Different scanner. New code - Bimmerfest - BMW Forums
Old 11-01-2011, 08:46 AM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
I had been wondering if different parts stores used different scanners. Autozone is less than a 1/8th of a mile from my house so I would just go there to pull codes. So today I decided to drive down the street to Advance auto parts to get a battery price for my wifes car and asked them if they could pull the codes for me.
They did use a different scanner and the little sob popped up a new code for me
P0340 along with the 171 and 174.
I believe I have found the culprit to the 171/174 issue. The vacuum jet pump behind the motor.
As for the CPS, Could this likely be the intermitent power and torque loss I am experiencing?
Old 11-01-2011, 09:17 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You have two CPSs; the right bank CPS is probably failing intermittently, and, if true, will cause a loss of power, at very least, and a stumbling engine, at most. Replace with a BMW-branded CPS.
The two lean codes could be caused by intake leaks, downstream of the MAF. The gasket between the throttle body and the intake manifold has been known to fail.
Don't know what a "vacuum jet pump" is.
Old 11-01-2011, 09:34 AM
540indiana's Avatar
Ed, I apologize It is called a "Sucking Jet Pump" (Part #1) and I am also suspicious of #4 in the diagram.
I tried the intake spray trick around the TB and no change in the motor. Unless it is leaking at the bottom of the gasket. I am just going to get a smoke test done and stop with all the guessing.
Old 11-01-2011, 10:58 AM
Here is the diagram of my sucking jet pump:
Engine => Vacuum control => Vacuum control - engine
And, here's a picture of mine:
It has three hoses. One is shown removed here on my M54 which goes from the F connector to the sucking jet pump.
If you have a simple layperson's explanation for how the sucking jet pump works, I'd be interested in the story.
PS: To the OP: What exactly was the problem you identified?
Old 11-01-2011, 12:36 PM
540indiana's Avatar
Blue, it has not yet been confirmed but I can hear air right at the jet pump and the line I noted in the diagram. Just by giving it a small turn I can hear the noise go away. That is what I am hoping.
As for the function Check out post #4
http://forums.bimmerforums.com/forum....php?t=1346918
Old 11-01-2011, 12:39 PM
Do report back when you resolve this.
Old 11-01-2011, 12:40 PM
540indiana's Avatar
Yes sir
Old 11-01-2011, 05:05 PM
rdl rdl is offline
Mein Auto: 530i 2003
I haven't opened mine up (i.e. broken it apart) to confirm but it's almost certainly the same principal as described in attached file, page 12.
Regards
RDL
Old 11-01-2011, 06:04 PM
Fudman's Avatar
Fudman Fudman is offline
RDL: A very informative .pdf! I've seen BB's posts regarding the sucking jet pump and I had no clue as to what a sucking jet pump was or did. It certainly had a strange name.
It is not a pump at all. It is simply a brake booster that uses intake manifold pressure to boost the master cylinder. When the car is started, the pressure on the intake manifold side of the jet pump is less than the intake boot side, so air flows from the intake boot into the intake manifold. The pump uses the Venturi principle to constrict the flow of air which increases the velocity of the airflow. This in turn creates a vacuum on the brake booster inlet side, which improves braking power. It's just a clever way to scavenge pressure differential to achieve an improvement to braking with no electrical component or parasitic loss.
Old 11-01-2011, 06:57 PM
540indiana's Avatar
I would love to get my hands on a M62 pdf like that
Old 11-01-2011, 07:25 PM
rdl rdl is offline
Like these?
Regards
RDL
Old 11-01-2011, 07:31 PM
540indiana's Avatar
Like these?
You are DA MAN!!!!
Old 11-01-2011, 07:33 PM
540indiana's Avatar
I would love to have a magical genie to fix my car????
Old 11-02-2011, 10:26 AM
Just for those who don't know, there are scores of engine-detail PDFs in the bestlinks ... (many of which are from RDL himself).
I see the M62 is covered ... e.g.,
- BMW Engines All About The M60 And M62.pdf
- BMW_M62_Engine_X5_details.pdf
- BMW Legends_ S62 V8.pdf
etc.
I'll see if the other PDF is there (if not, I'll add it).
Note: This is just a sub selection in one post ...
Old 11-08-2011, 04:32 PM
BTW, a reader reported his SJP broke, essentially in half, in this thread today:
- How does the BMW E39 sucking jet pump (aka suction jet pump) work & how does it fail?
