E36 M3 (1995-1999)
Old 12-03-2011, 08:29 PM
jlezin jlezin is offline
Mein Auto: 1999 M3 Convertible
Trim piece needed
This is my first time on the forum. Not sure if I'm notified of an answer, or if I check the forum. Here goes:
I'm looking for the two trim pieces on a 1999 M3 Convertible that go around the seat belt, in the back seats. Mine are cracked and I'd like to replace them. Anyone have a clue where to look? I've tried a few online sources but no luck. Thanks in advance, for any clues (or even a part number).
Jeremy
Old 12-04-2011, 07:36 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
Jeremy:
For future use try bmwfans.com and or realoem.com to locate the parts you want.
I am going to guess that what you mean is the surrounds that hold the belt in the front seat located on each side of the rear panel.
http://bmwfans.info/parts/catalog/E3...im_panel_rear/
look at part 3 if that is the one you want you have to pull that panel to install it correctly.
Hope this helps and is the part you are looking for...
Old 12-04-2011, 10:11 PM
Thanks!
That's exactly it. Thanks so much for putting that together for me and introducing me to BMWFans
Old 12-05-2011, 05:57 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
To put them on, try unbolting the bottom part of the seatbelt bracket. There's a small plastic cover and a bolt underneath.
Make sure you put it all back though!
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
