Old 09-23-2011, 09:11 PM
pburnett pburnett is offline
Mein Auto: 2006 BMW X3, Lexus IS300
Originally Posted by timfitz63 View Post
Well done, "pburnett!" It's looking more and more like this quick-fix is a winner!
Thanks guys, glad it seems to be helping! Not bad for a 25 year old, huh?
Old 09-24-2011, 09:51 AM
dpsaunders dpsaunders is offline
Mein Auto: 2005 X3
is there any pictures of the actuator removal / location?
I have 71k on my wife's X3 and got all three of the codes. The shop wants $1350 for the repair. I am quasi-competent in repairs but any visuals would be appreciated.
Pisses me off the shop is also charging almost $250 more for the actual part if I go with replacement than what I can pick up online.
appreciate any insight.
thanks
Old 09-26-2011, 11:27 AM
dannyy06 dannyy06 is offline
Mein Auto: Bmw X3
thanks
Its only 4 screws to remove it from the transfer case and another 4 screws to remove the
motor. The pictures are in the beginning of this thread they can help lots
Old 10-18-2011, 10:53 AM
jengstro jengstro is offline
Mein Auto: E60
I started to have the 4x4,dsc,etc. errors on the E60 530x. That terrible clicking noise after you shutdown the engine...
Is it sounding like this (video).
http://www.kolumbus.fi/~w451491/e60_aani.mp4
This sound comes sometimes, not too often.
If this noise is from transfer box, what the actuator/transfer box is doing after you shut down the engine?
Anyhow, I'm definitely going to open actuator next coming days and see what it has eaten...
I could use 2k€uros for something else than new transfer box.
(thanks to pburnett for a excellent post)
Old 10-18-2011, 06:23 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
I like the pix and all, but looks like the gear stuck in place and the worm just sat there and ate through it. So not the gearing that caused the issue, but that it seized at some point and the cylindrical gear just chewed it up.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 10-23-2011, 10:47 AM
Mein Auto: E60
Here is E60 actuator picture, different kind of than beginning of the this thread. Anyway, E60 / 2006 / 530x actuator has metal sprockets. Badly worn (220 000km driven)
http://www.kolumbus.fi/~w451491/e60/neliveto3.jpg
Old 10-23-2011, 11:34 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '95 M3, '89 MkI
In your case seems to be the actual "worm" the one with damage and not the "gear". It would be worth to research if the part numbers are the same.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers Chapter
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black.
Old 10-23-2011, 04:40 PM
F10ster F10ster is offline
Mein Auto: 528
Buy your parts online and have the dealer install them. My dealer will install BMW or other quality parts, they did my AC compressor.
Old 10-23-2011, 04:56 PM
sammyers sammyers is offline
Mein Auto: X3
I just did this DIY repair, and so far all is working just fine. I put it through its paces, breaking tires loose on dry pavement, therefore loosing traction control just slightly.
I will post again once it's gone through bad weather. Up here in the Pacific Northwest we get ice and snow. We'll see how she does.
I would like to advise on the fix though. Once you have the actuator/servomotor out, you will need to rotate the main gear, full 180 degrees. I thoroughly inspected mine, and the effected area was 1/2 of the gear circumference. Not only could I see the wear, but the other 1/2 of the gear had "fresh" green grease on it. Also, you need to pay very close attention to the gear position when reinstalling the worm gear motor. When you reinstall it, it will cause the main gear to move. Just be very careful.
I'll report back when I have updated news.
Old 10-25-2011, 07:42 PM
dgreen78 dgreen78 is offline
Mein Auto: 04' BMW X5, 00 323i
Anymore updates on how this fix is working? I am having the same issues and will be tackling it this weekend. 06 with 72K on it. Making the clicking on shut off and dash lights on under hard acceleration. Do you need to reset anything in the ECU/TCU after doing this?
Also, if anyone has a used actuator lying around please PM me, I would be interested in making a stronger gear for these (I am a machinist)
Old 10-25-2011, 09:38 PM
Mein Auto: X3
No, you don't have to reset anything with this apparent fix.
Also, all is still working fine with this.
Old 10-26-2011, 12:13 AM
Mein Auto: E60
Actuator has been changed, 4x4 works ok now.
That "resistor" / wear indicator. I looked that from old one... I cannot understand how that "inductor?" can measure wear from the plain cover of the motor (on the inside theres no any holes on metal, what could measure rotation or anything?) . Looks a bit like BS to me.
Ok, if it measures the wear from main socket some funny way, but then what is that two wire additional small socket.
Old 10-26-2011, 08:19 AM
Mein Auto: 2005 X3
I changed out mine a couple of weeks ago and wasn't that tough at all. Couple of bolts were hard to get to but other than that, all is well. No slip on acceleration and no warning lights. Good luck.
Old 10-26-2011, 10:48 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
I am not sure exactly how it is set up, but it measures wear on the fluid through resistance change. As fluid wears and pucks up contaminants, you can use this to measure wear.
I don't know if it flows through sensor or if there is another pickup somewhere in the case.
Madurodave
My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi
Retired: 1998 BMW Z3
Member of BMWCCA!
Old 10-26-2011, 08:48 PM
stedistang stedistang is offline
Mein Auto: 2007 X3
Had the dreaded 3 lights on the dash. Just did the fix. Only time will tell if it works! BTW, I don't know who said it was an easy DIY but I had a hell of a time. Once the actuator is off, it's true it is an easy fix but getting those damn 4 bolts off to take it down took me forever. Hint to help you guys out, use a 1/4 inch wratchet, a long extension, a universal joint and a slim and short 8 mm socket. Had to take 2 bolts off the heat shield and bend it out of the way. For those who don't have access to a lift, my sympathies!
I can't believe this little actuator costs over 800 bucks! What a rip off. Someone definitely has to start refurbishing these units cause from what I could tell, THEY ARE ALL DOOMED TO FAIL, it's only a matter of time and milage!
FYI, I have a 2007 3.0si.
And BTW, I live in Canada, where it snows like hell in winter, so I'll keep you guys posted on the effectiveness of this fix in extreme driving conditions, but I'll have to wait for it to snow, which should be in about one month.
Have fun.
Old 10-27-2011, 05:37 AM
madurodave's Avatar
BMW Enthusiast!
And BTW, I live in quebec Canada, where it snows like hell in winter, so I'll keep you guys posted on the effectiveness of this fix in extreme driving conditions, but I'll have to wait for it to snow, which should be in about one month.
Have fun.
How many miles? I have the same year.
Madurodave
Member of BMWCCA!
Old 10-27-2011, 06:51 AM
Mein Auto: 2007 X3
± 80 000 miles
Old 10-27-2011, 07:55 AM
madurodave's Avatar
BMW Enthusiast!
± 80 000 miles
Wow - I am almost at 103000. So far ok, but looks like something I should at least look at next summer. Along with the ball joints!
Did you ever change the transfer case fluid before it went bad? Being a plastic gear, probably would notmake a difference. Just curious.
Madurodave
Member of BMWCCA!
Old 10-27-2011, 11:09 AM
Mein Auto: E60
The "fluid" (transfer case oil) does not come to motor side at all, its isolated ;-)
Old 10-27-2011, 11:35 AM
madurodave's Avatar
BMW Enthusiast!
Thanks. Thought it was in oil area.
BMW parts sites call it fluid, so that is the term I used (even though bottle says oil).
Madurodave
Member of BMWCCA!
Old 10-27-2011, 08:56 PM
Mein Auto: 2004 X3 2.5i
My understanding is that some part of the xDrive system uses the resistance detected in operating the wet clutches inside the transfer case to indicate the viscosity or general condition of the gear oil/fluid.
If the pressure required deviates from a certain range, it is concluded that the fluid is degraded.
Nothing to do with the actuator which just has grease in it.
(Measuring electrical conductivity of the fluid would surely be too complex a solution, even for BMW engineers.)
Old 11-01-2011, 07:47 AM
Mein Auto: 2007 X3
Used actuators
I was able to locate a few used actuators with ± 50 000 miles. Asking price $450. 2 month warranty included. Any takers?
Old 11-01-2011, 04:05 PM
I thought about that route too but if they are going out at 65-80K thats not much of a deal.
Old 11-01-2011, 05:34 PM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
Originally Posted by dgreen78 View Post
... Also, if anyone has a used actuator lying around please PM me, I would be interested in making a stronger gear for these (I am a machinist)
Been out of the loop for the better part of a week.
Uh, has anyone offered to send this nice gentleman one of their stripped-out gears ("pburnett," I think you had one)...? He wants to produce some stronger (presumably metal) ones for us...!
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 11-02-2011, 06:08 PM
Opps, had been away from the board for a little bit. I am PM'ing with him to see if we can make it happen.
The big challenge would be how to get the housing open without destroying it to get to the gear to replace it. Perhaps we can start thinking about that.
