Old 10-16-2011, 09:18 AM
Nando779's Avatar
Nando779 Nando779 is offline
Send a message via AIM to Nando779 Send a message via Yahoo to Nando779
Mein Auto: 2003 325Ci, Orient Blue
Unhappy Car not starting, ignition switch, starter?
So here's the deal. My car will not start. I turn the key and nothing. No clicking, no attempt at turning, nada. The gauge cluster lights up as usual. So after doing some searching and testing, I have eliminated the following possibilities:
Battery
Cables
Fuses
Fuel pump
Key
This is not the first time this has happened. It has happened in the past but after a few attempts of turing the key, I was able to get it started, luckily.
From what I have read, I have heard it can be my ignition switch or....the dreaded starter which I heard is a pain to get to. I am wondering what kind of tests I can do to make sure it is the starter or something else. Not sure where to go from here
I have an auto with 106000 on the clock.
My bimmer and the son of Sam himself.
http://www.facebook.com/Nando.Alvarez
Old 10-16-2011, 11:32 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Remove battery, take to auto zone or similar and have it tested. It is probably dead enough to not have the amps to crank but still light the cluster. Much more common than starter.
Old 10-16-2011, 12:02 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Once the battery passes muster, get under the car and measure voltages at the starter solenoid terminals. Should have battery voltage at the main connection at all times, and battery voltage at the control connection when someone holds the key at Start position (3).
  • If no voltage at main lead, check the pyrofuse on the battery positive terminal.
  • If no voltage at the control lead, then the immobilizer on the EWS module may be acting up or said module is not "reading" the chip on the key. The antenna on the ignition switch?
  • If voltage everywere, you are screwed my friend, and your starter ist kaput.
  • Can also try jumpering between the main and control terminals while someone is holding the key in Start position; that will confirm if the solenoid is bad.
2006 325Ci
Old 10-16-2011, 12:12 PM
ziggyp ziggyp is offline
www.aa-canvas-upholstery.
Mein Auto: 2003 BMW 325CI
Exclamation No Click, No Crank...No Start!
I'm experiencing the same problem. After battery was tested and checked good, (I was able to jump start the vehicle) I took my vehicle to the robber's who had previously repaired it. Unfortunately and un-be-knownst to me this automotive service had changed mechanics since my last repair.
Upon arrival at the shop my vehicle presented with "no-start, no-crank and service engine soon illuminated" I advised the shop that I wanted them to remove and replace the starter motor (I knew this was beyond my capability) I suspected was bad after my research. I also provided a new exhaust camshaft position sensor. I had previously removed and replaced the intake camshaft position sensor (which cleared a previous service engine soon lite), but couldn't locate/change the rear one.
First and formost my advise is "DO NOT JUMP START" your battery. The mechanic advised me that I was wrong to jump start my vehicle at the terminals located in the engine compartment. I was advised that BMW's should be jump started at the vehicles battery terminals (which was contradictory to my research). I've come to believe that jump starting your vehicle period will likely damage its' electronics.
With that said, after receiving the vehicle the mechanic laid hands (and test equipment) on the vehicle "scanned BCM" and tested key pass system. Determined that "key code was not recognized and re-programed keys". Also "scanned ECM and found fault code for camshaft sensor fault (advised me this fault was cleared after R&R'ing rear camshaft sensor). Final results..., starter and relay need to be replaced. Whoohooo! They R&R'd the starter assembly (and relay) and the exhaust camshaft position sensor. But this gets better.
They "rechecked computor after replacement, several codes were stored in memory, several areas need to be diagnosed; Fault code P0143--tank leak detected/major leak (I asked if they had checked to gas cap...NO), 238--misfire cylinder #1 "feels like it has a transmission problem//cannot accelerate, 243--misfire cylinder #6, D7--tank level sensor, BE--internal error light, SE38--rotation rate sensor circuit, 5DF4--system voltage>9 volts" AND "heater and air conditioning system not working and not illuminating (Allegedly before starter replacement)"
I initially decided to leave the vehicle for more test to begin after the weekend. However, during my trying out the vehicles starting after the repairs I noted that the although the vehicle started right up...the starter sounded as if it was going to damage the flywheel. While pondering that loud "clang" when the starter engaged the flywheel (and with the shops service manager at my side) I decided to check the fuses (why pay a mechanic $150/HR. to check fuses) and lo' and behold the fuse for the heater (#28) was mysteriously missing (misplaced). When I placed it into its' proper recepticle the air conditioning and heater panel illuminated. YES...It was a miracle? NO!
I had advised the mechanic to switch the positions of the #1 & 6 ignition coils on Monday to observe if the faults followed the switch or remained with the cylinders #1 & 6. I now remembered him telling me "I have diagnostic procedures to follow. I can do what you want , but how will doing that help keep your wife comfortable while driving, especially with winter approaching? This was my first AAAHHAAAA moment! And I decided to take the vehicle home and inspect all of the fuses.
As I'm driving home I noticed the little red gear with the exclamation mark inside it was illuminated in the instrument cluster. The transmission was operating in the "limp mode". The mechanic had observed an obvious problem with the transmission during a test drive after replacing the starter and camshaft sensor...BUT DID NOT KNOW (OR DID NOT ADMIT) THAT THE TRANSMISSION MODULE HAD CAUSED THE TRANSMISSION TO GO INTO A DEFAULT MODE AFTER REGISTERING A FAULT.
So I'm torn. I want to have this auto service figure out what is still wrong with the new starter, causing it to sound as if it's destroying the flywheel. But How can I be sure these people are competent OR scrupulous?
Anyone know of a competent AND scrupulous BMW "robber"/ mechanic in or around Fort Washington, MD? Thanx for the referral to admin@aa-canvas-upholstery.com.
George "ziggy" Pierce
Old 10-16-2011, 01:06 PM
Nando779's Avatar
Did that, battery is good as it should be since it is only 3 months old.
Looks like I will have my work cut out.
Wow, sorry to hear all that trouble you went through. I just want to be sure it is in fact my starter before I take on that task. I would rather replace the ignition switch, I already have removed all the coverings and can see it.
Old 10-16-2011, 01:29 PM
mr_clueless's Avatar
mr_clueless mr_clueless is offline
Mein Auto: 2015 328i M-Sport
Have you tried yelp.com?
2015 328i / M Sport / Alpine White / Coral Red / 4 DR / 6 MT / Rear Camera + PDC / Xenons / DHP / 51K+ Miles / Bought 10-30-2014
Old 10-16-2011, 02:29 PM
Nando779's Avatar
Anyone have a good diagram of the location of the starter? I looked it up on realoem.com and it only shows the starter unit itself, not the location.
Old 10-16-2011, 02:35 PM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
There was actually a diy posted here a few weeks ago, will have to look for it when I get home
Sent from my ADR6400L using Bimmer
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 10-17-2011, 12:07 AM
craaazycarrot craaazycarrot is offline
Mein Auto: 2000 323i
Try unplugging your MAF. If its your starter then your engine won't crank.
Old 10-17-2011, 10:54 AM
Nando779's Avatar
Found a pretty good DIY: http://forum.e46fanatics.com/showthr...eplace+starter
Looks like I will be talking this during the week/weekend once I order the starter.
Old 10-25-2011, 02:51 PM
Nando779's Avatar
Got the starter swapped out and it was a PITA. There is basically no room for play. Made a cool tool that helps this job go a lot smoother if anyone wants to borrow it.
Old 04-12-2015, 11:44 PM
primfactor23 primfactor23 is offline
Mein Auto: 750 li
try the ivm its usually the problem plus its cheap
