6 Series DIY
6 Series Do It Yourself (DIY) forum. |
Oxidation on the Conv covering
Hello Members!
I just purchased an 05 645ci convertible. When I let the top down, there is a whitish/bluish stain on the cover. I suppose it is oxidation. Does this have to be painted over or is there some sort of chemical based solution that would remove it? I've tried general household cleaners diluted with parts water, but no success. Its on both the driver and passenger side of the covering. Thanks in advance! |
Have you tried RaggTopp cleaner and their protectant?
Nick / TopDownInFL (sans the "top down") 2012 650 Coupe - Alpine White / Black Interior / M Package / Premium Sound Previous Bimmers: 2008 650i Convertible - Monaco Blue / Saddle Brown Pearl Leather / Premium Sound / Sport / Cold / Comfort Access / Lane Departure / HD Radio / Sat Radio 2004 645Ci Convertible - Reverse Sensors / Reverse Camera / Retro iPod 2005 545i Sedan 2003 330Ci Convertible 2001 330Ci Coupe 1998 323i Convertible 1995 318i Sedan |
I may have not been descript enough about my issue. It's not the ragtop at all, but rather the plastic cover that hides the top after it has been dropped. It appears to be rings left by the seal or something. I will post pics of it shortly....
Ahhh - you mean discoloration on the boot. Yes - I had that in my last 6er convertible. I couldn't get rid of it. Does it only show after it's been wet (like after a wash or rain)? That's what mine did.
Try using some black shoe polish
Sent from my HTC EVO |
Hi Guys-
Thanks for the quick replies. I haven't been on here in a while b/c advanced statistics is doing the kung fu in my you know what (doctoral student)....i will definitely try the black shoe polish...should i use gloss or flat? I suppose flat would be the safe route in terms of ensuring the color blends well. Sounds like the excellent low cost remedy. |
Meguiars Spray Detailer has worked pretty good for me.
Black wax is good for it too - it's a product for the black plastics on cars. Also known as Bumper Black (in the UK!) or Back to Black........
Every autoparts store has some......... |
That sounds like the best solution.
Thanks! |
do you mean this type of thing
[IMG] [/IMG]if so i just done this [IMG] [/IMG]and i done front fog surrounds |
My 650 has it as well.
![]() It only shows when it's wet.
OK - found the solution. I used this stuff way back on my 318 when a detailer got a ton of wax on my black bumpers.
http://www.autogeek.net/forblacbumtr.html
I got rid of the oxidation I had (see the first pic below) by using Forever Black Bumper Trim. I taped up the edges of the Convertible Boot with Scotch Blue Painters Tape for Delicate Surfaces and applied two coats of Forever Black, allowing drying in between coats. While you can still see the runner seal placement lines on the boot (as I could before - the green only showed up when the boot was wet and/or cold and would take awhile to return to black), you can see that the boot at very least looks just black (second pic).
I'm much happier. I should've done this on my 645 - she had it worse and it always bothered me. BTW, it also looks a good number of shades darker, which I like.
Forever Black
I tip my hat to you for a very good follow-up to a question I asked months ago. Thank you for being diligent about finding a solution. I'm headed to a Forever Black dealer to purchase some now.
Thanks Top Down. |
Quite welcome! I've also redone my wife's Expedition. It came out looking new! Take lots of time taping up the edges - this stuff will stain! As long as you're careful and detailed in your taping, all will be well. Keep the spread even (it bubbles up here and there) to avoid streaks.
That is exactly what I was referring to. You did a great job on that cover man!
cheers mate, 3m di noc... very easy to use .. still not sure about doing the inside though
Zaino Z-16 Perfect Tire Gloss.
I discovered this stuff when trying to keep the wife's Volvo XC70 vinyl cladding looking good - after tryng literally every solution suggested by previous posters. I'm not sure why Sal calls it a Tire Gloss - he markets it as a "rubber and exterior vinyl finishing treatment" and it is absolutely the best product I've found for exterior vinyl (but I don't use it on my tires). I don't like silicone-based dressings of any kind for any purpose and this stuff contains absolutely no silicone. And it works! I will admit that I'm an unabashed Zaino fan and that my top spends very little time in the closed position. |
SMG Premium Sound Sport / Cold / Comfort Access 19" OEM Logic 7 Premium Sound HD Radio Heads Up Display Park Distance Control K&N air filter Aluminum Racing Pedals 6000k headlight upgrade fog light upgarde 2010 MV AGUSTA F4 titanium/RED frame 2010 Audi Q5 S Line |
just order forever black bumper trim and black tire gel
Quite welcome and you won't be disappointed. It's not a completely perfect solution, but your boot will certainly look black. I would suggest some bi-weekly touch up using something like 303 Aerospace Protectant - this will protect the boot and keep it looking new.
