E36 (1991 - 1999)
Old 10-21-2011, 01:14 PM
Gk baby Gk baby is offline
Mein Auto: 323 se i
Lower Suspension noob
Hi everybody a virgin post for me, only owned my E36 for a few weeks, but have started a few minor works...Long story short I recently replaced the front shocks, and am now considering lowering. Maybe I should have thought about it before buying standard shocks?? I dunno! Anyway, would I be able to use the standard height shocks with lowering springs? Thanks
Old 10-21-2011, 01:18 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
No, if you are going to use lowering springs, you must use struts & shocks designed to be used with lowering springs.
1998 BMW 328is
1966 Pontiac GTO
Old 10-21-2011, 02:24 PM
Mein Auto: 323 se i
thanks ze german...could you recommend any parts/manufacturers? I appreciate the swift reply!
Old 10-21-2011, 02:28 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Bilstein shocks H&R springs
GGC BMW CCA #443004
Join the BMW CCA!
Old 10-21-2011, 02:44 PM
ZeGerman's Avatar
Warm Leatherette
Bilstein Sport shocks/struts and H&R Sport springs.
Koni Yellows witih H&R Sports would be a nice setup, too.
It's also highly recommended that you replace the rear shocks if you replaced the front struts. Having fresh dampers up front and old ones out back will cause goofy handling.
1998 BMW 328is
1966 Pontiac GTO
Old 10-21-2011, 03:26 PM
Mein Auto: 323 se i
thanks both. Good to see a resounding answer! love the community on here, sure you'll be helping me much in the future!
Old 10-21-2011, 03:48 PM
ZeGerman's Avatar
Warm Leatherette
Also, if you upgrade to stiffer stocks & springs, be sure to reinforce your front & rear strut/shock towers. It costs about $12 to do both fronts, and $30 to do the rears. Cheap insurance.
1998 BMW 328is
1966 Pontiac GTO
Old 10-22-2011, 02:12 AM
Mein Auto: 323 se i
thanks again ze german! replacing tie rods today..hopefully get to the suspension next week end!
Old 10-22-2011, 08:52 AM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Some have found the Bilstein Sports with the H&R springs a pretty harsh ride. The Koni yellows have a bit more lowering spring friendly damping, and the Koni STR.T model (have them on my E36) will give you a noticeable handling improvement too with a bit less stiffness.
Rokkor coilovers are also an option if you'd like to have adjustable height at an inexpensive price. $319 for a kit for all four corners. I know there have been some forum members here that are running Rokkors and they seem to be happy with them. You might need a spacer set on the front so think about that in your cost analysis.
If you do a search on Rokkor in this forum you'll get lots of info.
Welcome to the 'Fest!
Old 10-22-2011, 09:49 AM
Mein Auto: 323 se i
Thanks DC..for the welcome and the info! Will check it out, do like the sound of all corners for $319!
Old 10-24-2011, 06:44 PM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
For what it is worth, I have H&R Sport springs and Bilstein Sports all around, and although the ride is certainly harsher, it results in great handling and response. Although, as Ze mentioned earlier, it is crucial that you reinforce everything, as I have been the victim of cracked shock towers and a solid, oe quality fix will run around $1000 (ask me how I know.)
It is all good that you are replacing suspension, but I would tackle all your bushings front and rear soon after, since degraded bushings in the subframes, control arms, etc. etc. are a complete killjoy (see what I did there?) for the overall ride and handling experience.
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 10-25-2011, 02:18 AM
Mein Auto: 323 se i
thanks Killjoy...A lot of work/money then eh? I guess I'll have a re think, prob just get some bigger rims now..stilll on 15's at the mo!
Old 10-25-2011, 09:37 AM
petriej's Avatar
Hmmm, I have this, too. Where do I get such reinforcements?
GGC BMW CCA #443004
Join the BMW CCA!
Old 10-25-2011, 11:57 AM
Mein Auto: 323 se i
agreed, I changed almost everything at the front now, feels like a different ride! wish I had just 'done the rear' (no ****) while I was there!
Old 10-25-2011, 11:59 AM
ZeGerman's Avatar
Warm Leatherette
You can get them from many of the major vendors. Turner, BimmerWorld, ECS, etc.
1998 BMW 328is
1966 Pontiac GTO
Old 01-19-2016, 05:20 PM
BxBill71 BxBill71 is offline
Mein Auto: 325 cic
I have a 4.8 x5 hate the space. In the wheel well can I just put lowering spring and keep the. Air suspension
Old 01-19-2016, 07:41 PM
ZeGerman's Avatar
Warm Leatherette
If you don't like how high your SUV rides, why don't you just buy a car? There is no point to ruining the only attribute that makes an SUV worthwhile.
1998 BMW 328is
1966 Pontiac GTO
lowering springs, suspension
