E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
I recently bought used bmw 545i and went for servicing they say i have both front and rear break pads to be replaced along with rotor costing me 876 and 785 dollars respectively and i will be charged for labor extra i just don't understand are they so much expensive and why to replace rotor???????
please respond anybody |
Welcome to BMW ownership my friend. They don't cut your rotors only replace at the dealership and they only use new parts. That may be why. It's not a hard job (to me), but boy do they get paid. After coughing up about $600 on the front axle of my X5 i said never again will i pay for a brake job and haven't since. See if you can find an independent BMW mechanic around you area, it may cost you half that amount.
Check your mirrors as often as it takes for you to know where everyone is around you! Last edited by boramkiv; 10-04-2011 at 01:58 PM. |
2012, 650i Coupe, Carbon Black, Black Nappa leather, M Sport , CWP,DAP, IAS, 20" Wheels, BMWCCA Member since 07/2008 |
I got rotors and pads for close to 500 for the all. Search the forums and you will find many treads on rotors and low dust pads an the Indy's which will do it for 200-250
12 X5 50i Sport 11 M3 DCT 11 X5 50i (lemon) -- SOLD -- 08 550i M-Sport 04 BMW 545I sport 07 BMW X5 4.8I sport 02 BMW X5 4.4i sport 01 BMW 540I M/sport 00 SL500 97 SL500 |
Are replacing the rotors really important??
![]() ![]() I know the I might lose some braking power but I drive like a Grandma so I can careless. I never replaces rotors on my old car, I had close to 200k on them - no problems. |
Go with the latest pads craze, cool carbon, supposely BMW put these on 2010 and newer cars to reduce dust to zero but maintain that "german car" braking feel. I've tried many typical pads, you either have no dust but less braking or great braking with dirty wheels in a week.
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
Buy rotors and pads on-line (RMeuropean dot com, AutohausAZ dot com are good) and replace them yourself or find an independent mechanic.
Take a calipers and measure the thickness of rotors. If the current thickness of the rotors is below the MINIMUM required, then replace the rotors. Otherwise, it's not necessary. |
holy crap
Buy after market rotors,sensors and oem brakes online do some research im not going to just give you the wesite to get them becouse i work hard to find them
And I thought that car forums were for SHARING information? I'm glad you're the minority and most members are glad to help. |
Thank you for all the comments and help
alien2002 remember u not helping doesn't make much of difference its public platform for helping each other thanks to all |
2008 BMW 528xi space gray, Premium, Cold Weather Package. |
I own a '08 535i with sports package plus stage2 intake. Pushing around 330HP 345torque. When I had to do my front brake for the first time they wanted $900.00 at the dealer. I went to http://brakeperformance.com ordered me front and rear sensors, high performance semi-metallic (last better than non metallic when you drive like I do) pads and dimpled and slotted rotors (not drilled, they can crack and warp, dimpled have a life time warranty). Had my local BMW shop install them and I spent about $1100.00 total. That's for front and rear high performance (a very sexy) brake rotors, pads and sensors installed for $200.00 more than OEM for just the front. Just make sure the shop you chose has the computer to reset your maintenance info.
Which intake is this?
Interestingly, a brake pad,with an EE cold/hot friction grade is only marginally better than steel on steel!
For details, see: What friction grade is recommended for BMW brake pads (e.g., EE, FF, EF) Last edited by bluebee; 10-08-2011 at 11:12 PM. |
BTW, here is just my complete cost analysis for replacing my four BMW E39 wheel rotors and pads and sensors from this thread:
- One user's example of a complete brake job with all torque figures, specs, measurements, fluids, decisions, tools, tricks, mistakes, suppliers, costs, etc., that it entails (1) Your numbers should be similar to mine for your E60: Last edited by bluebee; 10-08-2011 at 11:17 PM. |
Check out www.bavauto.com
Sent from my DROID BIONIC |
In context of determining whether to buy extended maintenance coverage ($2295) for my 2006 550i I asked my BMW dealer for cost to replace brake pads and compared to recommended independent. Given what seems to be high dealer maintenance costs (see below) it could make sense to buy extended maintenance contract (since I have not done my own car maintenance for many years).
First, I was surprised that BMW dealer will only replace rotors and pads (for all my other cars I have only had to replace pads). Dealer "explained" to get excellent stopping BMW uses "soft" rotors and pads so rotors also wear down quickly. Anyhow, cost was $1930 front and $1875 rear to have work done at dealer. Dealer also gave cost for oil change at $215; spark plugs $720; cabin air filter $192; engine air filter $162. Independent charge for rotors and pads replacement quote was $860 for fronts and "about the same" for rears. He also said sometimes they are able to just replace pads at cost of $330 front and $330 rear (my notes not really clear so it could have been $330 total to replace both front and rear pads only). |
It's amazing how much money u save when u do it your self lol
Thousand here, thousand there...
As long as people continue to pay ridiculous amount of money for simple routine stuff, I can't blame dealer. |
i also needed rear brakes on my 535i and the dealer quoted me $900. its a good think i can do it myself. i got the OE pads and sensor online for about 125. i tried to cut the rotors but unfortunately they couldn't be saved so i ordered new zimmerman rotors for 85/EA.
lot better than 900
Ebay sell oem pads for cheap and just get centric slotted rotors
#25
In Bluebee posting - Wow! I am amazed at the differences in cost if you shop around. Is it only the cost of the part and does not include the installation? My 525i light just turned on "Check Brake Lining", so this information is helpfull when I meet my local Independent BMW Repair shops.
