The X5 SAV Forum
Old 10-26-2011, 09:12 AM
jstplyin jstplyin is offline
Mein Auto: 2001 X5 & 1991 318is
I have tried a few times to likn my blackberry to my 2001 X5. I can't even get as far as to get my phone to ask for a pass code. Is it possible that even though all of the controls for bluetooth are there on my steering wheel that my model is not equiped with bluetooth?
Old 10-26-2011, 03:24 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Yes, this is possible. You can check by performing the procedure in the first reply. All you need is a screwdriver. Look for the Bluetooth module in the rear.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-11-2011, 12:01 PM
B0ssman B0ssman is offline
Mein Auto: BMW 535xi
I'm also having same problem. I found it! but no PK# its blank?[IMG][/IMG] I tried leaving pk blank no luck
Old 12-11-2011, 12:55 PM
petriej's Avatar
Oh that sucks. Try 0000? At least you found the module...
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-04-2012, 09:25 AM
2hot4u500 2hot4u500 is offline
Mein Auto: 2001 BMW 330ci
Originally Posted by King View Post
Look for a white sticker on the BT ULF module itself. (In the trunk, driver's side, underneath the black plastic floor/cargo panel.
I looked in the truck and drivers side, but what do you mean about black plastic floor/cargo panel. I am new to this and just received my first BMW so still figuring things out. Please help!
Old 01-24-2013, 09:17 PM
rayobot rayobot is offline
Mein Auto: 328xi
It's 0000 on my wife's '09 328. Just paired it with her iphone4. Now she's happy
Old 01-25-2013, 05:41 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
There are pics of this piece and it's location in the SECOND reply in this thread...go back to the beginning of the thread as not to miss what has already be suggested.
BTW...this is an e53 X5 forum...if this is not the type of BMW you own...all of the responses may not apply to your application.
Below is a BMW Bluetooth availability chart:
Q {BMW CCA Member #191509}
(SOLD)
Old 08-23-2013, 03:19 AM
miloc miloc is offline
Mein Auto: 2005 X3 3.0i 6-speed MT
Im having a similar problem: no sticker on the Bluetooth module. Did you finally pair your phone with the car? can I scan for the code myself with one of those scanners at autozone?
Old 08-23-2013, 06:15 AM
Fespo276 Fespo276 is offline
Mein Auto: BMW
How do I locate my Bluetooth Passkey?
I just typed in "1234" and it paired.
Old 08-23-2013, 11:58 AM
QSilver7's Avatar
Originally Posted by miloc View Post
...can I scan for the code myself with one of those scanners at autozone?
NO...an OBD II scanner is limited to the federal mandate for all car manufactures to have a standard for electronic engine emissions...and BT connectivity has nothing to do with emissions or air pollution.
(SOLD)
Old 08-30-2013, 06:13 PM
dmask0 dmask0 is offline
Mein Auto: 2004 E46, 2005 E53
The dealer can get the BT PK through their diagnostic software if the sticker is gone.
FWIW, I've been trying to pair our phones to our X5 (had the vehicle for 2 weeks now). The phone and vehicle would recognize each other but would not pair. It would say "Sorry, PIN or passkey is incorrect." I must have tried 50 different times over the first 3-4 days we had the vehicle with three different phones. Finally gave up. Dealer confirmed my PK (same as on the side of the BT unit) when it was in for an oil chance through a scan and said it might just need to be replaced (for $750). I randomly tried pairing again today and voila, it paired.
Old 08-29-2015, 01:43 PM
RichardDomenick RichardDomenick is offline
Mein Auto: BMW 525i
I found my Pass Key ie: PK: 1140 on the blue tooth device in the trunk. It used to work but doesn't anymore. I've had numerous engine and seatbelt codes erased. Could this have affected the Pass Key number. If so, how do I reset it to my phone A Samsung Note 4. I cannot get my phone to pair?????
Old 08-30-2015, 11:34 AM
QSilver7's Avatar
See BW1111's thread PLEASE HELP WITH BLUETOOTH which is o te 1st page right now with your request...they discuss how the reset their Bluetooth.
(SOLD)
Old 05-04-2016, 07:34 PM
Mumzie68 Mumzie68 is offline
Mein Auto: 2005 BMW x5
Pass key/pin
. Thanks I found and open the back where the bt module is,BUT the sticker is gone. How else can I find the pin without paying the dealership?
Old 05-05-2016, 10:23 AM
QSilver7's Avatar
Just curious because can't tell from your post...did you remove the module to check the areas not visible when it's mounted?
Also check the binder that contains the owners manual & other booklets if you haven't alresdy. The BT booklet also contains the PK code.
(SOLD)
Old 05-05-2016, 11:51 AM
No I didn't remove the module, afraid I'll pull or break something, assumed it would be placed on front. I bought the car used, so no Manual in the car. Previous owner doesn't know what happened to it.
Old 05-05-2016, 04:49 PM
QSilver7's Avatar
When you lift the cargo floor...the BT module is mounted at an angle on the left side. If you look at the plastic parts near the BT module that make up the under girding a that hold up the cargo floor...look down into the deep wells than secure the plastic piece that is right next to the BT module.
That plastic floor piece is easy to remove...and it will free up the BT module for easy removal, too. This will allow you to look at all sides of the BT module to find the sticker with the PK code on it.
(SOLD)
Similar Threads
No Bluetooth Passkey card with my new 330i!! Lederman E46 (1999 - 2006) 5 07-31-2005 11:46 PM
Can anyone verify if these Bluetooth Retrofit Kit Part numbers are available? m3evolution General BMW Questions 25 06-22-2005 09:21 PM
Installed Bluetooth phone ....finally!(long) 03BMW330 Car Navigation, Audio & Electronics by BAVSOUND 15 05-30-2003 11:26 AM
Audi Accelerates Bluetooth Adoption ChrisTO General BMW Questions 0 12-10-2002 06:46 PM
