E90/E91/E92/E93 (2006 - 2013)
#26
Stupid english ambiguity. When I said that "Your car isn't designed to roll easy in neutral", I meant that this is not a design goal of the engineers, AKA: The car was NOT designed to include feature "X". It might in fact do so, but it might not.
I didn't mean to say that the car is designed to NOT roll easy in neutral, AKA: The car IS designed to NOT do "X". In other words, how easily a car rolls in neutral is a "coincidental feature", not designed per-se. That means I'm wary about using it as a test that the car is busted in some fashion. It's not a good diagnostic test, IMO. Could it be the symptom of a deeper problem? Maybe. But alone it's not definitive. Quote:
Key caveat: within limits. For instance, some cars can NOT be towed, even in neutral. But short rolls down hills are fine. |
#27
To answer the OP's original question: YES- someone else has noticed this.
I just took delivery of my car three weeks ago and I notice the same thing. My previous car (VW) rolled out of my garage easily in neutral- so easily I had to use the brake to slow it. My new BMW rolls about a foot and stops. The tire pressures are set to spec, and I don't feel any brake binding. I guess it's just normal for an e90, so I wouldn't worry too much about it. Could possibly be the negative rear camber that adds a little rolling resistance- and I'm not sure if there's some toe-in on the front or rear- which would of course be toe-out in reverse possibly adding additional resistance. Just a theory. Last edited by Dashdog; 11-07-2011 at 05:47 PM. |
#28
Thanks again and enjoy your new E90! |
#29
Seriously, perhaps you are having a bit of brake bite from the hill assist feature? Consensus is that it exists on BMW automatic cars too. If I have hill assist activated then shift into neutral, there remains a tiny bit of brake bite -- sometimes they will even squeak a bit until I start moving with power, then it goes away. The car will also roll slowly. If you just are driving the car, come to a stop on a slight downhill, then shift into neutral, will it still have high rolling resistance? What about if you come to a stop in neutral after rolling a ways, then restart rolling (completely disabling the hill assist?) What about with a very slight pull on the parking brake (supposedly this disables the hill assist), then does it roll easier? |
#30
How "stiff" are we talking? If you got out and pushed the car could you move it easily? |
#32
Is hill hold standard on our ATs?
#34
Out of respect to the OP, and in an attempt to salvage what I feel is a useful E9x discussion, this thread has been pruned of several non-helpful remarks and reopened.
Non-personal, on-topic responses will be appreciated. Thanks. |
| Tags |
| brakes, coast, e90, neutral |
