How to replace the fan clutch? - Bimmerfest - BMW Forums
Old 01-19-2006, 02:48 PM
NFS NFS is offline
Mein Auto: E39 540I
I need to replace the fan clutch on my E39 540I. I have the 32mm wrench but I can't stop the pully from moving to unscrew the fan clutch. I don't want to buy the BMW special tool just to replace the fan clutch. Any advice would be greatly appreiciated.
Old 01-19-2006, 04:03 PM
psychop's Avatar
psychop psychop is offline
Fastest 528iA in the EU;)
Mein Auto: E39 528iA
Just slide the wrench in and tap it with hammer to the left. Just be patient, doing it
for the first time might be difficult as the nut tightens with the fan rotating. When i was
removing mine for the first time i was knocking on the wrench for 5 minutes before
it gave up.
Be careful not to hit any engine accessories, i never did it on the V8 however in the i6
the VANOS actuator is in the way
E39 528iA/Steptronic,Professional DSP,Comfort Seats,Soft Leather,Xenon,PDC
Old 01-19-2006, 04:08 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
hahahaha!!! i was having fun with this today. 15/16th wrench fit well and it was a PITA to get it off... actually, i never got it off. i just got a new fan with fan clutch with the pump.
you know, if you can actually get the fan off, there's knotches in the fan clutch where you can slide a 10 mm on one end and an extention on the other to keep the clutch from spinning when you do the intial impact hit. find the knotch, and line it up with a nut on the pump and that'll hold the clutch in place. there's 3 hex screws that holds the fan to the clutch which at the end, will need to be taken out anyways.
i'll try to take some pics tomorrow as i forgot my **** today at home when i went to get some more work done at the shop.
Old 01-19-2006, 04:09 PM
supark supark is offline
Mein Auto: Falcor
what worked for me was working a thin blade screwdriver through the bolt heads on the waterpump pulley. It gave just enough resistance that I was able to get the fan clutch off.
Old 01-19-2006, 04:40 PM
bimmerd00d's Avatar
bimmerd00d bimmerd00d is offline
just havin a heart attack
Mein Auto: 1998 540i 6-speed
1-1/4" wrench fits too! put it on, get a rubber mallet, wack it clockwise, it's reverse threaded. It will come loose after 5 or 6 hard blows. Then spin the fan and it all comes off easily. do the same when reinstalling, just counter clockwise. MAKE SURE you do not swing down, swing up so if you lose grip, it flies and breaks a window, now your oil canister or cruise module.
2011 535i xDrive M-Sport - 129k miles
2006 Mazdaspeed 6 - 128kmi
2016 Triumph Tiger 800 XRT - 4900mi
Old 01-19-2006, 04:52 PM
NFS NFS is offline
Mein Auto: E39 540I
Thanks for the advices. Did anyone removed the expansion tank and the radiator cover to replace the fan clutch? Chivas, pics would be great.
Old 01-19-2006, 04:56 PM
bimmerd00d's Avatar
I did not, there is plenty of clearance with the fan and fan shroud off. The radiator/expansion tank does NOT have to come out.
Old 11-05-2011, 05:18 AM
Ricardo567 Ricardo567 is offline
Mein Auto: BMW 1994 325IC
I think we have to use the tool to take it out. It costs tremendously if we knock off engine related parts or break the fan cap.
I have the video show us how to remove the Fan Clutch
Old 11-05-2011, 07:00 AM
I realize this is a resurrected ancient thread, so, for the cross-linked record:
- How to make your own BMW cooling system overhaul fan clutch nut counterhold tools (1)
Similar Threads
Fan clutch replacing wallgood358 E30 (1982 - 1993) 4 01-22-2006 09:17 PM
FS:E36 M3 Coupe fan clutch & lights Roadmax Exterior 0 01-18-2006 02:17 PM
SS Clutch Line/BMW Clutch bleed tool and Clutch wear Gauge bob lindquist E36/7 Z3 (1996-2002) 12 05-01-2005 06:44 PM
Starting in 1st swchang General BMW Questions 49 07-16-2004 12:14 PM
Anyone replace their fan clutch? DIY? Pokerplayer 5 Series 1 11-05-2003 11:29 PM
