E36 (1991 - 1999)
No heat after installing new thermostat
Hi
I installed a new thermostat in my 1997 328i today as I was only getting heat when the car was going at higher speeds and I thought my thermostat was stuck. So I installed the new one (and it isn't backwards) and now I have no heat at all. I opened the radiator screw and added coolant a few times and it is at a constant level now. the hoses going to the thermostat housing are fairly warm after driving but the hoses going into the dash at the back of the engine are not very warm. Any suggestions? please help! |
Does the engine get to operating temp?
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
yes it did. and it is not overheating or anything.
still has air in the system. Bleed it
![]() TRM |
This.
that happened to me when i changed my t-stat last month just keep bleeding and make sure the heat is on full blast and is switched to hot on ALL dials
Sent from my ALCATEL_one_touch_908S using Bimmer
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
Yep, you still have air trapped in there.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
when u installed thermo did you make shure hole was on top and did you make shure thermo stat cover lil hole was not plugged? bleed air
Here's a video on how to bleed your coolant system.
Note: he didn't raise the front at all. Sent from my SCH-I500 using Bimmer
1996 Z3 (M44) |
1996 Z3 (M44) |
| Tags |
| heater, thermostat |
