In-car transmitter/garage door opener - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 10-09-2011, 08:36 PM
NPE NPE is offline
Mein Auto: 135
Unhappy In-car transmitter/garage door opener
No matter what I try--including following the instructions in the owner's manual--I can't get the in-car transmitter to work with my garage door opener. Has anyone else had this problem? If so, were you able to remedy it somehow? Please help.
Old 10-10-2011, 05:36 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
Is your garage door opener one with a rolling code? If so, you will need to press the program button the actual garage door opener.
Old 10-10-2011, 05:55 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: From BMWs to Porsches
It will likely be a 2-step process. First, press the reset on the garage opener (in your garage) in order to mate the frequency from the opener remote to your car transmitter. Next, once that's done, press the reset again and then quickly press the car transmitter button 3 times.
Currently: 2015 Porsche 911 GTS and 2016 Cayenne S eHybrid
Past BMWs: `05 645CiC; `07 650i; `08 M6 convertible; '08 135i; `11 750ix MSport; `15 M235i convertible
Others: '11 Panamera 4S; '13 Boxster S; '13 911 C4
"You think that's air you're breathing now?"
-Morpheus
Old 10-10-2011, 07:45 AM
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
I've always had issues programming mine. The systems will rolling codes are more difficult.
Have you tried this? http://www.homelink.com/home.php
There is a video on the website that walks you through everything. Trust me....you'll get there.
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 10-13-2011, 01:13 PM
BJKBerg BJKBerg is offline
Mein Auto: 2010 X5d, 2009 128 Conv.
Currently there are a couple of different rolling code standards on the market. I discovered this when I had to replace one opener that was struck during a lightning storm. I have two half horse power openers on single doors. Each use the rolling code but the newer one uses a different protocol. It was a struggle to get both to work. What I had to do was first train the car to know what type of transmitter your garage door opener will recognize. This is done by following the instructions in your owners manual and using the remote that came with your opener near the BMW mirror. Follow the steps to train new opener. Once that has been done the BMW will know what type of rolling code to transmit. Then you need to link the car to your garage door opener. This is done by following the instructions on the back of the opener. Usually it is done by pressing the training button on the garage door opener and then pressing your the button on your mirror three times. You should see the garage door opener flash three times which indicates it has learned the new remote.
Good Luck and I hope this helps.
BJKBerg
2010 X5d Vermillion Red, Sand Beige Nevada, Premium Pkg, Cold Weather, 3rd Row Seat, Tech Pkg, Trailer Hitch, Ipod
2009 128i Crimson Red, Boston Terra Leather, Premium Pkg, Nav, Heated Seats, Ipod
2008 X5 3.0si (Traded In)
2005 X5 3.0 (Traded In)
2003 325i (Sold)
Old 10-21-2011, 02:02 PM
audi4t audi4t is offline
Mein Auto: 135i vert
I have found when trying to program Home-link, on several BMW's, the location of the remote is critical.
First of all it must be very close to the mirror with the Home-link controls.
Also there is no one correct location to hold the remote while pressing the transmit button.
Sometimes I have placed the remote under and behind the mirror, other times over the top and behind the mirror. Other times simply in front of the mirror.
My advice is to try multiple locations adjacent to the mirror to get the receiver to recognize the signal.
Old 12-17-2011, 12:00 PM
ShakyDog's Avatar
ShakyDog ShakyDog is offline
Mein Auto: Z4 3.0i
I had to press the button on remote for 3 seconds, then release and hold for 3 seconds to get the Homelink to see, then press the learn button on the opener.
Steve
