BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#26
Here's Motor Trend's blurb on F30 'd possibilities:
1) "emissions-control cost"? What is that, $20/year for the urea solution? 2) If they do offer the 335d over here, it is sure to get much better fuel economy being lighter and using the 8 spd trans. Significantly better than the e90 6spd auto 335d |
#27
I think what they mean is that lighter diesel engine vehicles do not require the DPF and DEF solution for emissions, but the 320 apparently crosses that weight threshold, hence their line: "the car is heavy enough to require selective catalytic reduction after-treatment". And of course, all the added equipment is definitely an added expense versus those diesel vehicles that aren't required to have it.
#29
Do the smaller TDI cars not have a DPF? I thought they all have them and some just avoid the usage of DEF.
--Aaron |
#30
The closet competitor vehicle in this market (Passat tdi) also requires the urea solution. I can't see how their point about emissions systems equipment costs is a relevant point in considering the 320d for the US market. |
#31
Passat looks a lot bigger than a 3 series do why would it be the closest competitor over the Jetta(which uses no DEF)?
--Aaron |
#32
The F30 is bigger than the Passat in every dimension. The 320d would be a natural competitor for the Passat tdi (also a 2L turbodiesel)
#33
yeah- look at the dimensions. I'm looking forward to sitting in a F30, but the numbers don't lie.
I was mistaken- the Passat has 0.1" more rear head room |
#35
I don't think the Jetta or Golf use DEF.
#36
That is correct, but you wrote something about them not requiring a DPF. All diesels come with the diesel particulate filter.
#37
Length: The Passat is: 191.6 in F30 is 182 in OK certain numbers are similar but you can't take those numbers and extrapolate that the two cars are the same size inside and out. They have different drive trains and engine configurations. What's the total passenger volume of the F30, that # I haven't see. The total number for the Passat is 102.0 cu. ft. The 535i is 101.5 cu. ft. So unless the F30 is as big as an F10, your assertion that "The F30 is bigger than the Passat in every dimension." is incorrect.
New vs old Passat?
I suspect that you two (TJPark01 and d geek) are confusing the new and old Passat figures?
#39
front head room, front shoulder room, rear shoulder room Wheelbase is slightly longer in the F30 too. And the trunk is bigger than the Passat. I guess the front overhand is where most of the 9" extra Passat is? |
#40
No- haven't seen the F30 in person yet. Have you? Where?
#42
2012 VW Passat Trim and Specs I have not seen the F30 in person, but I had the chance to rummage through a Passat. As an owner of a F10 5 series, I can say that the new Passat is roomier that my 5 series, although total Cu Ft passenger space is nearly identical. With that being said, there is no way a F30 can be the same size or bigger than a 5 or a Passat.
One kid at my daughters school drives a new Passat. Several parents drive the new five series. I have looked many times at the trunk spaces of their cars and also noted how many kids pile out of them. I firmly without a doubt believe the new Passat is around the same size as the new 5 series. So I too find it hard to accept the new 3 seres is around the same size as the Passat which in turns means around the same size as the 5 series.
Btw I am extremely impressed with how roomy the new Passat appears to be. I watch five kids pile out of that thing and grab all their school gear out of the trunk of it.
--Aaron |
