Alternator or battery problem - Bimmerfest - BMW Forums
Old 11-28-2011, 10:54 AM
jeffchapz jeffchapz is offline
Mein Auto: Z4 MR
Hello everyone, hope you had a nice long weekend...
Ok, so I have a radar detector that tells me the voltage in the car while the engine is running and now it shows that it is 10.6 and if it drops below 10.0 - the RD shuts off pretty much because the voltage is low.
The car started up fine 3 different times last night, but I left it charging over night and it looks like the battery was about 80% charged this morning as the charger was blinking with a green light. However, on my way to work my radar detector kept shutting down and evey time I turn it on.... it says low volt. so far I had the RD for over two months and always said 13.7 or 14.0 V.
I'm going to test the RD on a diffrent car to make sure that is not the problem, but if is not the RD and the battery charged last night.... would you say I have a bad Alternator?
Thanx.
2007 ///Z4 M
Old 11-28-2011, 11:27 AM
eken eken is offline
Mein Auto: 2001 Z3 3.0i
Sounds like an alternator problem your alternator should be putting out at least 13.5 amps. Stop at an AutoZone or Advance and have them check the output for you usually a NC deal.
Old 11-28-2011, 11:37 AM
Mein Auto: Z4 MR
Eken.... I didn't know Autozone could do that... Thanx for the info.
2007 ///Z4 M
Old 11-28-2011, 06:51 PM
Mein Auto: Z4 MR
Didn't get a chance to visit AutoZone yet, but if the alternator is not producing power or charging the batt.... where does the car get juice to power the electronics?..... ??
For now I have to keep my car on life support and plug it in every night when I come home so the batt has juice to start the car in the morning... from 1 to 5 how complicated is it to replace an alternator?? 5 being the hardest.
2007 ///Z4 M
Old 11-29-2011, 01:54 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
From the battery.
And running it like this may kill the battery also.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 11-29-2011, 08:20 AM
ZEEBOY ZEEBOY is offline
The Arkleyologist
Mein Auto: 2001 Z3 Coupe
Purchase a volt meter and put it on the + and - terminals of the battery (or from ground to + terminal of the alternator) while the engine is running. Should read around 13.7 volts. I would not necessarily use the RD as the final answer on voltage output.
Old 11-29-2011, 10:26 AM
Mein Auto: Z4 MR
Gentlmen... thank you for your time and sharing the knowledge.
I'm going to visit AutoZon as soon as possible or buy the device to check it my self.
Have a good one my friends.
2007 ///Z4 M
