Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 11-22-2011, 06:15 AM
Wop52 Wop52 is offline
Mein Auto: 98 M3 sedan
Clutch delay valve delete...
I have a 98 m3 sedan with a ltw flywheel and the cdv is getting a bit annoying. I want to remove it but don't wanna deal with bleeding the clutch. Is there any way around this or is it a must? Thanks in advance for any input.
Old 11-22-2011, 10:23 PM
SchwarzeEwigkt's Avatar
SchwarzeEwigkt SchwarzeEwigkt is offline
BMW = Fahrvergnügen
Mein Auto: 2002 325Ci
I don't normally come into the E36 forum, but I stopped by.
Bleed it if you open the line at all. It's not worth doing half-assed. You need your clutch to work. I had air in a clutch line in a Mercury I had a while back. It sucked.
'02 325Ci 5MT - Stahlblau
- Xenons, aFe CAI, Scorpion Muffler, Racing Dynamics Strut Bar, 330i ZHP Shift Handle, BMW Performance SSK, M3 Dead Pedal, Sparco Alloy Pedal Covers (Now with Busted Brake Pedal Cover!), CDV-ectomy
'02 Dodge Grand Caravan - Green
- MEAN. GREEN. MACHINE. You aren't a man 'till you hustle a crapcan minivan around some corners with gusto.
'05 Subaru Forester 2.5XS - Alpine White
- Wife's whip
Old 11-23-2011, 04:15 AM
rrsperry's Avatar
rrsperry rrsperry is offline
Mein Auto: ///M3 sc
Answer is no. You remove the valve, you have to bleed the line a little... Sorry. (and you really should rremove the valve....)
No matter where you go, there you are.
Old 11-23-2011, 10:18 AM
BMW = Fahrvergnügen
+1. There's a reason why my avatar picture is a crossed off CDV...
- Wife's whip
Old 11-25-2011, 07:51 PM
A white m3 A white m3 is offline
Mein Auto: 98 ///M3
and what reason is that? also how hard is it to bleed the clutch?? I think mine needs to be bled, every so often very lately, cold temps, ill go into reverse with the clutch pedal to the ground(took the stopper off) and it sounds like the gears will grind a bit... not a good sound, does this mean I need to bleed the clutch?? I assume so.
TRM
Old 11-25-2011, 09:36 PM
BMW = Fahrvergnügen
Because it's just better without a CDV.
- Wife's whip
Old 11-25-2011, 09:42 PM
Mein Auto: 98 ///M3
Wow... now I completely understand the reasoning behind removing it.
TRM
Old 11-25-2011, 10:24 PM
BMW = Fahrvergnügen
Fine. I'll spell it out for you.
1. Read this. Yes, it applies to you.
2. If you open any hydraulic line, clutch, brakes or otherwise, bleed it. It's a pain, but it's mandatory.
3. The issue you're having doesn't sound like a clutch issue. It sounds like you may want to change your transmission oil out. You could try bleeding your clutch if you want. If it helps, great. You'll be needing to do it anyway when you remove your CDV.
- Wife's whip
Old 11-29-2011, 10:04 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
It lets you slam the clutch a bit faster. I'd like to do it in mine, but I have a feeling the PO may have done it already.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 12-07-2011, 09:27 AM
I Love My E36's Avatar
I Love My E36 I Love My E36 is offline
Haters Gonna Hate
Mein Auto: Rear Ended E36 ///M3
If you do remove the CDV, make sure you dont Miss shift
Old 12-13-2011, 01:02 AM
Dmharvey Dmharvey is offline
Mein Auto: E36 M3 Coupe
Bleeding the clutch is a simple 5-minute job with a helper. Just keep the fluid topped off, have the helper pump the clutch pedal then hold it down, open the bleeder valve on the slave cylinder for a second, close the valve, and have the helper release the clutch pedal. You might have to repeat this more than once to get all of the air out. There are tons of detailed DIY write-ups available on this topic...
The first thing I did when I get my E36 M3 was remove the CDV, a simple 'mod' that helps to keep the clutch from slipping if you decide to get on it a little. Again, tons of detailed write-ups and info on all of this. If you miss a shift / money shift the CDV isn't going to save you, ditch it and you'll be glad you did.
