Help me identify this part on my 87' 535i... - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 12-06-2011, 07:34 PM
mse678 mse678 is offline
Mein Auto: E30
My 87' 535i is missing this part on the rear bumper.
I did a search on realoem.com and it looks to be part number 51121868523, and it looks to be one big piece.
But from another website, it's called the "rear bumper impact strips", and it looks to be 3 pieces. http://data.bmrparts.com/bmwparts/BM...121868523.html
Can any e28 experts help me with this? Is it actually one big piece, or 3 separate pieces?
And where is a good place to find this?
Thanks!!!
ID:	303924   Click image for larger version
ID:	303925   Click image for larger version
Old 12-06-2011, 08:03 PM
damalex's Avatar
damalex damalex is offline
Mein Auto: 89 E30
http://www.pelicanparts.com/bmw/cata..._pg2.htm#item6
Hope this helps ya out car looks nice
Sent from my ADR6400L using Bimmer
Old 12-06-2011, 08:18 PM
catso's Avatar
catso catso is offline
catso
It's one piece. The clips usually rust away and then the rubber breaks apart. Maybe Andy (member: south26) has a good used one. Try sending him a Private Message.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 12-11-2011, 06:05 PM
Mein Auto: E30
so i was able to find the piece, i need to know how to remove the rear bumper, is there a DIY?
Old 12-11-2011, 06:31 PM
catso's Avatar
catso
The three "bumper shocks" that connect the bumper to the frame/body each have 2 bolts that connect each shock assembly. I think these bolt heads are either 13mm or 14mm. Unbolt all 6 of those and you can then remove the bumper assembly. After that, you can work on removing the rubber strip by unbolted the fasterners that hold the rubber strip to the bumper. They're likely very rusty and deteriorated. I've actually done it with the bumper on the car, but it's much easier to remove the bumper first. Look at the attached diagram for a better idea on how it's put together.
Name:	6 rear bumper.png
![/I][/FONT]
Old 01-04-2012, 12:15 PM
jimoreno jimoreno is offline
Mein Auto: 2006 X3
It looks like your bumper impact strip is ok but slid to the left. If you look at your picture what used to be the corner (the area with the radius) is now farther inside. Try pulling it to the right but you might be missing the last clip unless is still in the rubber strip itself.
Jimmy Moreno
1995 530i
1986 535i
Old 01-11-2012, 05:39 AM
thexpbogger thexpbogger is offline
Mein Auto: e28 1987 535i M Spec
That's strange indeed!!!!!!!!!!!!!!!!!!!!!!!!!! My 87 535i does not have these unless they are a EURO or US option...............
Old 01-11-2012, 08:50 AM
catso's Avatar
catso
The North American market had some differences because of Govt. mandated safety requirements.
![/I][/FONT]
Old 01-13-2012, 04:25 AM
That's cool dude........................ As I assumed with the US requirements.......................It'sfunny though, because even though I have had the car for almost 4 months now, After I posted on this thread , I actually went out and sussed the car and realized that my car has exactly the same rubber trim running the entire length of the bumpers, BUT are one piece.................I took some pics of the **** BOX I am driving and will try to put them up somehow!!!!!!!!!!!!!!!!
Anyway keep cruising DUDES!!!
Stephen
Old 01-16-2012, 05:39 AM
Mein Auto: 2006 X3
Stephen: You car has the regular bumpers that were used in Europe. They are good for 3MPH standards at the time but apparently the US raised it to 5 MPH and they required the use of shock absorbers in the bumper mounts. Yours bolt directly to the body so in case of a small "bump" the sheet metal suffers. A lot of hardcore fans in the US get the parts and swap them to the Euro bumpers as they look sooo much better!
Jimmy Moreno
1995 530i
1986 535i
Old 01-24-2012, 08:24 PM
Gee Wizz
Thanks Jim.................. I appreciate the comment and still quite amazed that I still have not seen any 87 535i model cruising the streets here............. SURELY THIS DOES NOT MEAN I AM DRIVING A RARITY............. (NO!!!!...... I am not calling you SHIRLEY)!!!!!! (sic)
Opening bids are at 25K.............. (joking)
Stephen
HTML code is Off
