Old 10-21-2011, 01:01 AM
Mars01 Mars01 is offline
Mein Auto: Z4 SI 2008, FORD EXPEDIT
z4 alarm kit #65 73 0 309 944 w/motion detector
Hi, I am installing this car alarm and I don't see or feel the wire in the middle consol to plug the motion detector.
I have followed the instructions posted by DaveZ in the HOW TO tread, is it possible that it is not there, I found the one under the hood.
My car is a 2008 3.0 SI fab: 03-2008
Do I have to also remove the center consol and if so, is there a HOW TO somewhere.
Thank you
Old 10-21-2011, 11:26 AM
Cvaria's Avatar
Cvaria Cvaria is offline
Mein Auto: 2003 Z4 ; 2002 Wrangler;
Thank you
How did you get the rear RH panel off of you car to install the siren without breaking it?
as for the console wire, the instructions say just feel around.
I went with the coupe alarm so i can't really help but, the wire under hood for the hood switch was actually above and behind the mater cylinder and mixed with other wires running along the area under the windshield... it was not "behind the master cylinder" like the instructions said
I like my 2003 Z4 2.5i... but love my smelly old 2002 Wrangler SE, 2013 Dyna Wide Glide 103 and evil 2007 HD Sportster 883/1200 conv!
Old 10-21-2011, 12:28 PM
Hi, thank you for the reply.
For the hood switch, mine where it was suppose to be like in the instructions.
About the the rear RH panel (bumper cover), that's what i'm trying to move right now, took out the 3 platic rivets and the 3 screws but it won't move, not further advance that you are there must be some kind of clips holding it.
I was thinking of removing the plastic that covers the wheel well, not sure if it would help
Finding the wire in the center console for the motion detector, I manage to go has far as toutching the hand brake lever and didn't find anything.
Those instructions aren't fully explain, when you first look at it, it is very simple but when the real live comes in play it's another story
Not sure but this might help http://www.bimmerfest.com/forums/sho...d.php?t=352257
Old 10-22-2011, 07:01 PM
Cvaria's Avatar
have you gotten the bumper free yet?
Old 10-22-2011, 09:27 PM
Hi, yes the bumper is free and the siren install also found the wire for the motion detector in the center console and everything is put back in its place.
Next step, the dealer to get it program, this coming Wednesday.
After reading the instructions for removing the complete bumper I removed another screw underneath the bumper, the one that is almost under the license plate, pull the bumper slightly in and out from the bottom to get it loose, took the upper end of the bumper near the wheel well and pull lightly, it came out fairly easily. The only thing that hold it on the upper side are little tab, when you get the first one loose the rest is a piece of cake
Hope this help you out
Old 10-25-2011, 09:56 PM
Hi, how are things going with your bumper, if I managed to take it of with my 0 mechanic backgrown, anybody can do it.
Old 10-28-2011, 02:06 PM
Hi, got my alarm program Wednesday, the stealership charge me 1.7 hour, total cost 251.69 CND. Asked the stealer if they had made physical test and he answered that every thing was ok
When I arrived home after a 2 hours drive I was in hurry to test it. The system is the same has it was before they worked on it, no motion detection, no hood and no tilt.
Call them back and now they arguing that the trouble in from the installation that I did and asking me to pay them to take a look at the installation.
I have followed the instructions very carefully, could I have miss something.
Thank you
Old 10-30-2011, 03:43 PM
Cvaria's Avatar
how'd you get the bumper loose?
I still haven't finished. i've been busy with work. I don't think i'm going to let the dealer touch my car after reading your post and the the crap they tried to pull on me to begin with. there are several good mechs with computers are here. I think i'll let them have at it.
Old 10-30-2011, 05:40 PM
Hi, after reading the instructions for removing the complete bumper http://www.bimmerfest.com/forums/sho...d.php?t=130986 post #20 I removed another screw underneath the bumper, the one that is almost under the license plate, pull the bumper cover slightly in and out from the bottom to get it loose, took the upper end of the bumper near the wheel well and pull lightly, it came out fairly easily. The only thing that hold it on the upper side are little tab, when you get the first one loose the rest is a piece of cake
Old 11-14-2011, 06:26 AM
Cvaria's Avatar
I finanlly installed the siren.. but it does not chirp. did yours chirp after install and before your coding nightmare?
Old 11-14-2011, 09:28 AM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
To get it to chirp you will have to get it programed. While your at it you might want to review the other car options, but for the 2003 cars there isn't a lot else to change. Daytime running lights, locks on rollaway, hardtop detection come to mind off the top of my head.
Old 11-14-2011, 09:40 AM
Cvaria's Avatar
I figured so but, a lot of people have chirping before coding
Old 11-14-2011, 10:00 AM
Hi, glad to see that you made it out with the siren, and for your question about the chirping, yes mine does, ounce when I lock it and twice for the unlock and this before coding it.
Old 11-14-2011, 10:49 AM
I helped with installing an alarm on a 2008 X3, when we got done it chirped (the lights flashed even before the install) but it still needed programing for the motion sensor. Both for my Z4 and the X3 it took two trips to get the programing right so double check everything before you leave.
Old 11-14-2011, 12:18 PM
Hi, this isn't the first post that I can see that it took more than ounce to get it coded; I'm in the same situation, returning this Wednesday at another dealer.
Did you ever knew what went wrong the first time, are the mechanics at BMW trained or are they broom sweepers?
About BMW do you know if they are aware of the poor quality of the mechanics that the dealer's employs, looking at it, it doesn’t look that hard to do the coding the proper way the first time?
Old 11-14-2011, 12:47 PM
I don't know what it was, each car was taken to a different dealer, but both places got it right the second time.
Old 11-14-2011, 12:52 PM
Cvaria's Avatar
i ordered the DIS blah blah GT1 software to code it myself, looking for a crappy $100 netbook to handle it.
Old 11-16-2011, 12:08 PM
Hi, got it programme this morning and now everything is working has suppose to.
By the way do you know where I can find the meaning of these figures
SA number:1CA, 205, 224, 249, 255, 2VB, 350, 354, 399. 430, 438, 441, 459, 470, 493, 494, 520, 521, 522, 534, 540, 550, 5GA, 639, 645, 662, 677, 692, 704, 785, 823, 845, 853, 876, 838, 548, 896, 302
Thank you all for your help
Old 01-06-2012, 11:38 PM
Cvaria's Avatar
SA number:1CA, 205, 224, 249, 255, 2VB, 350, 354, 399. 430, 438, 441, 459, 470, 493, 494, 520, 521, 522, 534, 540, 550, 5GA, 639, 645, 662, 677, 692, 704, 785, 823, 845, 853, 876, 838, 548, 896, 302 ($302)
I got the software ( NCSExpert, INPA, DIS and SSS) and coded the alarm myself with an OBDII cable .... after an incredible learning curve.
the FA number/VO is the code for all the options on your car that came from the factory. $302 is the alarm that needed to be added to the FA/VO in the AKMB and ALSZ ECUs.
after adding $302 and processing the car, the DWS options show up in the list of configurable options.
i beat the dealer! cost of my alarm... $100 ... bonus: i can now change what ever i want, whenever i want... no dealer scumbags needed. i can reset airbag lights and more... my car!
Originally Posted by ProRail View Post
Is the security of your BMW not worth $700? For me it was a no-brainer. Of course.
on the 5er it's standard, but I paid extra for the lo-jack. cheap insurance.
HA! cocky lunacy
Old 01-07-2012, 10:40 PM
papitosabe's Avatar
papitosabe papitosabe is offline
WalkTheWalk
Mein Auto: 06 Z4 Coupe
HA! cocky lunacy
good stuff man..congrats...never pay retail!
Old 01-15-2014, 03:42 PM
mini-me mini-me is offline
Mein Auto: F80M3, Z4MR, X5d
Any hits on the process to code this? I bought the cable and am trying to follow the instructions here but NCS EXPERT complains of an invalid VIN.
