Old 12-03-2011, 01:47 PM
mikebhouston mikebhouston is offline
Mike
Mein Auto: Z3M Roadster
Exclamation 2nd gear randomly pops out after it's engaged...loudly! Z3
So i've only had the car for about 3 months but this has happened a handful of times. I'll shift from 1st to 2nd and with a load bang, the shifter throws itself back into neutral! It's a startling experience, makes you feel like the transmission just exploded, lol. But then I'll firmly shift back into 2nd and all is good.
Afterwards I always think maybe I didn't shift it fully seated into 2nd gear. But I've never had this problem on any other car. I read this post...
http://forum.roadfly.com/threads/756...ing-Out-of-2nd
...and it perfectly describes the experience. This is 2000 M Roadster 5 speed with about 110,000 miles. I have not taken it to the dealer. I was thinking of changing the manual transmission oil and see if that helps.
Last edited by mikebhouston; 12-03-2011 at 02:08 PM. Reason: couldn't edit the post title to insert Z3
Old 12-03-2011, 05:33 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
You might also consider.....
Looking at the transmission mounts and the shift linkage. BMWs have a problem with transmission movement which can cause missed shift. There are also parts in the shift linkage that were out.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 09-16-2016, 07:12 AM
Kitastoeger Kitastoeger is offline
Mein Auto: BMW
My '98 M3 pops out of second occasionally. Never a problem getting into gear. I replaced the bushings a couple of years ago. What causes this?
Old 09-16-2016, 10:52 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
Engine mounts, transmission mounts, shift linkage wear, as well as high internal wear can cause this issue.
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 09-16-2016, 05:07 PM
Mein Auto: BMW
So it could be a lot of things...
Old 09-18-2016, 08:56 AM
bmwz3guy bmwz3guy is offline
Mein Auto: 2011 328xi, 1996 Z3
Trans popping out of gear
My 1996 Z3 had a similar problem a bunch of years ago with 1st gear popping out to neutral. Turns out there is a Technical Service Bulletin on this specific problem and a secret recall to fix it. A guide sleeve inside the transmission was machined incorrectly at the factory and BMW replaced the manual trans after a lot of screaming and swearing on my part. Cost me about $600 for labor to install a BMW rebuilt trans. Unfortunately I bought the car used from a Mercedes dealer (not BMW-Certified Pre-Owned) and the car was well out of the factory warranty period. Had it been CPO, BMW said it would have replaced the trans for free. Like I said earlier, a lot of jumping up and down and swearing got them to at least replace the trans.
BTW - a local BMW dealer could not identify the problem so I took it to a highly reputable BMW repair shop who spent more than 2 hours diagnosing and researching the problem. That shop apologized for charging me $150 and recommending I take it back to the dealer given the TSB on the problem.
Old 09-18-2016, 10:24 AM
Mein Auto: BMW
Do you have a link?
Old 09-19-2016, 03:28 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by bmwz3guy View Post
My 1996 Z3 had a similar problem a bunch of years ago with 1st gear popping out to neutral. Turns out there is a Technical Service Bulletin on this specific problem and a secret recall to fix it. A guide sleeve inside the transmission was machined incorrectly at the factory...
Originally Posted by Kitastoeger View Post
Do you have a link?
He has a '96 1.9 with a Getrag transmission and you have a '98 M3 (not a Z) with a ZF transmission. I doubt if the problem is the same.
