Old 01-06-2011, 01:45 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
How to check power steering fluid
Hi, I have searched for about an hour on this. I have an 02 540. Sorry if it sounds dumb,but would you pleae tell me how to check my power steering fluid? I know where to check,but what should the reading be on the plasic dip stick hot/cold? I had a liitle leak and have fixed that and want to be on the safe side. Thanks
Old 01-06-2011, 01:52 PM
cn90 cn90 is offline
At the very bottom of this link, you will see the owners manuals in pdf:
http://www.e38.org/e39/
Old 01-06-2011, 01:58 PM
Its not in the manual.
Old 01-06-2011, 02:12 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
From the e38 owners manual which has the same (ATF) regular power steering reservoir design...(ignore the Self Leveling Pentosin (hydraulic) fluid info in the middle column)
From the BMW TIS:
Q {BMW CCA Member #191509}
(SOLD)
Old 01-06-2011, 02:13 PM
Wow, you are correct, damn BMW engineers for failure to include that in the owners manual!!!
http://www.e38.org/2002Manual-5ser.pdf
This link may help you:
http://www.bimmerfest.com/forums/sho....php?p=4631702
In my car, the PS fluid is about 1 inch below the PS reservoir NECK.
Here is a pic if you want to be more precise:
Old 01-06-2011, 03:08 PM
Thanks for the info. On the photo it seems as the min/max lines are wrong.
Old 01-06-2011, 04:06 PM
LOL,
I think they meant MIN and MAX air space above the fluid LOL!
Old 01-06-2011, 06:19 PM
Ok so would the bottom line be good when engine is cold and the top line when engine hot? Sorry I just want to be clear on this. Thanks
Old 01-06-2011, 07:35 PM
QSilver7's Avatar
The 2 lines below are taken from 2 BMW sources that are in post #4 above...do you need more clarification from any of the two quotes below?
  1. "The fluid level should be in between the marks on the dipstick"
  2. "On a stationary engine top up the fluid reservoir to the MAX mark on dipstick"
(SOLD)
Old 01-06-2011, 09:09 PM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
question of the day: how do you change the PS fluid?
Old 01-06-2011, 09:24 PM
The Simple way:
- Turkey baster (or syringe) to suck PS fluid out in a container.
Do this until it is dry.
- Fill with your favorite PS fluid (Dexron-III).
- Start engine, turn the Steering all the way R and L a few times to expel any air.
- Shut the engine.
Repeat this cycles a few times so most of the fluid is fresh.
The Complex way is via the steering rack line disconnect but that is more labor, so keep it simple as above.
Old 01-06-2011, 09:30 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
It's in my manual.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 01-06-2011, 09:51 PM
That's a good one for the power steering fluid thread.
- BMW E39 fluid summary printout for your glovebox (1)
Old 01-06-2011, 09:58 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Make sure you use ATF and not conventional power steering fluid
mujjuman
Old 01-06-2011, 10:06 PM
franka franka is offline
Mein Auto: E39 540i Sport
Use your best judgement. Fill it until the fluid is coming well up the first curve on the side of the container. It doesn't have to be precise and the fluid doesn't expand so you could theoretically fill it to near the top.
The idea is to have fluid in it at all times.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 01-06-2011, 10:09 PM
that is solved so now lets dicuss the silly and poorly placed change holder.
Frank
540/6
Old 01-06-2011, 11:06 PM
Thanks everyone lets move on........................
Old 01-07-2011, 06:23 AM
One other comment ... from my research (only) ... there is no longer such a thing as "Dexron III".
Apparently this is because only GM does the certification , and reputedly, GM no longer certifies Dexron III (in favor of Dexron VI certification).
So, the story goes, if you can't find Dexron III (presumably which is "old stuff"), then you can certainly use Dexron VI.
Or so they say ...
Old 11-30-2011, 05:32 PM
Edgy36-39's Avatar
Edgy36-39 Edgy36-39 is offline
Constantly Learning
Mein Auto: 2006 M3, 2002 M5
Found this b/c I need to top off. FWIW, Mike Miller recommends Red Line Syn Power Steering fluid.
BLUE HEAVEN:
Interlagos Blue 06 M3, Autologic tune, K&N CAI, Agency Power midpipes and exhaust, Fortune Auto coilovers, ///M Pedal Kit, UUC SSK. MRegistry listing here.
Le Mans 2002 M5, Black/Titanium, Rogue SSK, Dinan exhaust, PSS9 coilovers, Euro rotors, iPod integration. MRegistry listing here.
Old 12-01-2011, 02:33 AM
I'll add that useful information to the bestlinks ...
- Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1) & how to clean the power steering fluid reservoir internal filter (1) (2) & how to replace the cap o-ring (1) (2).
