X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
Tailgate rattle and noise
Hi All,
This week, after the 5th attempt and 2 dealerships, I got my X5 back with the tailgate noise/rattle *fixed*. The SA/Tech acknowledged the noise and said they adjusted the tailgate and there is no noise. However, I have to close the lower portion on the trunk so hard, you won't believe it. If I shut the lower part close, the upper part won't close using the "Red auto close button" until I force the lower part with a lot of force. The noise is somewhat gone (not entirely) but now the lower part is pressed against the rubber and it squeaks. When I took the delivery and was about to drive off, there was half an inch gap in the lower and upper parts. The SA then took it away and came back after 10 mins - the gap was gone this time - and told me to use more force then usual if I want to use the Auto close button. Is it normal for the tailgate to be adjusted in way you actually have to use more force than usual? I feel like I'd break it in a few months if I use it everyday. The SA told me this is the only way the noise will go away. Any thoughts? Last edited by smuggymba; 10-12-2011 at 01:32 PM. |
I'm in Houston too... Which dealer did you go to for service. Frankly, some of them are totally crap.
BTW, I don't think this is normal... I would take it back and refuse to take the car back until they fix it. |
Dealer tech competence varies significantly, try another dealer, try and use one that handles a lot of cars. If one more visit fails, take it up directly with BMWUSA. You may want to take a video clip of you closing the tailgate, and if you have a camcorder with an external microphone, you might even be able to capture the sounds you mention. Visuals help catch people's attention quickly! Not suggesting you broadcast the video, but you can certainly let the BMW rep know, you will, if this is not fixed to the way it is supposed to be! Chances are, one or more of the tailgate panels is outside the design tolerance limit and that is causing this issue. Replacing these panels should solve this problem. This assumes the dealer tech knew what he was doing and have adjusted it to the max possible! |
Make sure you tell them what is happening and what the other dealers have done (or not) to fix it. I would also request a face-to-face with the Service Manager, so they know you mean business. |
I just emailed BMWNA and will wait for their response till tomorrow. No doubt momentum is worst - there was a half an inch gap between the upper and lower part when the SA said - have a nice day and went back in.
Try Advantage Midtown while you are waiting for a response from BMWNA. |
tailgate noise over bumps
I have the same problem ....I bought a 2009 X5 and can't get rid of the noise in the cargo area. I took it to the dealer 3 times already they can't fix it....... the latch on the lower tailgate is lose it moves back and forth...the funny thing is, I checked on other X5s are the same ...it looks are missing 2 bolts ....go figure? why is that? someone posted a picture on here.....what the hell?
Sorry to say mine too. Truth is the electrical tape fix worked much better than dealer attempt. I put one full turn on right lower latch and one and a half on the center. Nothing on left. Not 100% perfect but much better. Try experimenting on your own and see how you like it.
This kind of thing blows my mind. These are $60-$80K vehicles and we're talking about a hinged door assembly. In 2013, it really shouldn't be a major engineering feat to build a rear hatch that fits properly, doesn't squeak, and opens/closes with ease.
My 2012 X5 50i doesn't have hatch rattles (thankfully), but the auto-open/close function works only about 90% of the time, just enough for the problem to never manifest itself in front of a service technician. I picked up a 2013 Toyota Land Cruiser for my wife a few months ago, and the difference in overall build quality is like night and day. There are definitely some things about the BMW that are head and shoulders better than the LC, but it ain't the body/paint/interior fit. If BMW could pair up the iDrive/interior aesthetics, engine, and suspension with the Toyota build quality, they'd have one hell of a vehicle. The hatch on the Land Cruiser sounds like you're closing a vault when you shut it. At this price point, that's the only way it should be. |
After fruitless trips to the dealer about creaking, I took matters into my own hands and adjusted the tailgate myself. It was misaligned from the factory. Details and pictures here:
http://www.xoutpost.com/bmw-sav-foru...r-hatch-4.html Also using electrical tape for the creak during weight shift. |
