Old 10-01-2011, 04:16 PM
tjh54 tjh54 is offline
Mein Auto: bmw 2001 z3
2001 z3 camshaft position sensor
My 2001 z3 3.0i is showing the check engine light. I read it and it gave me the code for intake camshaft position sensor. I changed it and the same code has returned. Does anyone have any ideas?
Old 10-01-2011, 07:50 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
DId you clear the code?
Old 10-02-2011, 07:39 AM
I cleared the code and drove it after about 10 miles the check engine came back on with the same code.
Old 10-02-2011, 08:49 AM
IgotBMW's Avatar
BE IRIE
Then you should recheck the connection and that you've installed it correctly.
Old 10-02-2011, 12:12 PM
I double checked and reinstalled the intake camshaft sensor. I cleared the code and the same code returned. If anyone has an idea what to do next it would be greatly appreciated.
Old 10-02-2011, 04:29 PM
BTW it has 73k miles
Old 10-03-2011, 02:44 PM
Cobrafixer Cobrafixer is offline
Mein Auto: 2001 Z3 3.0L Roaster
Mine did that on the exhaust side I think (was the one in front, I didnt have to screw with the VANOS).
It had 70k miles on it!
Old 10-03-2011, 03:33 PM
I glad you solved problem but I still have mine.
Old 10-07-2011, 03:59 AM
Heloman54 Heloman54 is offline
Copterfixer
Mein Auto: 2001 Z3
Thumbs up Z3 Camshaft sensor.
If you went thru all that and still have the same problem them I would think you have a bad sersor. Did you buy the original BMW sensor or aftermarket? I prefer original parts when possible, but when it come to electrical components I buy original parts only. You dont have to buy OE parts from the stealerships either. I like BavarianAutosport.com. I never had an issue with any of their parts and yes, they sell OE parts.
Old 10-08-2011, 03:16 AM
stryper1970 stryper1970 is offline
Mein Auto: 97 z3
How did you clear the code?
Sent from my DROID X2 using Bimmer
Old 10-14-2011, 02:34 PM
I rebuilt the dual vanos and now it's fine. I also have better response and gas mileage.
