X3 E83 (2004 - 2010)
X3 Sunroof failure
My advice for X3 owners is DO NOT OPERATE THE SUNROOF. My 2007 was two months out of warranty when the sunroof ground to a locked-up failure. The vehicle was garaged its entire life in So. Calif. and the sunroof was seldomly used. On a nice sunny September day I pushed the button to fully open the sunroof and it made a grinding noise and locked-up. I took it in to the dealer who replaced the entire cassette mechanism for around $3,300 (net of a 15% discount). I wrote a letter to BMW of N.A. and was told there would be no adjustment from them.
Based on the limited use of my sunroof, I can only conclude they look good, but don't hold up very well. I figure my sunroof cost me about $165 each time I used it. Bottom line DO NOT OPERATE THE SUNROOF.
Sorry to hear this -- especially since the frequency of this problem seems to be creeping forward as each model year ages, and I also own a 2007...
But I am curious if there's a correlation between the failure of the roof mechanism and the amount of 'upkeep maintenance' that owners perform. My question is not an indictment of you; but how often do folks inspect the roof mechanism for debris and possible wear, and lubricate it? The only seemingly-recommended lubricant that I can find for this application is a MINI part number (83 22 0 397 761, "Kluberplex adhesive grease") -- which I'm willing to bet is basically lithium grease; I don't know what the corresponding BMW part number is, but I'll also bet it comes in the same can... Anyway, I'm postulating that these roof mechanisms may be failing due to (and please pardon the term) neglect by owners. In fairness to owners, BMW doesn't provide any guidance about how frequently these complicated roof mechanisms need periodic 'upkeep maintenance' (i.e., inspection and lubrication), or even where the lubrication points actually are. In fact, when I inquired about whether BMW would lubricate the roof mechanism as part of their Free Maintenance Plan, I was essentially told "no," although I managed to get them to do mine this past July when I complained about a squeak associated with roof operation. So I'm curious: does anyone take it upon themselves to lubricate these roof mechanisms, and if so, have you experienced any problems/failures...?
X3 w/6-speed & Sport Package: A sports sedan disguised as an SUV... |
Sorry to hear about the sunroof. Reading all the bad things about its mechanism on the forum, every time I open it I am afraid as if I am committing a crime or something. Who knows when it would start to act up. I have a 2007 X3 too so I hear you very well. BTW, I have read in some posts about people doing regular maintenance on their roof like greasing components and cleaning the gutter, etc. I haven't done it on my car yet from the time I have had it (which is few months) and don't know if the previous owner has done it. Do we have any DIY for that process here on the forum? I mean, is it like a time consuming process even to maintain it? Anything leads on it would be very helpful.
Coz if that's the case, I am taking your advice of not opening it again. I would rather buy a old convertible for that price (3.5K) and take it out as and when I feel like brining some sun into my car. |
As a rule, I will clean (as necessary) the roof cassette gutters and drain hole openings every time I wash my X3. Doing so isn't particularly time-consuming, although you do need to budget the additional time to operate the roof to different positions (you can't actually get to all the necessary spots with the roof positioned in one spot), and will probably need a step stool or some other way to easily see and reach over top of the roofline (if you, like me, are not fond of using the seats or rocker panels to do such things). I don't get particularly involved with the cleaning process; just a clean, damp rag seems to work fine. I am, however, careful not to wipe away any exposed lubricant from the mechanism; mainly, I'm just aiming to get any obvious pieces of debris (dirt, dust, leaves, etc.) out of the roof mechanism. Quote:
I agree with that assessment as well: cheap plastic components. I'm willing to speculate that part of the issue is that these plastic roof parts do not tolerate intense sunlight (in particular, UV) very well; I wonder what the proportion of failures is in the southern parts of the U.S. compared to the northern parts and Canada...? But again, if the plastic is kept well-lubricated, the lubricant will act a bit like a sunscreen and keep the part protected. Well, at least, better protected... I'm just speculating at this stage that the lubrication is not surviving well on the parts -- for whatever reason -- and plastic parts rubbing against other plastic parts is a recipe for failure...
Had to have mine replaced under CPO after I had it for about 2 months, so that's been about 3 years ago. Since then I will check it out every month or so right before I wash the car. I have found leaves, sticks and other small debris in the vacinity of the tracks that could very easily get into the plastic gears and cause issues. I typically pull the stuff out or vacuum it out. I will also spray the gear tracks and any other parts that look like they may need lubrication with a silicone based lubricant once or twice a year. I use that because it's non staining and has good water resistance. Don't know if that's the right stuff to use, but so far so good.
May want to consider that infreaquent use could also result in failure. Window seals can almost adhear to windows if not used used for long periods of time. The extra pressure caused by a stuck panel could result in additioanl stress on the mechanism. I wipe down the rubber seals with protectant a couple times a year to keep the rubber plyable and from drying out. However BMW must have some concerns or why else would they include an allen wrench to manually close the roof with the tool kit, and instructions on how to do it manually in the owners manual? |
My indie mechanic (who I stopped using for reasons unrelated to the sunroof) lubed it. When I asked what he was using, it turns out it was vaseline. That's fine with me if it works. I also use the sunroof regularly, based on the "use it or lose it" principle, and am careful that if I have to close it while driving I have the windows cracked open to avoid any unusual air pressure. I still haven't done any inspection (relied on the mechanic for that).
I have a 2007 too, sorry to hear about your exorbitant replacement cost, hoping to avoid that! (Knock wood!) |
Thanks timfitz63. I can do what you have been doing for minimum if not anything more. I guess that'll atleast make me feel good that I did my part if at all anything goes bad in the future.
I have an 06 with the same problem.I checked with the dealer both in Canada & USA and they would not admit to any design problem.
My own indi.mechanic found the broken part and it was PLASTIC on metal...I am hoping to get the part when I return to Florida next month.It is the front passenger side slide rail and costs approx.$250. With all the complaints I have read about with these roofs,it really burns my ass the way BMW is handling it. I will let you know how it works out for me. |
Nothing surprises me after the way they handled the whole transmission issues which at times were life threatening.
Sent from my DROIDX
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
Sorry to sound dumb here but does indie/indi mechanic means "Independent Mechanic?"
![]() That's another issue for me here living in small town that the closest BMW dealership is 4 hrs drive from my home so I will have to rely on a local mechanic here putting all my trust in him.
Here in the Bay Area, where BMW is the "California Ford", there are numerous independent garages, some with excellent reputations, that specialize in BMW. Good choice for a car out of warranty. In New Mexico from what you say I imagine you're going to find someone who's more of a generalist, so you'll want someone experienced, patient, and humble enough to ask questions rather than bull through things. |
after having a sunroof failure and seeing that actual weak part of the system, would there be any interest in an aluminum replacement part? it would cost around 400$ or so to get i machined
![]() Quote:
You are right! The mechanics here are expert in repairing trucks than anything else. I can see a truck in every four cars or even more at times. But I have found a guy who has worked with a BMW dealership for 6 years in his career so hopefully I won't have have to take his BS. Will see how it goes.
Mine failed on the front passenger side as well.
Coincidentally (or maybe not) I stopped using this mechanic when he used the wrong lubricant in the differential. Maybe it's not coincidence, maybe he's just consistent. |
Mine failed on my 2008 at just over 14 months or so, under warranty of course. I rarely use it since. It's a piece of ****, in my opinion. Sorry yours went too.
Does anyone know where we can get the Kluberplex? I tried a 30 second google search but didnt come up with much. Anyone else have thoughts on another type of lube for the sunroof (keeping in mind the plastic parts)?
2011 X3 28i (1/12 - present) 2011 328i (5/11 - present) 2009 MINI Cooper (4/09 - 5/11) 2006 X3 (03/07 - 1/12) 1995 325i (05/06 - 3/09) 1985 325e (08/99 - 12/04) |
Swap, you might want to go over to the regional boards here and post there for Indy recommendations in your area of New Mexico. You might find a diamond in the rough close by -- or not. Worth a chance anyway. I stopped using my sunroof as soon as I noted the startling frequency of failures here on the board. I don't like them anyway (prone to leaks etc.) and would never buy one on its own but it was included as "standard equipment" so I had to take it.
I'll research more when I have some time; or anyone else is welcome to take the baton and run with it for a while...
Sil-Glyde might be a good alternative lubricant.
It was recommended as a non-hardening, plastic friendly lubricant on a Full Size Jeep website. It was specified in a DIY to lubricate replacement plastic flex-track for old Grand Wagoneer "Woody" power windows. When I replaced the flex track, I also removed the hardened lithium grease from the power lock mechanism and applied the Sil-Glyde. Both the power window and door locks have been working well for 2 years.
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog 1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb BMW CCA #422951 |
#25
BMW sunroof issues have been around for a long time. Normally the grease from the factory is adequate. I have an E39 that is 12 years old and the grease still seems fine. I don't use the sunroof but do try to cycle through full slide open and then closed in the summer when the grease is thinner just to keep everything lubed. I never NEVER use the vent position any more due to the age of the arms that lift the rear portion into the vented position being the parts most prone to breakage.
Historically what fails are the arms breaking that lift the rear of the panel into the "vent" position. Pieces get into the track and then next cycle sliding the roof open you get the grinding noise and additional issues. However, I have seen many post on non pano roofs with step by step repair procedures. The parts are available to fix a broken roof and the ones that break are not that expensive. The dealer always opts for the replace cassette for two reasons, one it is easy and two they make more plus they don't have any liability if something else breaks. |
