Old 10-08-2011, 09:18 AM
ensoniqts12 ensoniqts12 is offline
Mein Auto: 525i 2003 Auto
Question SES light came on again after new MAF sonsor
Had 6 codes (system too lean, misfire detected etc..)
(Car was stalling when it was cold outside or when starting a car in the morning, I could also hear that engine wasn't running smoothly, even though I almost don't know anything about cars.)
Bought a cheap MAF sensor on ebay from "only_maf" seller or store.
SES light disappeared the next day day.
about 2-3 weeks passed by, SES light came on again.
(don't really remember the codes they (at the auto zone store) told me, but the codes were all related to ignition, and all started with a "P", the guy told me it might be oxygen sensors, bad spark plug or cables. (Spark plugs are about 1 year old). (I don't remember if the codes are the same that were before but this time I got 7 codes instead of six)
Can this be the MAF sensor going bad again?
Old 10-08-2011, 09:33 AM
Fudman's Avatar
Fudman Fudman is online now
Your first mistake was to assume the MAF was the source of your problem. Why did you replace the MAF (that has nothing to do with your ignition system) when Autozone did not identify as a possible source of your problem? Randomly replacing parts is not a sound nor inexpensive methodology for repairing your car.
Your second mistake was to use a "cheap MAF sensor from eBay". You get what you pay for. The use of cheap aftermarket parts for critical engine or suspension functions is not recommended as their life expectancy can be short relative to OEM parts. Do a search of this forum and you will see that many others have had poor experiences with low cost replacement parts.
First thing you should do is rerun the codes. Then search this forum for possible reasons why you have these codes. You can also post back your codes and symptoms and I will guarantee that BlueBee will post up the links to threads that mirror your symptoms with fixes. This forum is an excellent collection of people who have had similar problems and been able to diagnose and fix their problems. You need to use it properly to maximize effectiveness. Please post back with your codes and we can help.
Old 10-08-2011, 09:45 AM
Yes, now I learned my lesson about buying cheap parts.
I searched the forums here before, with the codes I had than, (don't remember them anymore and lost the paper where i wrote them) and, changing the MAF sensor was one of the recommendations.
But after I put the new cheap MAF sensor, the second day SES light disappeared and stayed off for about 2-3 weeks. That is what makes me think that the MAF sensor was the problem.
Anyways, I'll I get the codes and post them here.
Old 10-08-2011, 11:38 AM
Fudman's Avatar
Investing in an inexpensive code reader is a good investment. Yes you can get them read for free but that isn't worth the hassle. BlueBee found an OBDII for $30. Makes troubleshooting much easier and works on most cars.
Old 10-08-2011, 03:33 PM
Manybrews Manybrews is offline
Mein Auto: Car
Lean codes are almost ALWAYS due to a lean condition. Meaning a vacuum leak, ruptured crankcase valve, low fuel pressure, etc.
Old 10-08-2011, 11:03 PM
Actually, I paid $30 but then they started selling them for $22 ... I felt gypped!
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
See this thread for parts that should be OEM:
- What E39 parts are most often recommended to only buy OEM (1)
Follow Fudman's advice.
See this debugging of lean codes today, for example:
- Fuel system lean - multiple codes - Help please
Old 10-09-2011, 03:37 AM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
Check your DISA valve. It's an easy thing to do.
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 10-09-2011, 10:00 AM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
I dont know if the I6's have these but did you happen to forget the rubber boot ring from MAF to air boot or the ring from boot to TB?
codes, maf, misfire, obd, ses
