Old 11-20-2011, 12:50 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
Auto Fold Mirror Fuse
So I heard that most E39 are prewired for the auto fold feature (like the E39 M5). How can you tell if your car has this feature? What fuse number is it? Searched, but to no avail.
Old 11-20-2011, 02:25 PM
sidneyj sidneyj is offline
Mein Auto: '03 BMW 530i
You heard wrong. You need mirrors, window switch and module for passenger side.
Old 11-20-2011, 03:03 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
The car is prewired for M5 mirrors, F29 controls the drivers side and F6 for the pass side.
All you need to do is plug in the existing cables to new M5 door modules (both sides) and then plug in M5 (or knock-off) mirrors into the door modules and your all set.
Old 11-20-2011, 03:21 PM
Thanks sidneyj
So Jimlev, F29 and F6 are the fuse numbers, correct? I am assuming these fuse numbers are located in the glove compartment area. Just to make sure, my car is a 98 E39 and it IS prewired (12pin connector). Are the M5 door modules just the switches for the mirrors? If so, can I just use a simple SPDT switch for the job?
Old 11-20-2011, 03:49 PM
QSilver7's Avatar
Here's some E39 Fuse Locations
Here's just a few of the images that get posted all the time when forum members ask about the location of fuses in the e39:
glove box fuses
trunk fuses
Q {BMW CCA Member #191509}
(SOLD)
Old 11-20-2011, 03:58 PM
Yes, those fuses should be above the glove box. The 12 pin connectors are already plugged into the door modules that are in your car now.
The M5 door modules are more than just switches, look at your drivers door, it has the switches for all of the windows as well as both mirrors.
The pass dor module is hidden behind the door panel.
You can operate M5 mirrors (rotate up/down) without purchasing new M5 door modules (about $600 now).
I bought the M5 door modules about 5 years ago at a discount.
I've helped a few guys with this wiring diagram for using a $5 toggle switch to control the rotate motor.
Make sure the switch you get is spring loaded and returns to the center (off) position.
Click here
Old 11-20-2011, 05:33 PM
I stand corrected yes the wires are all there but again the stock mirrors don't work and you do need the correct drivers side window switch and passenger side module.
Old 11-20-2011, 05:59 PM
Thanks sidneyj, yes I knew that I need to get the M5 mirrors with the motor, how else will they go up and down.
Old 11-20-2011, 06:01 PM
Thank you so much Q! I was actually looking at another thread in which you had the same exact post. Thank you so much!
Old 11-20-2011, 06:04 PM
I bot the M5 modules about 5 years ago at a discount.
Thank you so much Jim! Very helpful. So you did your own wiring from the switch to the mirrors and this eliminated the need for the M5 modules. Just install switch (btw, where did you put your switch?) to power source and to the mirrors as shown in diagram and just press switch when you want the mirrors to go up and down. Please confirm. Thanks
Also Jim, where did you run your wires from the passenger and driver side mirrors to the switch (for a clean install)?
Lol, sorry for excessive questions, but also where did you get your 12 volt power source from to connect to the switch from?
Just in case, the M5 modules are plug and play correct?
Old 11-20-2011, 06:20 PM
ProRail ProRail is offline
&amp;quot;Clunker&amp;quot; *****
Mein Auto: 1999 BMW 528A-220K-traded
Well, I guess you can really make an E-39 last forever. Just takes money and time.
Old 11-20-2011, 07:12 PM
No, I didn't use a toggle switch, I bought the M5 door modules about 5 years ago.
I've helped a few guys with the switch wiring diagram for using a $5 toggle switch to control the rotate motors so they wouldn't have to spend $$$$$ for the M5 door modules.
You can grab power from the fuses above the glove box or the cig lighter wiring.
You can put the switch anywhere you want, bur you will need to run wires fron the switch thru the rubber boot in the body to the door so you can connect them to the mirrow wires.
If you get the mirrors and M5 door modules it is plug and play, nothing else to do.
I looked up when I bought the M5 modules, it was 5 years ago and I got them for ~40% off list IIRC.
ID:	301982   Click image for larger version
Old 11-20-2011, 07:32 PM
Thanks Jim. Do you know a good source for the miyama ms500j switch. Can't seem to find any online.
Old 11-20-2011, 07:44 PM
Try Digi-Key.
It doesn't need to be this exact switch.
Any DPDT that has the center position as OFF will work.
Look for ON - OFF - ON with a spring back to center position.
I think C&K makes them too.
Old 11-20-2011, 08:25 PM
Try Digi-Key.
Thank you
Old 11-21-2011, 10:46 AM
aa240sx's Avatar
aa240sx aa240sx is offline
Mein Auto: 2001 BMW 530I
I've used JimLev's method and followed it to a T. Works perfect and bypasses all of the fusebox related stuff. Nearly plug and play. I also used a toggle switch which I keep in the slider just beneath the armrest and tapped the 'always on' power from the cig lighter.
- 2008 R350 Mercedes Wagon
- 2003 M3 Coupe - Alpine SMG
- 2001 530i - 5 speed, Anthracite Metallic, Sport Package
Old 11-21-2011, 11:07 AM
Doing a search in the bestlinks for 'folding' and 'mirror', I find currently:
- Mirrors, Remote power folding mirrors installation
- M5 Mirror Install
- M5 Mirror Install Diy
- Mirrors, wide-angle mirrors installation
Without doing any extra searches, I can still cull out duplicates and bad links. Then, adding this reference, we can get the following for others to benefit in the future from:
- How to add M5 remote power folding mirrors to your E39 (1) (2) (3) (4) (5)
Old 11-21-2011, 08:26 PM
Thanks for the input aa240. Did you have to remove a lot of dash to get to the wiring in order to wire both sides? Also, which switch did you use?
Old 11-21-2011, 08:27 PM
- M5 Mirror Install
Thanks blubee, very helpful as usual. Thanks for the links.
