#51
Why? You don't have one?
Yep, same one I have installed now. |
#52
I don't have it and don't feel like shoveling over $200 for theirs.
2001 540i - Orient Blue M5 bumpers, wheels, mirrors S/C, water/air IC A1 Headers, Random Technology Cats, Eissenmann Exhaust 3.15 diff, evosport power pullies Koni Sports, Eibach Springs/Sway Bars |
#53
Yes, if you don't have it, it's not worth paying $200 for... I could take some pics of mine over the weekend for your reference if you are interested.
#54
Would be great man it seem like a rip off just to bypass
#55
Here's what it looks like. Also some pictures of what I did to it over the weekend.
#56
I also built a bracket for the catch can, still needs to be painted. Here's a mockup.
#57
Wow I didn't realize their plate was aluminum like that! I was thinking it was just a modified OEM plate. What are all the new ports you made? For sensors? Also what is that electric sensor in the center? A MAP sensor? Also the catch can looks great. Do you still need it or just adding it now as belt and suspenders?
#58
I drove about 60 miles to the office and back on Friday with the catch can and when I removed it later that evening, the inlet hose had was just a bit oily, while the outlet was completely dry. It seems that at least at this point oil out of the crank case is not a major issue, but the catch can will help almost completely eliminate any oily fumes from the intake, which I think is a good thing, so I decided to put it in. EDIT: just remembered... when I removed the aluminum PCV pipe under the manifold, there was some oil in it. So the catch can will certainly help. Last edited by Flug540; 10-03-2011 at 09:50 AM. |
#59
That is an intersting set up dinan has on that bracket and your additions look good. I may just drill out the oil seperator connection and put a tube in sort of like dinan has just to extent hose to back should be really easy. and seal off the CCV of course.
#60
![]() For my setup I made a 180 degree fitting for the oil separator outlet so that I won't have to go around the engine to the oil separator on the front. Instead the hose will come out at the front of the engine and hopefully the 180 fitting will trap some oil as well. |
#61
[QUOTE=540alex;6355718]That will work too, you can just cut off that plastic pipe that extends from the stock plate. Another issue that you might have with the stock plate is securing the stock vacuum plumbing to the plate so it doesn't pop under boost
![]() QUOTE] good point not sure how I will secure it yet. Could probably replace with brass fittings glued in place.
#62
Cut and plugged the secondary air intake tube to remove the valve which is in the way of the charger. There are 2 pieces I plugged and put back into the exhaust took a photo of the one. Car actually runs better as there was apparently a leak at the valve I didn't know about! So to all out there check that your valves are tight. Mine must have shaken loose. No leaks now and runs great with more room.
#63
Your car doesn't have it let me take some photos of the valve.
#65
Removed valve...only on m62tu
All it does it pump clean air into exhaust on a cold start up for emissions. It was in the way and noisy so it is now gone! Also that T-bar on the PCV I have is 5/8 on 2 ports and 3/8 on the other.
2001 540i - Orient Blue M5 bumpers, wheels, mirrors S/C, water/air IC A1 Headers, Random Technology Cats, Eissenmann Exhaust 3.15 diff, evosport power pullies Koni Sports, Eibach Springs/Sway Bars Last edited by bricas45; 10-10-2011 at 04:40 PM. |
#66
Thanks, that explains it.
#67
will be modding my hose not the plate on mine. This should be easier. I will do this and attach pcv to my intake as a test before full install. I will plug the pipe with something like JB weld. And put a 'T' connector between the oil seperator and the end plate.
#68
Doesn't Dinan and the other mfgs have this all figured out and and tested out already?
Afterall, there are hundreds of compressor systems out there functioning normally. Or do I have this wrong?
Frank 540/6 Dirrezas (4) @ 275/35-18, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy |
#69
Yes just don't feel like dumping $200 towards the Dinan plate.
#70
I think if I didn't have the plate, I would make one. It's just a piece of aluminum, a few holes and hose connectors, pretty straight forward. The only complication there is the welded PCV pipe, but I ended up not using it after all. Last edited by Flug540; 10-12-2011 at 08:35 AM. |
#71
I believe the engine rotates clockwise, when generating torque, as seen from the driver's position.
#72
There is actually some clearance between the hose and the timing cover, but it's a good point. I'll double check how it actually behaves when the engine is revved.
#73
#74
When the engine mounts fail the engine' rock is great enough to pull the upper radiator hose into the fan blade. I had it happen to me. Of course if you keep new motor mounts on the car at all times it will not rock as severly. But on the otherhand with at least 1/3 more torque the engine will rock over farther than normal and will wreck the engine mounts sooner than later. Just something to keep in mind.
#75
No, I completely removed the aluminum pipe connecting the two. The oil separator outlet is 16mm in diameter. The hose I used is 5/8".
