Old 09-29-2011, 06:44 AM
italiano italiano is offline
Mein Auto: 2007 BMW 745li
I got the same problem just p0491
Old 09-30-2011, 02:55 PM
mrringtone mrringtone is offline
Mein Auto: 2007 Alpina B7
I met with a tech in Houston an hr ago. He suggested taking the heads off and using Sea Foam. Carbon Build up is a common issue with several BMW V8's and some of the straight 6's as well. He quoted me for $200.00. I did sea foam about 8months ago, but I just put it in the gas tank I never thought about taking the head off and pouring it in there. He also informed me he has performed this job on two 7-series BMW's and was successful at it.
Old 09-30-2011, 03:00 PM
adboles adboles is offline
Mein Auto: 745i
hello mrringtone,
Was that a misprint,$200.00 (two hundred dollars) to take the heads off a 745?
Old 09-30-2011, 07:21 PM
bump x1000
Old 10-03-2011, 07:43 AM
Mein Auto: 745i
More llike times ten italiano. But somettimes if feels like BMW bumps it times 1,000.
Old 10-03-2011, 08:58 AM
@Adboles - No misprint. The correct amount is $200.00 I am quoted this price because he has done this job twice. He will have my car for two days. I will keep everyone posted. I am scheduling my appointment for tuesday or wednesday of this week.
Old 10-03-2011, 09:10 AM
Mein Auto: 745i
mrringtone, please let us know if this corrects the secondary air flow too low problem that causes the codes 0491 and 0492 to show up. I would like to talk to him and ask him if he can share how he does this for $200.00 with my mechanic here in Tennessee!! Thank you, I'm looking forward to hearing from you.
AD
Old 10-09-2011, 03:34 PM
i thought my code cleared itself my p0491 has returned after a few weeks of being dormant. I knew it was too good to be true. mrringtone waiting on your insight and good news!
Old 10-09-2011, 07:26 PM
DRMCEO DRMCEO is offline
Mein Auto: 2004 745LI
I remember years ago a procedure I used on a 540i I had that I read about for what I recall was carbon build up. It involves the vacuum hose from the pressure regulator, but looking on realoem, our pressure regulator is part of our fuel filter. Is that correct or is there a seperate fuel pressure regulator elsewhere?
Old 10-10-2011, 08:06 AM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
Same problems here and await good news about the Seafoam idea.....
Old 10-10-2011, 03:01 PM
I may have a possible solution if I can get confirmation about our fuel pressure regulator.
Old 10-11-2011, 06:48 AM
roadfrog's Avatar
Lets keep the hope alive!
Old 10-11-2011, 07:56 AM
After driving my car for a few days. My check engine light did come back on. Since the job is covered under the shops 12month 12,000 miles warranty I will dropping my car off today for a second treatment. The good news is while driving I got 25.5 MPG's which has never happened since owning this car. I believe a small amount was remove but not enough, the tech is determined to have this resolved. I will keep you posted in the next 48-72 hours.
Old 10-11-2011, 09:25 AM
ahhh ohhhhhhhhh...........................
Old 10-11-2011, 05:25 PM
roadfrog's Avatar
I spoke to my Indy about the Seafoam thing. He said they tried this remedy several times without success. He said the carbon is so stubborn and hard that only honing out will clean properly.
Old 10-11-2011, 06:01 PM
HerbP HerbP is offline
25.5 mpg just buy adding Seafoam, that crazy! How is that possible?
Old 10-11-2011, 06:38 PM
txsailor txsailor is offline
Mein Auto: 2002 745i
mrringtone - I live in Houston as well. Can you tell me the name of your mechanic so I can give him a try? Thanks
Old 10-11-2011, 06:42 PM
I don't event know and I was driving 65MPH I am chugging my plugs soon so it may increase.
Old 10-11-2011, 06:44 PM
TXSailor the info is below. My car is there right now so give Joey Noll a call and tell him Ivan referred you and let him know my black 745i is being serviced right now. There work is warranty by 12month 12,000 miles. The other mechanic is Dennie Noll
Nolls Auto Repair
Master ASE Certified
17215 Houston Drive
Cypress, Texas 77433
Phone: 281-758-4212
Fax: 281-758-4213
Old 10-11-2011, 06:46 PM
I regularly get 29 MPG on road trips and I drive 70+. Your amazement at 25 MPG now has me questioning the accuracy of my trip computer.
Old 10-11-2011, 06:50 PM
I have the car apart right now and am trying to get the injector rail off the car so I can pull the manifold off the car. Once I finish this I'll post my results if changing the valve underneath stops p0491. Just need help gettin the injector rail
Off it's stuck.
Old 10-11-2011, 07:26 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
I have also got 29 mpg on interstate driving once doing 70 the whole way so 25 shouldnt be hard to beleive.
Old 10-12-2011, 06:53 AM
roadfrog's Avatar
Ditto on the 29 mpg. I get that all the time cruising 65-70 mph.
Old 10-12-2011, 10:33 AM
Check out this TIS at http://tis.spaghetticoder.org/ or go onto ebay and purchase one for 9.99 or 19.99 make sure you have windows if you have mac use bootcamp because VM Fusion Ware will not will work.
Off it's stuck.
Old 10-12-2011, 03:29 PM
manny187 manny187 is offline
Mein Auto: 2002 bmw 745i
I had the 2 codes p0491 and po492 and my car failed aircare (emissions testing), this is very common problem in the 7 series car. To fix this problems is very expensive...and even after you fix the problems the codes will pop up again. My dealer told me there is no point in fixing these problems as they do not have any affect on the performance of the car. So disabled the secondary air system for me at a cost of 500 dollars, been 2 weeks now and the codes have not come back on and the car passed aircare.
