DIY: E36 $10 City Lights - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 10-30-2011, 10:19 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
I finally got around to making the city lights that I've been waiting to do. There's another DIY on bimmerforums, but it's not very complete at all in the procedure, so I was never too motivated to try it myself. Well, I got bored and frustrated with the other projects on my car, so this DIY is the result.
It turned out to be really easy once I figured out the parts I needed.
-2x 194 bulb sockets - I found them at Autozone, they were labeled as "license plate bulb sockets", $4 each
-2x 194 bulbs - I ordered amber ones from Amazon and they were $4 for a pack of ten. Any 194 bulb will work, and they're pretty common
-large drill bits
-RTV
-butt splices
1. Assemble the bulb and socket
Put them together and you get this:
2. Drill the hole for the socket
I started off thinking that I would make a hole in the highbeam that was the size of the widest part of the socket, but I didn't have any drill bits that big, so I used the biggest one that I had. It was perfectly sized, just about the same diameter as the bulb. This was good because the top of the socket would fit hella flush, without too much space to wiggle around.
3. Install and seal the socket
The bit wasn't quite big enough, so I had to bore it out a little by rotating the bit about the hole until it got big enough so that the bulb just barely fits in. Then, I put some RTV around the edge of the hole to seal the socket. I later found that it was easier and less messy to just put the RTV on the part of the socket that will sit on the hole. That way you don't get any RTV on the bulb while inserting.
Push the bulb in, and it should fit pretty snug. I used some tape on the socket to hold it down while the RTV dried.
4. Wire the light
Once you're done with that, you need to decide how you want to wire them up.
If you want them to come on instead of the parking lights - Cut the wire going to the cornerlight that is for the parking light (not sure which one it is, may require trial and error. It's not the brown one though, obviously). Connect that wire to one of the wires on the city light socket, and ground the other wire from the city light socket.
If you want both parking lights and city lights - You might be able to do a three way splice on the parking light wire, but I'm not sure. You would need to do the same as above, but with a three-way splice instead of just re-routing the wire.
If you don't have foglights, then you can use the foglight wiring. This is what I did, since I don't plan on installing fogs. This is a little easier and you can control the city lights with the fog light button, which is pretty cool.
That's all there is to it. I have some pictures, but my car is stuck in the garage so they aren't that good (Damn ECS ). I love the way they look in person. I might buy some different color bulbs and see how they look for you guys. I'll probably try white and yellow.
Updated pictures:
-CJ
Old 10-30-2011, 10:22 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
Registered Non-OP
Mein Auto: A rental
Good stuff, looks good
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 10-30-2011, 10:34 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Wait just $10?
Oh fcuk yeah...I'm definately doing this...I'm sick of angel eyes...
Instagram | @randytheus
Old 10-30-2011, 10:37 PM
hornhospital's Avatar
D'oh, You Kids!
Originally Posted by KaptinKP View Post
I'm sick of angel eyes that don't work...
Fixed. Me too.
Quotes to live by:
Ken Kanne, Silverhill, AL, E30, E36 & New Member Intro Forum Mod-
BMW-CCA #441426
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Exactly how I did mine....
However, I can't remember if I mounted my bulbs in the top or bottom of the headlight. Whichever I did, it matched the true euro ones....
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 10-30-2011, 10:38 PM
crisscross's Avatar
Wait just $10?
I can help you do them, just come up here and we can do it in an hour or two...
Did you see mine when I was down there?
-Alan
-2000 F250 V10
Old 10-31-2011, 12:41 AM
andreialta's Avatar
andreialta andreialta is offline
Send a message via AIM to andreialta Send a message via Yahoo to andreialta
Mein Auto: BMW 325is
good DIY.. very Tempting.
1999 Estoril Blue M3
Old 10-31-2011, 02:06 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Nice job, although I believe even the French have largely abandoned yellow headlights.
What light pattern do you get out of the added 194 bulbs?
Would higher wattage bulbs be the ticket to turn your high-beam position lights into agreeable DRLs? You could dim them down with pulse width modulation when they should serve as position lights.
Old 10-31-2011, 05:17 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i dig.
however, changing the bubs to a different color or when they burn out will require more rtv and cleaning of the old stuff...
i think i would be looking for donor lights from a junkyard just to cut out the bulb fitting and see about attatching it (either by epoxy or melting the plastics together with a soldering iron).
still,
i still like angel eyes though...unfortunately i am not able to do what i thought i would as i do not have the euro style lights. (unless anyone knows of a way to cleanly seperate the lens without destroying it)
cj, have you tried using leds for the lights??
df
Old 10-31-2011, 06:28 AM
crisscross's Avatar
Originally Posted by drivinfaster View Post
i dig.
still,
df
Put the headlights in your oven at 200* for ten minutes, then separate the lens from the body
-Alan
-2000 F250 V10
Old 10-31-2011, 07:59 AM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Nice work. If I find myself bored (unlikely) I might run my angel eyes to an independent switch like I used to have in my E46, and wire these up to the parking lights.
Old 10-31-2011, 10:18 AM
cj.surr's Avatar
some kid
I actually wouldn't have to remove the the socket to replace the bulb, because I have these weird plastic headlights that actually have a removable lense
But even if I did, I don't really see a problem, since RTV is pretty easy to break, and the sockets are only $4 if something goes wrong.
-CJ
Old 10-31-2011, 10:36 AM
Gooby's Avatar
Mein Auto: 1995 M3
Fixed. Me too.
My angel eyes work just fine...lol
I just got bored of them...
Old 10-31-2011, 10:37 AM
Gooby's Avatar
Mein Auto: 1995 M3
Idk i dont like the idea of driving to Reno in the winter... =/
And i dont remember lol....if i did see them i forgot...
Old 10-31-2011, 01:36 PM
D'oh, You Kids!
I could just plug the 194 bulbs into the socket where the angel eyes would have connected, but I don't want to heat and remove my lenses and then heat and replace them after the bulbs are in.
And just like Amber's DDM lights, I can't drive with them until I get my new adjusters. The PO had removed the lower ones altogether, and the new lights are "coon hunting" REAL bad without them tilting the housing down. With the adjusters as low as they will go I'm still shooting way too high.
Quotes to live by:
BMW-CCA #441426
Old 10-31-2011, 06:45 PM
@ ken...thought you needed a pooch to do that...
you mean the plastic lenses don;t warp?? i read about the heating in the oven trick, but then discovered (according to teh interwebz) that this trick will work on the euro lenses but not so much on the domestic.
if so, then i'm in!! i have acrylic rod (3 different diameters) and want to 'play' with some angel eye designs, i have some leds that are beggin to be hooked up.
the only thing is i thought that i'd hafta buy euro lights to separate them, but now i'm just a little concerned about warpage....hmmm...maybe some ebay aftermarket units...
df
Old 10-31-2011, 06:51 PM
D'oh, You Kids!
df
My Miniature Pinscher goes crazy when I drive around the place at night. He thinks he's supposed to follow the lights. When they're pointed into the trees he gets pretty weirded- out
I hadn't thought about the heat warping the lenses (or back!) Scratch that!
Quotes to live by:
BMW-CCA #441426
Old 10-31-2011, 07:26 PM
crisscross's Avatar
Ok fine, maybe before bimmerfest 12 in the spring we can get together again
df
I did it on my old plastic ones and it worked out great! No warps and no hazing at all...
I really want to pick up a used set of Euro bosch units on ebay too....
-Alan
-2000 F250 V10
Old 10-31-2011, 07:37 PM
cj.surr's Avatar
some kid
Better pictures... Still look brighter in the pictures than they actually are.
-CJ
Old 10-31-2011, 07:39 PM
df
Old 10-31-2011, 08:12 PM
crisscross's Avatar
I can't get mine to photograph well either.....
Needz bumper mesh dude
-Alan
-2000 F250 V10
Old 10-31-2011, 08:14 PM
cj.surr's Avatar
some kid
Yeah, I've got the mesh, but I can't find a way to mount it easily. I've been using duct tape, but that obviously is not a very good idea. I will eventually weld them on.
-CJ
Old 10-31-2011, 08:27 PM
crisscross's Avatar
RTV may work, but I used a soldering iron to melt the piece to the bumper. I also tried JB weld for a while before I melted them together...
-Alan
-2000 F250 V10
Old 10-31-2011, 10:34 PM
cj.surr's Avatar
some kid
Yeah, I'll be using a soldering iron to weld it.
I just read something on bfc about people wiring angel eyes up to the windshield washer pump harness... Seems weird to me. Apparently that is a way to make them run all the time. I think I'm gonna try that sometime soon for the city lights.
-CJ
Old 11-01-2011, 06:23 AM
crisscross's Avatar
Search for Chad's DIY for angel eyes on this forum, there is a hot wire in the fusebox that will run AE's or city lights anytime the key is on. That is how I wired my old angel eyes in the 325i
-Alan
-2000 F250 V10
