Old 02-20-2010, 11:14 PM
humbertob humbertob is offline
Send a message via MSN to humbertob
Mein Auto: BMW 335i N55
Question Windshield washer fluid leaking ! Help !
Well, I just purchased a 2005 X3 with 60k on the Odo, I'm very happy with my purchase and have checked everything on the car, but have noted that the windshield washer fluid is leaking where the electronic pump meets the groomet on the reservoir, my question is: What can I do ? Can I just order the reservoir's groomet to fix the leak, if so ? where ? of course online, I prefer to avoid the dealer on this little thing. Thanks in advance for your help !
Old 02-21-2010, 10:50 AM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Google is your friend:
http://www.realoem.com/bmw/
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
Old 02-21-2010, 11:13 AM
Wink Thanks !
Thanks Evlengr, just ordered the parts !!!! Blessings !
Old 02-26-2010, 12:32 PM
pezjunki pezjunki is offline
Mein Auto: 2005 X3 3.0
cool saved a couple of bucks, thanks
BTW......
04 WASH PUMP 67128362154 $42.75
05 Strainer f wash pump 61667006063 $2.62
Old 02-26-2010, 12:47 PM
Also, I noted that mine was leaking from the pump itself, not the gromet. So, i ordered both.
Old 02-26-2010, 05:06 PM
Wink Great Forum
This is a great forum. I was afraid to purchase my X3 without a warranty, but now I'm feeling more confident to work on my X3 with all the help I have found here ! Thanks a lot ! GOD Bless you all !
2013 BMW 335i Sport
2011 BMW 335i Performance Power Kit (Son's)
2009 BMW X3 (Wife's)
Old 02-27-2010, 11:07 PM
oh, and ebay FTW! $15!!
Old 05-13-2011, 08:26 AM
ryanoscerous ryanoscerous is offline
Mein Auto: 2006 X3
Wow, our 06 X3 had all the washer fluid leak out. All the grommets look good, pumps are well seated, no cracks that i can see anywhere. Removed all , cleaned, reassembled. It looks like fluid is leaking from a small rectangular opening in one of the pumps, kneaded some epoxy patch putty, sealed it up. Reassembled, now its leaking from the rectangular opening in the other pump. What is this opening, and can i seal them up?
Old 05-15-2011, 03:59 PM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
I just replaced the pump and grommet in my 03 M3. Same problem, but I also had a leak where the hard plastic fitting in between the hose and pump mounts to the pump. What a dumb design--I threw that part out, cut off a fresh bit of hose and put the hose directly to the pump, then sealed with the blue RTV.
Old 10-07-2011, 11:56 AM
sj00884 sj00884 is offline
Mein Auto: BMW X3
Hey Pez where's you buy the parts? Also, there are 2 pumps I am assuming one is for the headlights the other for windshield? I am having trouble with the one located on the driver side. Thanks
Never mind and never mind. Wrong schematic (one down was it!) and didn't realize Origoem doesn't sell parts. One awesome utility though thanks!
Ordered 2 pumps/gromets delivered for $67 from Bimmer Specialists which was about $30 less than my usual fav Bavarian Autosports
Old 10-07-2011, 02:47 PM
tafeej tafeej is offline
Mein Auto: BMW X3 2007
I have a 2007 x3. I have washer fluid leaking into the interior of the front and back passenger sides under the carpet. Has anyone else had this problem?
Old 10-07-2011, 11:26 PM
PPXYZ PPXYZ is offline
Mein Auto: BMW X3 2009 AT
http://www.bimmerfest.com/forums/arc.../t-174868.html
Other water issues come from clogged roof drains and the catch basin in the engine compartment IIRC.
Old 10-24-2011, 04:20 PM
James Hamilton James Hamilton is offline
Mein Auto: 2005 X3 3.0i
Is there a trick to removing the coils in order to change the spark plugs?
Old 10-24-2011, 09:05 PM
Mein Auto: 2004 X3 2.5i
Change of topic from washer pumps, but, ...
I think the caps on the coils require a bit of force to open them upwards,
to allow the connector to be removed.
May need careful use of a flat bladed screwdriver to pry the caps upward.
After that it should be simple pulling that is needed.
Old 10-25-2011, 08:51 PM
Thanks, I was afraid to put a lot of pressure on them. My luck hasn't been running to good lately and I didn't want to have to buy one. I didn't have to use the screw driver, wiggle and pull did the trick. Unpluging the wires left a nice finger size hole to apply additional pull force. Everything went off without a hitch. Thanks again
Old 01-22-2012, 03:53 AM
PCronn PCronn is offline
Mein Auto: X3
Floor Mats Soaking,
I just had this today and the reason is a design fault.
BMW in there wisdom have put a joint between the front and the rear, ie. washer bottle and rear washer jet under the carpet.
Right then your going to have remove drivers seat and lift the carpets, as the "washer pipe joint" is between the hand brake and the drivers seat under centre console under the carpet.
I would think it's the pressure that blows the joint, either the cold weather or dirty / blocked rear washer jet.
Here's the question: Who in there wisdom would put a joint under the carpet inside the car. BMW.....
Old 02-15-2012, 02:33 PM
flynhawaiian flynhawaiian is offline
Mein Auto: BMW X3 3.0
I just had a washer fluid leaking problem. I had a problem not only with the pump, but the line was leaking as well. I would advice changing the front line if you have the time as well. The strainers are $5.00 each and I would also replace them...
2004 BMW X3 3.0 and a 2006 Mini S to SMOKE Porsche 911s
Tiptronic Auto Trans
Premium Pkg, Sport Pkg, Navigation, Premium Sound (DSP), Privacy Glass, Homelink Mirror, Grom Audio USB, Euro Style Convex Side Mirrors, Hardwired V1 with Stealth One, Homelink Mirror, CG Locks!
Old 10-07-2012, 11:13 PM
jvest2000 jvest2000 is offline
Mein Auto: 2006 X3
Just FYI on my experience with this. My wife's 2006 X3 washer fluid leaked out within a week of being filled and i noticed the leaking coming from the pump closest to the engine which feeds the windshield sprayers. I ordered a new OEM pump and grommet/strainer and replaced easily in 15 minutes, parts were about $35. Here is a little guide i put together on the process, hope it helps someone as this problem seem pretty prevalent in these cars. In fact I just looked at my aunt's 2008 X3 and saw minor leaking from one of the pumps in that as well. Pretty unbelievable that these pumps are such crap but it is what it is and at least the fix is easy.
DIY Instructions For Replacing BMW X3 Washer Pumps
Good Luck, hope it helps save you some $$$.
Old 12-02-2012, 08:34 PM
Yomama Yomama is offline
Mein Auto: 2006 X3 3.0I
Any difference between front and rear
Are the two wiper pumps on the 2006 X3 the same and interchangeable. I ordered a replacement wiper pump today and just noticed the description says for 'front windshield'. The one that is leaking is the one closest to the engine. Which I have assumed is for the rear as it appears the leaking starts when I spray the back.
Thanks in advance
Old 12-03-2012, 06:34 AM
John320 John320 is offline
Mein Auto: 2017 X1
Yes, same part # for front or back. The front headlight washer pump ( that is placed higher up and to the side of the reservoir tank ) is different & not interchangeable
Old 12-03-2012, 07:21 AM
Perfect thank you. I should note that I tried some of the DIY fixes noted on this forum (ie RTV, plumber putty, replace grommet). None of them worked. Ordered the pump from Ebay, $30.40 free shipping. Will let you know how it goes.
Old 12-03-2012, 01:06 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Sorry to say you should have done a search--- OEM pump with grommet from Amazon $10.95 shipped.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 12-04-2012, 06:12 PM
Oh no. I did search on Amazon. There was one for $7.xx but Amazon said it would not fit a 2006 X3. How about a link to the product Vern.
cheers
vern
Old 12-04-2012, 08:15 PM
x3brian x3brian is offline
Mein Auto: X3
I got an aftermarket Uro one for $4 from ecstuning.com. It works great. Considering the frequency of failure...about 1 every 50k miles is my going rate...$4 plus shipping works for me.
Old 12-05-2012, 07:45 AM
I also did a search and there not up there any more. I did mine back in September They did have others for as little as $7.95. If you order just make sure the electrical connection is the same as your replacing, the connections come in "round or flat".
cheers
vern
