Old 06-07-2011, 07:03 PM
croket croket is offline
Send a message via Yahoo to croket
Mein Auto: 2006 530i
Deteriorated Window Trim DIY
Hello all, Iím sure a lot of us are having this window molding cracking / drying issue so I decided to post a DIY on replacing the rear window trim. I hope you guys find this useful.
Here's what you'll need:
1) Go to your local dealer and pick up the molding. I paid (including taxes) $44.17 for mine. I couldnít get it any less than that anywhere online.
2) I used an orange peeling tool, it worked great because its plastic and has a pointed tip. I also used a paint can opener for the stubborn areas where I needed some rigidity; Of course you can use whatever tool you have that will not scratch the paint.
3)I also used some off the shelf rubber /plastic care product I had in the garage as a lubricant. You can use soapy water or anything else that will act as a lubricant when installing the new trim piece.
4) Have some window cleaner and some sort of gunk remover, I used goo gone.
Here we go!
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
I started by flaking off as much dry rot as I could to make the removal of the metal part a bit easier
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Once I had most of the loose stuff out of the way, I pried out the metal part with my fingers as much as I could to separate it from the glass
Photobucket
Photobucket
Once I got it separated I lifted up on the corner and pulled upwards on the rest of it
Photobucket
Photobucket
Now that I have removed all 3 sides, I was left with rubber smudges and lots of clean up. I used the goo gone to clean the smudges and window cleaner the completely clean the trim channel.
Photobucket
Photobucket
Photobucket
Photobucket
Time to install the new molding, I used the Teflon rubber /trim care spray and strayed the bottom side of the trim so as to act as a lubricant. I started from the top right hand corner.
Photobucket
Photobucket
While pressing down on the trim I slide my fingers across as the metal trim channel works its way into the window edge.
Photobucket
Photobucket
And finally its completed and look beautiful again
Photobucket
Photobucket
Photobucket
Photobucket
Thanks for looking everyone, by the way I have another DIY on installing and AUX adapter, Here's the link AUX DIY
Old 06-07-2011, 08:34 PM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Thanks bro!
Old 06-07-2011, 11:17 PM
etnav382 etnav382 is offline
Mein Auto: 06 550i
When I did this I started the removal at the bottom, where it connects with the trunk rubber and just pulled it up. A lot faster that way, but thanks for the write up.
Old 06-08-2011, 09:28 AM
Yea I tried that too, but it would not budge from the bottom and I didn't want to force i. I was trying to be as gentle as posible for fear of shattering that glass being that it was my first time doing it. By the way if anyone is wondering its a 2006. Thanks for the reply.
Old 06-08-2011, 12:16 PM
txag_530i's Avatar
txag_530i txag_530i is offline
Excellent write up and photos. Thanks for taking the time to do this.
Old 06-08-2011, 12:26 PM
hairball's Avatar
hairball hairball is offline
Mein Auto: 2014 X3 35x
+1
It's easier to start from the bottom and work your way up and around the glass. I did not need any tools to remove mine.
Old 06-08-2011, 02:30 PM
agghopp agghopp is offline
Mein Auto: '05 530i, Sport, Prem, CW
That's an '06 5 Series and the trim was that bad? I see you're from FLA so I guess that makes sense. Do you park outdoors? I have an '05 in Ohio, garaged and it doesn't look anything like that. Thanks for the info!
Old 06-08-2011, 03:39 PM
I realize the hot sun bakes the hell out of cars but damn it ate up this molding! Aside from fading, Ive never seen this happen with any other vehicles Ive owned. I read in another post that BMW makes these trim pieces out of biodegradable material, hence the reason they deteriorate so quickly, I don't know how true that is but I'm starting to believe it.
Thanks for the positive comments guys!
Old 06-09-2011, 07:48 PM
bimmerstien bimmerstien is offline
Mein Auto: 528xi, w/Spt, Nav, PP, CW
Thanks for taking the time to share this with us. I learned a great deal.
Old 06-09-2011, 09:06 PM
tnycman tnycman is offline
Mein Auto: 07 550i sport
Mine is just as bad.. will order the parts didn't know it was DIY job... The stealer told me the glass needed to be replaced..
Old 06-09-2011, 11:09 PM
TruBlue550i TruBlue550i is offline
Mein Auto: 06 550I: 92VW VR6 Corrado
Thumbs up
I'm definetly in neeed of this fix. My trim looks bad. What's the part number?
Old 06-10-2011, 04:59 AM
This is the part number i got for realoem.com 51317057415 for my 07 550i... It should be pretty much the same for all E60's.. Double check it though before you buy it..
Good luck!
Old 06-10-2011, 12:18 PM
carlos916's Avatar
carlos916 carlos916 is offline
Semper Fi!!
Send a message via AIM to carlos916 Send a message via Yahoo to carlos916
Mein Auto: 1983 E21 / 2006 M5
NICE DIY!!!! this needs to be a sticky!!! also share this on 5 seires fourms!! nice!
Semper Bimmer! oRah
BMWCCA Sacramento Vally Chapter
Old 06-10-2011, 06:26 PM
skippy_ps skippy_ps is offline
Mein Auto: '05 530i
Great diy, thanks for posting! Need to do the same to my '05 - looks about the same as yours.
Old 06-13-2011, 01:11 AM
chauzers chauzers is offline
Mein Auto: 2008 550i
Thanks for the info...
Old 06-28-2011, 04:17 PM
m1a1x1s1 m1a1x1s1 is offline
Mein Auto: 2007 525i
Great write up. I'm going to have to do this on my 5 because it's looking nasty back there!
Old 08-09-2011, 11:46 PM
okii okii is offline
Mein Auto: 530i
Excellent write up. Went to realoem website and there are two rear window molding options. One molding is for safety vehicle,comfort laminated or protective glazing rear glass. How do know what type of rear glass your vehicle has?
Also, is there a similar write up for replacing the front windshield Cover molding along the top?
Old 10-07-2011, 03:08 AM
pdubq pdubq is offline
Mein Auto: 2008 535i Sport
Excellent writeup Croket!!! I'll be doing this ASAP... I'm so sick of my crumbly trim... that Goo Gone is incredible stuff.
Old 10-07-2011, 10:41 AM
Bremen Ben's Avatar
Bremen Ben Bremen Ben is offline
Mein Auto: 2008 535i sport
This might be an dumb question: does it require any type of glue to hold the trim in place?
Old 10-07-2011, 04:26 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
no.
Old 10-07-2011, 07:21 PM
BTW, this is a loooooong standing problem of BMW using substandard components for the window trim!
From the bestlinks ...
- WINDSHIELD MOLDING CRUMBLES: heat labile rubber windshield & back window molding that crumbles in three years due to poor choice of recycled materials (1) (2)
Old 10-08-2011, 01:11 PM
bbayless bbayless is offline
Mein Auto: 2004 530I
Thumbs up
Crocket this was a great display of detail, I did my front and rear in about 35 mins for both, great info, I appreciate it
Old 10-20-2011, 12:09 PM
bobmw525i bobmw525i is offline
Mein Auto: 525i
gREAT!!!! thanks for the upload of those awesome detailed pictures! i'm gonna do mine too now!
Old 11-02-2011, 05:59 PM
Mein Auto: 525i
just finished mine and i love it!
Old 11-03-2011, 02:08 AM
Castrostrong Castrostrong is offline
Mein Auto: 2005 BMW 530i
Thank you for your time!!
