Old 10-30-2011, 05:09 PM
rexgo's Avatar
rexgo rexgo is offline
BMW Student
Mein Auto: 97 528i
'97 528i With CEL / Code P0340 - CPS Replace DIY
Got a CEL - scanned and got a code P0340 / Cam Position Sensor Circuit A, Bank 1 malfunction.
Which means on my '97 528i single VANOS engine - 1 sensor on the intake side.
Had all the classic symptoms too: sluggish acceleration, and loss of ~ 4 MPG's.
Current mileage is 72K,
and VANOS was done ~ 15k miles ago..
C
hecked the wiring, and decided to replace the CPS. Seemed to be the original.
Read almost everything here, and on other forums for guidance. So thanks to everyone.
I decided to do another DIY to help those who follow.
Here's the location of the CPS intake side:
Here's better view of the offender - its blocked by the VANOS solenoid:
The CPS is a plugged into a connector under the intake manifold (IM). More on that later:
Here's some of the items you will need to address with sizes.
Remove 2 connectors: T
o the top of the engine & on the VANOS solenoid (so it won't twist)
Remove solenoid with 32 mm wrench as shown. Mine came off easily with the long wrench.
Before you remove the solenoid put a rag down to catch oil.
Remove oil filter and top - cover with rag to prevent foreign objects. Now you can get to the CPS:
Twist the CPS to break the seal:
The solenoid oil line (19mm) needs to be swiveled to allow removal:
Remove / cut plastic tie holding the CPS wire under IM:
Tie ~ 4 feet of string to the sensor to help installation of new CPS:
I decided to approach the CPS connection from the top through the intake manifold.
Remove top engine cover, and this is the view:
Remove connector and clip directly above plug:
Here's the plug:
Push the wire release - from the front of engine - and pull CPS plug out. Remove complete CPS though top of IM:
Here's the empty connector - note orientation slots:
Buy a new OEM sensor. I got mine from AutohausAZ VDO /Siemens made in Slovakia ~ $80 + frt:
To install the plug I made a wire tool that holds the end and extends my reach. Here's the tool and CPS:
Push the plug into the connector (while pushing on the wire clip)
Now switch the string from the old to new CPS:
Now feed the new CPS thru the IM, and use the string to pull it to the front.
Here it is emerging from the darkness.
Install a new o'ring on the CPS - lubricate it first with oil. Install CPS with loctite on the mounting bolt.
Reinstall solenoid, tighten, and make all other connections.
Here's the tools I used:
After all connections are made start the car and check for any leaks.
Shutoff engine - use your OBD scanning tool to clear/erase code. I have a Autel MS300
(thanks bluebee)
Restart car and success CEL light is gone. Power is back - boy what a difference - she's back!
Tom
'97 528i, 99k DD
'91 CRX Si, 114k
'83 Supra, 109k
Old 10-31-2011, 03:48 AM
Bazza-Aus Bazza-Aus is offline
Mein Auto: 2002 530i
Very nice work rexgo!
Old 06-03-2013, 11:19 AM
cn90 cn90 is online now
Some interesting things happened to my 1998 528i w/ 135K miles (Single Vanos)...
- Washed the engine using Purple Power, then gentle amount of water to rinse it off.
- Started the car, engine misfires a bit, not bad misfire, so I know it is related to the fact that I washed the engine.
Perhaps water gets into some connectors.
- Code P0340 (CPS issue) came up persistently for a few days. Then it goes away.
So I guess any water that gets into the sensor connectors eventually evaporates...
- At 135K miles, I know my factory CPS is probably on borrow time.
- Anyway, just bought a brand-new BMW CPS ($90 online) and keep it in the trunk for now.
Old 06-03-2013, 11:32 AM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
Very good write-up, subscribed.
Old 06-03-2013, 01:18 PM
dvdlkd dvdlkd is offline
Mein Auto: 1997 528
Your a genious. I would have never thought about the string idea to help with routing.
Old 06-03-2013, 05:45 PM
rexgo's Avatar
BMW Student
Mein Auto: 97 528i
Thanks, I got the idea from reading numerous threads on this subject.
Tom
'97 528i, 99k DD
'91 CRX Si, 114k
'83 Supra, 109k
Old 06-03-2013, 05:46 PM
rexgo's Avatar
BMW Student
Mein Auto: 97 528i
Some interesting things happened to my 1998 528i w/ 135K miles (Single Vanos).....
Good idea!
Tom
'97 528i, 99k DD
'91 CRX Si, 114k
'83 Supra, 109k
97 528, cps, cps diy
