E34 (1989 - 1995)
Old 10-15-2011, 02:19 PM
Cindysandoval3's Avatar
Cindysandoval3 Cindysandoval3 is offline
Mein Auto: 1992 bmw 525i
Can someone tell me
What goes connected to this part. A screw or cap, hose?
Cindy
ID:	297252   Click image for larger version
Old 10-15-2011, 02:20 PM
Cindy
Old 10-15-2011, 02:40 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
From the diagram on the other thread, it's the coolant supply line for throttle body heat (anti-ice). A hose gets connected to it.
Good food, good people, good times.
Old 10-15-2011, 02:59 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Originally Posted by Cindysandoval3 View Post
Cindy
It looks # 9 small hose block to throttle body.
Old 10-15-2011, 04:27 PM
Ok,thanks
Cindy
Old 10-15-2011, 06:56 PM
What's #9 called
Cindy
Old 10-15-2011, 11:08 PM
I found the hose!! Now if I can screw it back in, it would be awesome lol
Cindy
Old 10-16-2011, 06:12 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i would inspect the end that came off for cracks and deterioration, as well as proper fit. iirc, this hose should be clamped on with a hose clamp.
that means that either:
a) the hose clamp failed
b) the hose burst/split
c) the hose was replaced with an incorrect size
the hose should go on rather snugly to begin with, and any corrosion or buildup on the nipple should be removed to ensure a proper fit. (emery cloth will do, or scotchbrite it there's not a lot of scale on the metal)
once this is put back together, the cooling system needs to be bled. it's not too difficult, but sometimes people have a tough time (i think they rush through it ).
when bled and running, you can verify the system is operating properly.
good luck with the repair.
df
Old 10-16-2011, 08:48 AM
Lol if only I wouldve read this yesterday. Hose blew off again. I placed it back on and burned my wrist forgetting it was hot lol. And it is rusty
Cindy
Old 10-16-2011, 12:31 PM
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette, 530i
Cindy
I'm sure you know by now that it needs to be fastened with a hose clamp. From the looks of this, I'd check your entire cooling system especially for low levels of anit-freeze. Don't forget to bleed the system for trapped air.
If that line was disconnected there is a good possibility that some other lines or connections are failing.
Good Luck!
Old 10-16-2011, 06:16 PM
Thanks, I gave up. Lol.
Cindy
