E34 (1989 - 1995)
Old 10-17-2011, 06:19 PM
south26 south26 is offline
Mein Auto: 535i 1989
535i dies, then is fine, what the H!!!
Hi, I just bought a 535i 1989 and on the way home it suddenly lost all power and just idled. I turned the car and the turned it back on and it ran fine. The engine light had turned on and then it turned off when I turned the car on.
It did it again today. I would push the gas pedal down and it ran horrible. So I turned it off and it ran fine.
Any ideas?
Andy
Old 10-17-2011, 07:22 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Hey Andy. With that scenario, it could be so many things. Guessing and buying random parts could get extremely expensive.
The first thing you need to do is get the codes read (I don't think you can do the stomp test on your car). Let us know what codes are stored and we can help you go from there.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-17-2011, 07:59 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Sounds like a electrical connection loose or failing.First I would check connection of battery. the ECU connections . Then to the supply cables under the main relay area. A bad coil may be it too.
Old 10-17-2011, 10:07 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Check your grounds, check your MAF, check your plugs, check your air filter, check your fuel filter and check your fuel pressure/fuel pump sending volume.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 10-18-2011, 12:33 AM
Banned
Mein Auto: car
The throttle position sensor. I'll bet on it. And really, don't drive this car. The engine could cut on you at any time.
One way you could fix this (if it is the tps) is to remove the tps switch, use contact cleaner on both the tps and the switch, then apply some dielectric grease to the switch and plug it right back. Then take the car out for a drive where you won't run into problems or cause problems if the engine suddenly cuts out on you.
Before doing all this, see if you can recreate the problem with the car being stationary. Maybe if it idles for 10 minutes it will cut off by itself. Or maybe it needs to be revved for 5 minutes consistently, etc. You get the picture.
Please let us know how it goes.
