E36 (1991 - 1999)
Old 11-30-2011, 09:37 PM
ramutio ramutio is offline
Mein Auto: 328i E36
Lightbulb New E36 Owner - Car Summary & Tips Request
Hello,
A few months ago, I acquired a 1997 328i Std. Coupe. This is my first Bimmer, and to be honest, it never crossed my mind to purchase this car, however I got very lucky with the deal and didn't think twice to make it mine... well yes, but my Uncle & Father made me change my mind.
I purchased the car from a very good friend of my Father. This guy is very "special" and meticulous in every aspect of his life, specially his cars. For this reason it was a guarantee that I was purchasing a car in excellent conditions. Best decision ever made
I purchased it with 108K km (67K miles) and now it's currently with 112K km (69.5K miles). I have the intention to make every preventive/corrective maintenance needed, and have my car sharp as new. However your advice and experience is greatly appreciated as I don't have deep pockets and would like to avoid spending unnecessary or at least too early.
Is there a way to pull the maintenance history for the car? Local Dealer or Global Database?
I have the following BMW services (at least recorded in the Service Manual):
1.- 02/09/1999 -> (12K miles) Oil Service
2.- 08/17/2000 -> (22.5K miles) Inspection 1
3.- 06/11/2002 -> (35K miles) Oil Service
4.- 07/17/2006 -> (55.5K miles) Inspection 1 / Brake Liquid
Looking at the above (only) 4 services, then it doesn't make any sense what wrote about my father's friend LOL... but really, car is, looks and drives as new. Soon I will upload & share some pictures.
What do you recommend me to do next or think is missing for maintenance considering the current mileage and the listed services? I have made the following progress so far, I'm a DIY guy:
Changed:
- Manual Transmission Oil
- Coolant
- 3 Hoses that plug to the Radiator
- Radiator Vent Screw
- Belt Tensioner
- Both V-Belts
- K&N Air Filter (Cleaned)
- Spark Plugs
On The Way (Just Ordered):
- New Brake Rotors, Pads & Sensors
- Camshaft Sensor & O-Ring
- Hood Struts
- Washer Pump
Detected & To-Do:
- Power-Steering Leak
- Fan Clutch - I will make the electrical conversion
- ICV Clean
- Whatever comes out of this post
Thanks for your time and any advice.
Old 11-30-2011, 10:05 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
I like you already. Determined to mintify your car before modify. Add all the cooling system components to that list. I mean, everything in the cooling system. Your car is at the age/mileage where it starts to fail and overheat the engine, which will kill it. ECS tuning has a complete overhaul kit with everything you need except a radiator and extra gallon of coolant. When I did my overhaul, I went with an all-aluminum radiator, so I didnt have to worry about the plastic side tanks cracking (which they tend to do).
You're also at the ripe age for the suspension needing new bushings all the way around. Do a little bit of searching and read the stickies, theres tons of bushings and if they fail, you could have serious problems.
Oh, and the way it works here is pics or it didnt happen
Welcome to the fest
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 11-30-2011, 10:15 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yep, as Chad mentioned above, the cooling system overhaul should be your very first priority. This includes changing the radiator, expansion tank, bleeder/vent screw, expansion tank cap, thermostat, thermostat housing, water pump, belts, hoses, and fan. These items MUST be replaced every 75-100k miles BEFORE something breaks (and it will).
Otherwise, your plans seem good. Just about every E36 out there has weeping power steering hoses - not a big deal. Just make sure the fluid is always at the correct level. And yes, as mentioned above, many of the suspension bushings will soon start to go bad if they haven't done so already. Same goes for your ball joints and tie rods. Basic maintenance stuff, and VERY easy to do yourself if you're willing to take the time to learn. These cars are dead simple to work on.
There is a lot more info available in the "stickies" at the top of the main E36 forum page.
1998 BMW 328is
1966 Pontiac GTO
Old 12-01-2011, 12:53 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
Yeah!!
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 12-01-2011, 01:27 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
welcome to the 'fest
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 12-01-2011, 01:29 PM
Fast Cars Suck!
also here in the states Car Fax can tell you some of the recorded maintaince history, normally whatever was done at dealerships
Old 12-01-2011, 01:35 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Welcome! They basically covered everything above so I don't have much to add, but you should find out if he did his own oil changes between services because that's scary long.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-04-2011, 01:10 PM
Mein Auto: 328i E36
Thanks guys for your input. I did had in mind to change the water pump, thermostat housing (aluminum) as I read they tend to break. Now I will focus in all the cooling parts that I haven't changed already... The upgrades will have to wait
ID:	303604   Click image for larger version
ID:	303605   Click image for larger version
ID:	303606   Click image for larger version
ID:	303607   Click image for larger version
care, diy, e36, maintenance, services
