7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
As we all know, on our E65/E66's the steering angle sensor will occasionally freak out and throw an error, with the supporting evidence being a non-self-canceling turn signal. After a little while (typically car stop/start) it will go back to acting normal.
Well, mine finally freaked out again this morning and I was able to pull the error. You'll notice that it only happened once, and that it was just for a split second. I'm not soliciting advice on this, just providing a little information back to the community. Attached are some screen shots from pulling the error using INPA.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
could you maybe explain what some of the info means on those screens for the folks like me who have no clue what that is?
Sorry...
I got the same problem today, but the good thing is, turn off the engine went for a pick up, came back and restart, it's now gone just like how u described it. thanks!
05 745I 58K 88 735-gone 288K 80 320 gone 300K 76 280Z 2+2 RIP 325K |
In INPA by default it just shows the mileage (in KM) when it happened. I haven't checked using any of the other tools yet (DIS, etc.).
Right on.
Does anyone know how to fix the problem? It goes away after a restart but annoying.
Lol yes you need to replace the sensor. I had the same issue taken care of under warranty. Mine would only trip after turning the wheels close to or full lock, such as backing out of my driveway.
2007 Kawasaki Ninja ZX-14 2006 BMW 750i 1972 Dodge Charger 1968 Dodge Charger 1967 Austin Healey Sprite Last edited by MOPAULY; 10-20-2011 at 12:35 PM. |
Lmao at gman750 reply! Bro I've known keif for a long time now and when he starts talking bmw he goes into a zone and pretty much no one really knows what he is saying!
same problem how to replace it ?
The third screenshot says on the last line that this would not cause a warning light to come on. Every time I have had this happen (maybe 3 times in 3 years) I have received a warning light saying to drive moderately. Why does INPA say it will not show a warning light?
Sent from my ADR6425LVW using Bimmer
catalytic converter
my catalytic converter is stopped up on my bmw 745 li. any suggestions
Have you checked the ZGM (gateway module)
![]() As far as the Cat goes..... can they be cleaned? They sure are expensive to buy.....
What is that?
What is what?
Do u have any idea how much without the warranty it costs
Sent from my SAMSUNG-SGH-I727 using Bimmer App |
i have this problem as well, and i cannot reactive my DTC
