X3 F25 (2011 - current)
The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now! |
#26
My theory is that this language was left in the product literature, because it was probably true in regards to the iPhone 3G/3GS. |
#27
Not particularly scientific; but, as I have a 3GS & 4S phone and cradle, I will drive to a known poor signal area and try calling my 'Beemer Son'. By using each phone with and without the cradle should be at least interesting, if not quite a scientific test. |
#28
I had read somewhere that metallic body of cars reduce the signal charge inside the car, whereas the external antenna gets the charge back to the designated area. This does not need a physical connection for cell phones. One can only visualize the effect in real poor signal areas. Good luck. This is different from the radio signals where you need a physical connections as the strength of radio signals is comparatively low.
#29
I'm still on the fence about buying the snap-in adapter because I think it is way overpriced. (the adapter cost more that the iPhone 4) I am curious about the external antenna function though and I can't find anything on the web showing support for an external antenna but that doesn't mean it doesn't work. If someone has the adapter and is willing to test it for us, you can put the iPhone into field services mode to get the exact signal strength using the snap-in adapter and without. When in field services mode it with show the exact signal strength in DB. Here is a short article showing how to get it into Field services mode. http://gizmodo.com/5633290/test-your...mode-in-ios-41
#31
I have tried an iPhone 3GS & 4S, both in and out of their cradle,in a very poor signal area with positive results. Both phones sounded better from both ends when in the cradle. Not very scientific but that is the best I can do presently. I will try the signal strength test too one of these fine days. Hope this helps? |
#32
The Gizmodo article says to exit field test mode just click the Home button (bottom of post)...
#34
thanks meta, i guess my brain was fried after a long day of work and i just missed that line.
Anyways, I tested it. I put my phone in field test mode, and it read -70. Then, I put my phone in the cradle, and it still read -70. I then proceeded to make a phone call to see if that would change anything. Nope, after the phone call, it still read -70. (I'm pretty sure when I was actually calling the person, it switched over to the normal bars). Perhaps -70 is the best signal possible? Or maybe it works better in a spot with poor coverage? (This test used a Verizon iPhone 4S, and a 2012 X3 with dock and bmw apps) |
#35
smartphone antenna connections
Hi,
There is not a physical connection between the phone and the antenna--there is an inductive connection. The cradle contains an inductive pickup that couples your smart phone to the car's sharkfin. This is a direct route to the antenna designated "telephone 1 & 2 and does not relate to BMW assist cellular functions. The cradle holds the phone in a very specific position to align the smartphone antenna with the inductive pickup. The advantage with the shark fin is that it is outside the car...a cell phone inside a metal car is severely compromised--that's why there are cell towers seemingly every two feet. A lot of the confusion comes from no two cell phones being the same in layout or functionality. All this info is available on the BMW Tech Info web site, which requires a daily subscription for unlimited downloads. You can also find some info on the BMW coders site--look for the combox document. You can see this antenna setup in the diagrams. so, yes there's a connection, but it is not physical best Luna-01 |
#37
In short, as stated above there is no need for an actual physical 'jack like' connection between phone and 'mast' cable. |
#38
People bashed me when I originally did this 4 years ago but I dont have to run to the dealer for updates everytime my droid is updated either. Maybe not as elegantly interfaced with console, but always does what I ask and more. One of the reasons I bash BMW for their electronics. Always several years behind when it comes to audio and interface. Hope you get it fixed.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
#39
So my x3 just rolled off the line on December 2. I pick it up in South Carolina on 1/13. I didn't order the cradle b/c the dealer said that using the apple cable gets me the same results. After reading this post, I am not so sure.
My car will have BMW apps on it. What do I lose by not having the cradle? If you all say I need to get the cradle, can I install it myself?
2006 325i/Sparkling/Grey/Premium/Xenons/Heated/Comfort Access/Sat Prep (SOLD) 2013 X3 3.5/alpine/chestnut/sienna/premium/tech/bmw apps/heated seats/PDC delivery on 12/5
#41
try reading the posts above....
'12 Z4 2.8 - Melbourne Red '09 Accord Coupe LX-S - Red/black RTOM..... |
#42
The cradle will get you a different interface for the iPhone and it will allow video play back from an iPhone. Everything else will work without it.
#43
thank you. i think i will get one, then, because I hear that the iphone interface on the idrive is worth it. i just hope it's compatible with iphone 5!
#44
hamajicky, unfortunately the iphone 5 will most likely not fit in the cradle designed for the 4. there's always a chance, but the 5 will probably have a new form factor.
#45
so maybe I will wait a little bit and buy the new cradle after I get the iphone 5
#46
You will use it once and then revert back to the standard interface (which you would get with the regular cable) |
#47
I don't find the regular interface for browsing iTunes intuitive at all. It is more steps to browse through albums, and seems clunkier than the cradle interface.
#48
If I recall correctly- the cradle gives you access to external antenna "shark fin" for better reception, which you will not get w/o i.e., regular cable attachment. I have not tested this but if anyone has please let us know.
#49
See post #34.
#50
Thanks SamS. I guess I should have clarified. Has anyone tested it where reception is bad?
