#51
http://www.youtube.com/watch?feature...&v=IIR-CYQ6zIA A good closeup starts at about 1:03.
BMW--giving new meaning to the phrase "disposable income." |
#52
![]() I absolutely guarantee you that when I put them back on, those damn things won't be so anxious to get back in there. It's a conspiracy against me. I'm not paranoid, I'm absolutely sure they hate me.
#53
You might find the installation tool he used (a socket with a parabolic section cut off the side) helpful in removing the remaining retainers. Don't wait to check out the video.
#54
Also, 540Alex and I learned that lapping the valves doesn't give as good a seal as using a poly crystal diamond cutting resurfacer that a top-notch machine shop would use. As it was explained to us, this cutter leaves the chamber so airtight that if you used a felt-tip marker on the valve seat, it would make the seal less effective.
#55
Yeah, I think that is kewl. Saw a few tools fashioned that way on Youboob. I'm curious how you cut that section off of a socket though.
#56
I'm going to ask my machine shop if they have that. I'd imagine I'd have to take the head back with the valves, right? |
#57
I didn't realize that the 540 springs were in a "well" like that. The 528i springs are sitting above the base with no well around them. What was the reasoning behind the shims? To give more compression to the valve springs? |
#58
A rotary cutting tool (grinder with a diamond cutting disk) should do the trick, just be careful not to overheat it. I don't know how Alex did it. A hacksaw could take a while, I'd guess.
#59
![]() I think I'm going to go pickup a huge c-clamp at Harbor Freight and cut a cheap socket to use for the rest of them. I was digging around earlier looking at ways to clean the valves, especially the carbon on the exhaust valves. The Blaster LMT didn't soften it really, so I checked out a link from the 540 build where a guy used the wire wheel on his grinder/buffer to clean the carbon off, then polished them down with emory cloth and fiber/paste. I think that is a definite. Don't want carbon building up on them easily again. It'll take a while for 24 valves, but I think if I hit the stems and face with a wire wheel on the dremel, then maybe 1500 grit emory and oil, I should be able to get the stems and faces very smooth and shiny, THEN do the re-seating. ETA: It's pretty obvious that my compression had to be low because the seat area of the four exhaust valves that I've pulled so far are not only crusty with carbon, but also have an almost concave shape that I can detect with my naked eye. Pretty sad, really. Once this is done and back together, I should pickup a lot of performance when they are seated properly. Last edited by jarhed1964; 12-08-2011 at 07:53 PM. |
#60
As for the machine shop, Alex took the heads, with the cams and valves stripped out, and with every part carefully identified by its cylinder number, to the shop. He re-installed everything. You might look through the thread, which has a lot of info and photos. In looking for a shop, I think your best bet would be to find a place that does a lot of race and performance car preparation.
#61
Yeah, I'm reading the entire thread right now. The shop I used for the compression test/cleaning/cutting is the shop that does the engines for the dealer here in Charlotte. I'll ask him, but if not there are plenty more around. |
#62
Yeah, I'd guess that there are a few performance shops around Charlotte.
#63
Dirty and clean.... x24
#64
Cleaned up the VANOS and replaced the seals. Thanks to Besian Systems.
#65
Finishing up valve lapping. Actually lapping is doing a very good job at seating these valves. Not taking very long either.
Waiting for a shipment of small stuff from ECS Tuning, going to pickup my replacement copper nuts for exhaust today. Renting timing tools from a user on one of the forums. Scrubbed out the intake and exhaust ports, chipped away at the carbon, then took a stainless wire brush with the dremel to it. Not polished, but clean. Tough part will be cleaning out the ports thoroughly of any garbage, and making sure the valve guides are completely clean of any grit before I put the valves back in. Lifters are all cleaned and soaking in Mobil 0-40 synthetic. I literally pulled the plungers out and cleaned the glaze off of them and the inside of the lifter cup. Once that is done and the old oil forced out of the plungers by depressing the check ball, the two part plungers move freely. I put fresh oil back into the cup before pushing the plunger back into it. Going to lightly sand the springs with 1200 grit, then oil them, then line them all up to make sure they are the same level. Those that aren't and seem permanently compressed will be replaced. I've not put valve seals on a BMW before but they lock on at the bottom. I think I'll be trying to use a small piece of pipe over them or a socket to press them onto the valve guide until they snap into place. I'll be replacing four valve keepers because one flew away somewhere when I pulled it and I figured I'd get extras in the order from ECS. |
#66
You guys and ladies that go to this extent on your engines are freaking awesome! I envy you your ability to do so. You basically have a brand new engine.
I WANT A BRAND NEW ENGINE TOO ![]() . |
#67
HA!! ![]() I wouldn't say a brand new engine, heck, I'd have to replace all of the valves, springs, pistons, rings, crank and bearings, etc... Actually, when you open any engine up, you see things that need to be done. I couldn't sleep at night knowing I put filthy crusty valves back into the engine or old beat up worthless valve seals, etc.... I had to do this job because of necessity: a coolant leak I couldn't pinpoint. Once everything came apart, I identified other things that would have been foolish to do another time. Intake manifold is off, might as well change the CCV, and so on. On another note, I realized that the red "crust" on the underside of my valve cover was actually CARBON mixed with oil to make it red. So...... trying to figure out how carbon got under there. I'm thinking the valve seals were so stretched out that they just didn't do the job anymore and exhaust gases went right up there. It was crusty when I took it apart and I thought to myself I need to figure out where it came from. Started cleaning the cover today and have to literally SCRAPE the crust out of there. It's soaking now. Last edited by jarhed1964; 12-16-2011 at 03:31 PM. |
#68
Good to see all this stuff being done. It makes me wish I had an actual garage to work in for the projects that take more than a day.
#69
Great thread!
Thanks! Jason
+1!! This thread is awesome! Keep it comin!
2000 528i steptronic Blacked out |
#72
Parts from ECS Tuning showed up yesterday. Got four new valve keepers, the "closing panel" for the firewall (that plastic thing behind the engine that falls apart into little pieces for older E39's), and a new blind plug where the TDC Locking pin goes.
Finishing up installing all the valves. Putting new valve seals on all valves. Valve goes in, protective sleeve goes on the valve stem, new seal goes on, then is fully seated with a 9mm or 10mm socket. No pounding or heavy force needed. It just sorta "snaps" on there. |
#73
Ok, so...........
9 year old decides to play with the damn lifters, getting them all out of order. ![]() At least they are still separated between intake and exhaust, but other than that... Don't worry, I didn't kill him. I'm just going to have to do my best to match them up. There are no identifying marks or scores that will help me do that, but I don't have a choice.
#74
Unfortunately, when you create a situation that makes it possible for a 9-year-old to do what 9-year-olds do, the results aren't surprising. Glad you didn't kill him. How do you plan to match them up?
#75
I have no idea how I'm going to match them. There are three new ones going in but other than that I have no clue. |
