Old 10-23-2011, 08:31 PM
euclidX3 euclidX3 is offline
Mein Auto: X3 2011 (F25) XDrive 28i
Exclamation "P" switch on shifter
Hello,
I am a proud owner of a new X3 F25 28i.
A novelty for me: I notice that you can engage the car in "Parking" by pressing the "P" switch on top of the shifter.
I did so while the car was rolling slowly in my garage and it immediately put the car to an abrupt stop, as if the gearbox was suddenly locked. This stop is totally different from a braking action as it is quite brutal; Basically, the gears are suddenly locked.
My question is this: what would happen if the P switch is accidentally depressed while the car is cruising, say while driving at 55mph on the freeway? Would this immediately lock the gearbox and have catastrophic mechanical consequences or does the gearbox software deactivate the P switch when the car goes above a set speed (say 1mph for example)?
Obviously, this is something I would not dare trying on my new car...
Old 10-23-2011, 09:05 PM
michael T michael T is offline
Mein Auto: 2011 X3 35i
Hi, I am glad the "P" button is no where near the shifter. At least you have to lift up on the button to engage the park.
Old 10-23-2011, 10:12 PM
Sorry, I don't undertsand your comment. Do we drive the same car?
The "P" button is ON TOP of the shifter.. And you dont need to lift it. You just press it with your thumb while holding the shifter... See attached file.
Name:	P1030183 (Small).JPG
Old 10-24-2011, 07:58 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
One is the electric parking brake and the other is the mechanical "Park" position for an automatic transmission perhaps?
Old 10-24-2011, 09:35 AM
caesarp caesarp is offline
Mein Auto: 328i xdrive
Originally Posted by euclidX3 View Post
Hello,
I beleive the park button does not work if you are going above a certain speed.
Old 10-24-2011, 09:41 AM
jgroarke jgroarke is offline
Mein Auto: BMW X3 3.0d Msport
Eeek
OK challenge time, I knew *exactly* what you meant when you posed the question, I've been thinking this for some time.
I just screwed up my eyes and tried at 30mph, nothing :-)
Then I tried 25mph, nothing ...
Any other takes for 20mph? Lower? :-)
I know it was highly unlikely it would kick in at that point, but nervous nonetheless ...
J
Old 10-24-2011, 10:39 AM
Thumbs up
Hello jgroarke,
I thought the BMW engineers would have thought of such a possibility and would have deactivated the P switch above a certain speed... but to actually test it on one's own car...!
Hats off for you!!
You solved a mystery!
All my best!
Old 10-24-2011, 07:09 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
[P]ark above the shift should not engage unless brake is depressed and speed is 0. At least I hope that's how it's designed.
Auto Hold is for stop and go situation and that would come to abrupt stop if you are going slowly.
So did you press the ((P)) button?
What happens if ((P))arking brake button is on, and you hit the accelerator? Does the car engine rev but don't move, or moving and dragging the brake, or Parking brake will be disabled?
Old 10-24-2011, 08:01 PM
Hi Pyao88
The Auto Hold feature is a no brainer. If the Parking brake is on and you hit the accelerator, the brake disengage and the car moves. Once you come to a complete stop to speed 0 (like in traffic or at a red light for instance), the brake automatically engages again, until you hit the accelerator pedal again. Personally I do not really like this feature, so I always disengage the Auto-Hold feature.
However, my original question is about the [P]ark switch above shifter, not Hold brake (see attached picture below).
And to answer your first sentence, I do confirm that [P]ark above shifter DOES engage when the vehicule is rolling and brake pedal is NOT depressed. So the car stops in a very abrupt way...That is why I started this thread originally.
Old 10-24-2011, 08:37 PM
Under 5mph it stops.
http://www.bimmerfest.com/forums/sho...d.php?t=198235
http://blogs.insideline.com/roadtest...idding-me.html
Can you confirm if opening door while under 5mph would also come to an abrupt stop?
Old 10-26-2011, 10:47 AM
Hello pyao88,
Thx for sharing the links. Interesting really!
I tried opening the driver door while the car was rolling. It indeed slammed the car to [P]... Wonder what would happen if any of the other doors were opened under these conditions... Will test it and will update.
Cheers!
Old 03-05-2016, 10:43 PM
/dev/null /dev/null is offline
Mein Auto: 2014 X3 F25 xDrive 28i
What happens if you open the door driving at 75 mph?!
Old 03-06-2016, 02:20 AM
jeff_K jeff_K is offline
Mein Auto: BMW X3 28i
Sorry...I don't know. But I will never ever do that except in an emergency - a big risk indeed
Old 03-06-2016, 08:28 AM
Jamolay Jamolay is online now
Mein Auto: 2014 328xd Wagon
I wouldn't imagine that it is very easy to open the door at that speed. At least going in the forward direction. Not that I have tried, and I won't.
Old 03-18-2016, 09:04 PM
littleredcar littleredcar is offline
Mein Auto: X3 and 335is
I did open the door while rolling slowly. I wanted to look at my wheel while I rolled so I could move it a bit and expose a different part of the wheel for inspection. It jammed into park when I opened the door and came to an abrupt stop. I won't ever do that again - it concerned me that it could cause damage. On my 335is, there's a place in the dash you can enter your key fob and then, you can roll the car without it going into auto park mode. But our X3 doesn't have that key fob slot.
Old 03-21-2016, 02:33 PM
danend danend is offline
Mein Auto: 2012 X5 35d
I have opened and closed my door at higher speed multiple times never thinking it would put my X3 in park... Occasionally I think the door isn't closed all the way (kids or leaving passenger) and I'll open and close the door while driving down the road.
Now I'm afraid to do it at lower speed...
Old 03-21-2016, 03:01 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
If you have your seat belt on, the car will not go into park if you open the door.
Old 03-22-2016, 08:40 AM
Another great reason to wear seat belts!
f25 x3, parking switch
