Eeeewww!
![]() Getting the head cleaned/cut. Some warpage going on there and some coolant leaks. Waiting to hear if he found any cracks. Damn thing was a bear to pull off with all the crap attached to it. Anyway, look at the scale and crap on top of these pistons. Shop guy does engines for the BMW Stealer in Charlotte and told me to stop burning 87 octane because it puts huge thick carbon deposits all over the place. |
Wow..
~The Fun Cars~ 2003 BMW 540i [Sterling Gray / Gray] [Msport] [DSP] [AUX] [ICE V5] [BSWs] [DINAN Trans] [M Audio Subs] [E38 lighted int. door handles] [E46 Paddleshifters] [Two-tone Interior] 2008 BMW 550i [Jet Black / Black] [Sport] [Paddles] [Comfort Access] [IPOD] [Shades] [Nav] [PDC] A 5'er that was almost too good to be true. Stuff For Sale: OEM E39 Nokia Subwoofer [click] WTB: E39 Technical Graphite center console trim, A+ condition. |
That was my reaction when I took the head off. Unbelievably disgusting. Don't think I've seen that since the carb days. No more crap gasoline for me. That avg $1.40 savings at the pump for an 8-10 gallon fillup costs more down the road.
how many miles were on your car? what made you take this job on? were there any noticeable issues?
2000 BMW 528iA Step- 223K Miles- Aspen Silver ![]()
2004 Volvo V70R 2005 Nissan Armada SE OFF ROAD |
Getting it pressure tested and cut. Hopefully, he won't find any cracks, if he does and can fix it, fine. If he can't fix it, guess I'm saving up for a new head.
Do you think there is a possibility those heavy combustion chamber deposits happened during the overheating episode? |
No, but I believe it's a lower quality gasoline and the crap that is in it that may be responsible, that and the fact that my CCV had peanut butter pouring out of it when I removed it.
Maybe the clogged CCV sucked oil into the combustion chamber.
How you going to clean those pistons?
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
Went and got a wire brush attachment for my drill. Pretty fine wires, and if I don't put too much pressure on it, it shouldn't take off any appreciable metal. I'll put each cylinder at TDC before I do it and use a vacuum to suck out the mess.
Maybe you should set up the vacuum to pull the debris away as you use the wire brush.
Actually, that is the plan. Mask off the cylinders with the pistons not at TDC, scrub and vacuum at the same time. I've done something similar on other engines I've rebuilt, mostly chevy's.
FYI,
Costco (also amazon dot com) sells a fiberoptic camera for $130 (similar to colonoscope that doctors use to look at bowel). This camera has multiple purposes. it allows to inspect engine pistons etc. etc. - Octane 87 does not do this. - The common causes of carbon build-up on top of the pistons: a. Mixture too rich b. bad spark plugs create incomplete combustion c. Oil consumption, in your case it could be a blocked CCV. Last edited by cn90; 11-23-2011 at 08:52 AM. |
Actually, despite my appreciation for people who use the recommended fuel in their cars, higher octane burns at a *lower* temperature than lower octane. Additionally, "proper" high-octane gas (i.e. gas that isn't ethanol blended to achieve the octane rating) gets there with higher levels of aromatic compounds that will increase carbon build-up if the car isn't built for it….and whether or not our cars are is up for debate, but they're not super-high compression engines.
'99 528i ('98/12 build). 174,000km BY29428/Royalrot Breaking My Wallet since 2009 Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals '99 540i (grandfather's)
Mine looked exactly the same when I pulled the head for a HG job. I suspected a coolant to cylinder 6 passage way leaking very small. The car never really overheated but would warm up with sprinted driving. I used roll-loc disc and sea foam, I then followed that with carb cleaner to get in the piston skirts with compressed air to blow it out. The compressed air helps a lot. Also after you will want to change your oil to get out any cleaner that seeped past the piston. 10k later and my car is great.
In this thread, the Costco variant we found was more expensive than that:
- How to siphon the fuel out of the tank (1) But, we did find it at Walmart for $50 less than at Costco. ![]() I agree. This may help explain what an octane rating indicates: - Engine fuel octane (1) If so, the OP may wish to test his CCV: - How to test the crankcase ventilation (aka CCV, CVV, PCV, CPV, & OSV) pressure regulating valve system (1) Quote:
- CCV system overhaul (M54,M54,M54,M54, & M54 observations) (M52,M52) (M52TU) (M62,M62) ('99 528i) ('98 528i); usually replaced with the insulated CCV upgrade (1). Quote:
Here is more information to help you make good decisions: - "The Gasoline FAQ" & top-tier gas stations (1) Last edited by bluebee; 11-24-2011 at 10:43 AM. |
Either way, I'm gonna stop being cheap and start using higher grades of gasoline. For a 10 gal fillup, what am I saving by using 87? Maybe $2.50? $3.00? About $12-15.00/month? Is it worth it? BTW, this old guy who does work for the dealer is a BMW schooled tech. Now, I know how we all feel about them, but either way..... I'm sure that using a better cleaner fuel will not hurt me. ![]() Gotta find a Mobile station around here. Last edited by jarhed1964; 11-23-2011 at 11:47 AM. |
See above. It's not the octane he's ranting about. And the CCV is getting replaced. Not going to bother testing it. I got the intake off, everything under there is getting replaced. |
This post goes toward validating the argument AGAINST using low octane fuel vs recommended high octane. I always use 9X grade and some tried to argue in favor of 8X. Lower octane gas is less stable than high octane (under pressure). Pressure exerted on 8X by the pistons may prematurely ignite the 8X crap-gas (aka knocking). Our engines correct for the premature ignitions by changing the timing (prevents knocking). yet people STILL try to argue in favor of using crap-gas based on science that has ZERO to do with the reason BMWs require high octane fuel. BMWs have a high compression ratio as with most "performance" cars. Higher the compression the more likely 8X will ignite prematurely which is then corrected by throwing off the engine timing to compensate. Crap-gas misfired timing WILL impact your fuel-air mixture. Which, in turn, CAN lead to more carbon buildup over time. As for the rest of the unrelated information, nothing promotes using 8X octane beyond people trying to drive an executive level car on a shoe string budget. THANK YOU for this post as a picture says 1000 words. Not just because it validates my stand, more so because it is very educational for us all. . Last edited by seemyad; 11-23-2011 at 01:44 PM. |
- What are you actually saving/losing by using 87 vs 91 octane AKI (1) The net cost savings that can easily be calculated is somewhere around a thousand dollars per hundred thousand miles - but it's way more complicated than that so see the thread for details. Last edited by bluebee; 11-24-2011 at 10:44 AM. |
Tell ya what... my "advisor" has been pulling apart BMW engines for over 30 years, I would imagine he would have a pretty good idea what the results of different types of gasoline are on BMW engines. This thread was NOT started to rehash the ridiculous argument about 87 vs higher octane gas. If you would like to have that discussion, please take it to your octane thread. I have no intention of putting 87 octane in my BMW's anymore. If you choose to do so, that is your problem. I am not going to allow this thread to be hijacked like all the rest. Tell ya what.... if you feel you know more about the effects of gasoline on BMW Engines, please give this man a call at his shop. I'm sure he'd be glad to discuss it with you. Raymond Sharpe President Raymonds Auto Machine Service, Inc. 2923 Washburn, Ave. Charlotte, NC 28205 704-376-1912 Or, maybe you want to call the BMW Dealer and tell them about the things Raymond has been saying about BMW engines, since he does their engine work: Hendrick BMW 6950 E. Independence Blvd Charlotte, NC 28227 (866) 455-2752 Good to go? Are we done with this? Thanks. Last edited by jarhed1964; 11-24-2011 at 05:29 AM. |
Carbon Buildup in combustion chamber has many many causes. The bottom line is:
- Gasoline leaves behind a tiny of carbon when burned. Do this experiment outside on your driveway: burn a small amount of gasoline, maybe 10-20cc in a small metal can, and see what is left behind. - Oil leaves behind a lot of carbon when burned. Do the same experiment using 10-20cc oil. Don't tell the enviromentalists you are doing this (j/k)! ------------- Common causes: 1. Cheap Gas, This is a Must-Read written by Larry Carley, "Watch Out for Bad Gasoline": http://www.aa1car.com/library/bad_gas2.htm 2. Engine Oil somehow gets into the combustion chamber: - Loose piston rings (unusual before 200K for M52/M54 engines) - Loose valve guides (unusual before 200K for M52/M54 engines) - Clogged CCV ---> #1 cause in M52/M54 engines |
Wow, I'm surprised Mobile is not on the list of top-tier gasolines.
#25
But, assuming by "Mobile" the OP meant "Mobil", the links provided the OP earlier clearly state that Mobil is Tier-1 gasoline. |
