Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 12-08-2011, 03:24 PM
BMW535xia BMW535xia is offline
Mein Auto: 535xi
Dealer repaired/ replaced the following today under warranty on my 08 535xi after diagnosing shorted/burned right taillamp assembly:
- new connector
- new carrier
- created ground
- replaced bulbs
no issues with driver side assembly as of now
Old 11-14-2012, 07:00 AM
vbcgy vbcgy is offline
Mein Auto: 2008 528i
I am now joining this thread encountering the same problems. 08 528i no warranty left and three weeks ago one of the small bulbs burnt out and i received a quick message through iDrive. Went to the dealer paid $24 bucks and had it replaced.
The service guy warned me about this inherent problem with my model and said that if the bulb burns out again I would need to have the wire assembly replaced. Aprox $200 bucks.
Three weeks later that bulb is burnt out again, so I wanted to ask the question. If I were to replace the burnt out bulb and the matching one on the right side with LED bulbs that consume less power. Do you think that might avoid a further problem and save me from having to get the rewiring done?
As an FYI...
I wrote into BMW Canada complaining about this issue. This is clearly a defect and if it can affect the rear light cluster and potentially the brake lights it should be a recall. I don't have warranty left. No problems on my part paying for maintenance related issues...but this type of defect shouldn't happen on a car of this calibre. See how and if they respond.
Cheers
320i - sold
325i - sold
X3 - sold
525i - sold
Jaguar X-Type - Sold
528i - current
Old 11-14-2012, 10:32 AM
Nube1kenobi's Avatar
Nube1kenobi Nube1kenobi is offline
U of Dawgs
Mein Auto: 2008 535iA Sport
Cheers
No! Because the existing high resistance to ground (earth) issue is not fixed.
Nube1Kenobi
2008 535i Monaco Blue/Dakota Black/Dark Poplar | Sports Package | Premium Package | Cold WX Package | Navigation, Voice | RTTI | PDC | L7 | HD | I-Pod/USB | PWR rear shade | Sports Auto - paddles | Active Steering | Comfort Access | Fold Down R/seats | Rear DMS Airbags | Adaptive Xenons | Now with recalled and replaced -446 HPFP
Do not argue with an idiot else he lowers you to his level and beat you down with experience..
Old 11-14-2012, 11:57 AM
Thanks...figures there is no cheaper option.
I got a reply from BMW Canada. No warranty...blah blah...won't do anything as I expected.
I guess they will wait for someone's brake lights to fail, cause a crash and then issue a recall.
320i - sold
325i - sold
X3 - sold
525i - sold
528i - current
Old 03-12-2013, 09:54 AM
kannit kannit is offline
Mein Auto: 520d 2009
Loose connection?
Hi,
Rear left tail light cluster on my 520d 2009 stops working altogether and then comes back on intermittently. This happens every 2-3 mins. When the cluster was totally blank, it just slapped lightly on it and it came back on for few mins before going blank again.
When the cluster goes blank, iDrive starts throwing error messages for rear left brake light, indicator, fog light and reverse light failure one by one.
Is this also a known problem?
Regards
Old 03-12-2013, 10:17 AM
Originally Posted by kannit View Post
Hi,
Regards
This does sound like a loose connection. Have you tried pulling the light harness, making sure the bulbs and connections are secure? As soon as a bulb connection is lost, it will trigger the idrive alert.
320i - sold
325i - sold
X3 - sold
525i - sold
528i - current
Old 03-12-2013, 12:03 PM
arizona-dave arizona-dave is offline
Its a "Dry" Heat
Mein Auto: 2009 528i
I repaired mine a month ago...the Brown wire on the harness that plugs into the light assembly had overheated and melted the pin inside the housing. The brown wire is ground.
I cut off the brown wire from the harness and soldered a connector to it. Then I removed the brake housing and soldered a wire onto the grounding block inside of it (its pretty easy, the inside of the housing has a stamped piece of metal that runs ground to all the different light bulbs), ran that wire out thru the back of the housing thru a 1/8 drilled hole (the housing is NOT air tight, so this makes no difference) and soldered a connector to it to mate with the brown wire.
Shrink wrapped the 2 together.
Problem fixed. :-)
Hi,
Regards
2008 528i Black on Black - Pretty well loaded only 44K miles - BiXenon Adaptive Headlights - What a nice car to Drive, first car to Rival my 1998 Lexus GS300!
Old 03-12-2013, 06:52 PM
U of Dawgs
Hi,
Regards
Same problem, different side... always the brown ground wire terminal.
Nube1Kenobi
Old 03-13-2013, 03:08 AM
You were right! The wire connector was loose. I pulled out the connector and with the help of a small screw driver I narrowed the holes of female wire connector assuming that pins of male connector will sit firmly into it...and it worked!! It is not going blank on road bumps or any other jerk while driving.
I also checked other connections and ground and nothing was burnt out fortunately. I think that would happen only when ground is bit loose and thus causing high resistance around the loose connection which will eventually heat up that area of loose connection.
Only problem I faced was opening the plastic cover over the tail light housing. It was damn difficult and at one point I thought it will break because I had to apply so much of force. That did not happen of course.
Thanks all for your help
Old 03-13-2013, 09:19 AM
Its a "Dry" Heat
LOL - Always the Brown Wire...true true!
And the pins can get loose and go bad quick too...mine was fine, never a flicker, and whatever happened was very quick, within 3 days an intermittent flicker went to full-out failure. ( -its a design issue & BMW knows about it)
I have a hunch that the brown wires needed to be a tad bigger gauge to handle the current of all the lights in the assembly, and probably a double ground would have been good to keep the actual pin from heating up...my brown wire was actually fried for about 1 inch outside the harness plug, and the female pin was the color of burned metal in a campfire, and the male pin inside the housing was completely gone - melted.
In any event, there are a number of relatively easy fixes for it for those who are not afraid to get their hands a little dirty...besides, we get to learn a little bit here and there about a pretty complex driving machine :-)
