Avatar
I'm debugging lean codes and wondering myself.
I'm tempted to rent the $150 Autozone tester (if it works for our vehicles) to see what that tells me.
Well, I suspect fuel delivery issues, plus the car is at a mileage where I am doing it as a matter of prevention. I would not want it to go out on me somewhere and leave me stranded. Bluebee, what is the tester that you are referring to from autozone.
Old 10-04-2011, 08:57 AM
bricas45's Avatar
I replaced mine as I am in the process of doing the supercharger install, but wow I didn't even realize mine was on the way out. Much smoother throttle response and the walbro is way quieter then mine. I was used to the old one and I guess I didn't know the noise I was hearing was a sign. MIne never gave out, but I would not like that to happen. It is a good feeling knowing that it is new and fixed a problem I didn't know I had. For about $100 it is a great preventative item
S/C, water/air IC
Old 10-04-2011, 09:04 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Stop by your local AutoZone, and ask to see it. The V8 has no Schrader valve on the rail. You need a kit with quick-change fittings to tee into the fuel line.
I also saw one at Harbor Freight that might work. IIRC, it was $180.
Old 10-04-2011, 09:22 AM
bricas45's Avatar
depends on the year. My 2001 has the Schrader valve on the rail.
S/C, water/air IC
Old 10-05-2011, 04:26 PM
redbull713's Avatar
Interesting, that is the first I have heard of a 540i with such valve. I know for sure that my 97 DOES NOT have one. I also need some recommendations for the best fuel filter.
Old 10-05-2011, 04:46 PM
bricas45's Avatar
Must have been added with the m62tu
S/C, water/air IC
Old 10-05-2011, 08:02 PM
guvy16 guvy16 is offline
Mein Auto: 2000 540
Ya must be the m62tu
I have a 2000 540 and it has the schrader valve
Old 10-05-2011, 08:30 PM
Here is a reference to the free Autozone fuel system testing kit:
- How do I test fuel pressure on 540i m62 V8?
Actron's Fuel Pump Diagnostic Kit, No.CP9220A, is designed to help detect whether a fuel pump is defective and to assist in diagnosing fuel-system related performance problems. This kit features a 40" gauge hose to easily reach any test point. The kit is compatible with vehicles that have a Schrader valve test port on the fuel rail; a detachable rubber hose connection at fuel rail, fuel line or fuel filter; are GM models with threaded connection at fuel filter or throttle body; or are Asian, European and domestic makes with a "banjo bolt" connection.
And, here's a picture of the M54 engine fuel supply Schrader valve:
