Old 12-02-2011, 02:23 PM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
Z4 M Pedal Install Instructions
Anyone point me to a DIY You-Tube or direction sheet? Just picked up the pedals today, and the gas pedal was not what I was expecting. It's got a big box attached to it that needs to plug into something!
Regards
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 12-02-2011, 02:53 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Regards
Did you look in the Z4 FAQ ???
Old 12-02-2011, 02:58 PM
No! That would have been too easy and I would have immediately found your post on how to do it.
Thanks!
Project for tomorrow morning! Yeppie!
VRSF Charge Pipe /
BMWCCA Member
Old 12-02-2011, 03:04 PM
Ron
However I do have one question, in the instruction I did not see disconnect battery, but at the end it stated reconnect battery. It also mentioned coding. Why coding if its a simple plug and play up grade?
Regards
VRSF Charge Pipe /
BMWCCA Member
Old 12-02-2011, 03:08 PM
Never mind about the battery part. That part is going to be the hassel, it will take more time to get the battery cover off than to do the mod.
VRSF Charge Pipe /
BMWCCA Member
Old 12-03-2011, 11:36 AM
Got it all done. Is there a length of time the battery can be un-hooked that can cause any issues to the car?
VRSF Charge Pipe /
BMWCCA Member
Old 12-03-2011, 07:20 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
Nope- I did the pedals without D/C'ing the battery with no issues. You may have to reset the clock or reinitialize the auto up windows. The pedals are cool huh? Should have been standard on the M IMO. My S2000 had cooler pedals...
Old 12-03-2011, 08:17 PM
Doc, the clock was no problem, the auto up windows, how do I get that back? Everything else works fine.
VRSF Charge Pipe /
BMWCCA Member
Old 12-04-2011, 04:58 AM
http://www.bimmerfest.com/forums/sho...3&postcount=19
Also in the FAQ
I will tell you I did NOT hook up a battery charger. The process worked fine without it. I had to use it when I changed my battery last month.
Old 12-04-2011, 02:58 PM
I fired up the car and did it while running. Worked great!
Thanks Doc, Thanks Ron!
One more mod in the car. Yeppie.
Finished product:
VRSF Charge Pipe /
BMWCCA Member
