Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Old 11-26-2011, 09:20 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '00 540iT
Believe I have the real data on 335D Oil Capacity
Was at the dealer today because got a screw in a tire on the 3 week old (to me) car. Was near the edge so not repairable. Guess $300 out the door is not terrible.
I asked the senior tech about oil capacity. He indicated it takes 8-1/2 bottles of Castrol quarts to bring it to the full line on the 335D. Thus I suspect the full capacity (with filter) is 8 liters. But most dealers will put in 8 quarts (7.57 liters) placing the level about 1/2 quart low, or midway between the full and add one quart mark.
Old 11-29-2011, 02:10 PM
diesaroo diesaroo is offline
Five is Right Out!
Mein Auto: 1987 190DT, 2009 X5 35d
I asked the senior tech about oil capacity. He indicated it takes 8-1/2 bottles of Castrol quarts to bring it to the full line. Thus I suspect the full capacity (with filter) is 8 liters. But most dealers will put in 8 quarts (7.57 liters) placing the level about 1/2 quart low, or midway between the full and add one quart mark.
Mine is not an E90, but the engines are the same. Mine has always taken 7.4 quarts to get to 1/3-1/2 of a quart below full. So the oil change kit should come with 8 quarts and you'll have about 0.6 quarts left over.
Build a man a fire, and he will be warm for the night. Light a man on fire and he will be warm for the rest of his life.
Old 11-29-2011, 02:47 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
Do dealers really buy it in quart bottles? I always thought they had these huge vats in the ceiling. The things you learn from Bimmerfest Also, why would theu use quarts rather than liters (litres)? Sounds fishy to me.
Old 11-29-2011, 02:52 PM
"Clunker" *****
Why does it take so long to edit? Seems to me it used to be instantaneous.
Old 11-29-2011, 04:06 PM
Yes they use bottles for the LL-04 Diesel oil. They have drums for the more common LL-01 oil. They get the LL-04 oil in quarts becasue it's manufactured and packaged in the USA. Same bottle that you can find on the shelf of a well stocked auto supply store.
Old 11-29-2011, 04:22 PM
Think I have your answer. 335D and the X5 35D may have the same engine, but they do not have the same oil pan. Doesn't the front drive axle go right through the middle of the oil pan on the X5? It sounds as the space displaced by the tunnel for the axle is about 1/2 a quart.
Why do you not use the full 8 (or 7.9) quarts and put it on the full line?
Old 11-30-2011, 02:12 PM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
what color of your dipstick? There is a minor difference (~.25 liter) between red and black.
Old 11-30-2011, 03:48 PM
Red, What's the difference and why? I would think a black one would make it real hard to see the level.
Old 12-01-2011, 01:42 PM
Mein Auto: 335D
Minor changes in the oil pan I suppose. I found that info over a year ago on Amsoils website. It was 7.3 liters for black and 7.5 liters for red. IIRC only earlier models had red.
