Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 11-26-2011, 12:15 PM
queretaro queretaro is offline
Mein Auto: 2008 128i Coupe
wheel swap
will wheels for a 3 series fit a standard 128i?
Old 11-27-2011, 06:42 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
They should.
1999 528iA
2000 Z3 2.3
2003 M5
Old 11-27-2011, 11:26 AM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
From an E46 3-series, yes, an almost perfect fit. From an E9x 3-series, maybe, but the offset is generally 15mm or so too low, but may be OK with a 205/50-17 tyre.
Old 11-27-2011, 01:15 PM
The 16" wheels from the 3 series are 7" wide and have a 38mm offset. The snow tires fitted on the wheels are 205/55/16. Does this help determine if they will fit my 128i?
Old 11-27-2011, 04:59 PM
jsc's Avatar
jsc jsc is offline
They should be fine at the back, a 255/40-17 tyre on an 8.5" wheel with 52mm offset fits, putting the outside of the tyre at about 76mm from the hub, compared with 65mm for the wheel and tyre you are looking at, giving you 9mm more clearance, depending on the tyre.
For the front, a 225/45-17 tyre on a 7.5" wheel with 49mm offset fits (I am actually running 225/45-17 winter tyres on a 44mm offset rim without rubbing), putting the outside of the tyre at about 64mm from the hub, compared with 65mm for the wheel and tyre you are looking at, giving you 1mm less clearance, so it is likely it will work without rubbing, depending on the tyre.
Old 11-27-2011, 06:33 PM
Thank you jsc.
One more question please. Will the 16" wheel clear the breaks on a standard 128i, or is a 17" wheel necessary?
Best regards.
Old 11-29-2011, 12:30 PM
amancuso's Avatar
I use 16" wheels from a BMW Z3 on my 128i, the offsets are the same as most e46 wheels. They should work just fine.
1999 528iA
2000 Z3 2.3
2003 M5
Old 11-29-2011, 02:51 PM
thank you
Old 12-02-2011, 02:45 PM
maybebmw maybebmw is offline
Mein Auto: Audi A4
And my winter tires are 16" 205's, and they clear the brakes okay. You should be good provided your offset is okay.
Old 12-02-2011, 03:47 PM
thanks to all who replied.
Old 12-02-2011, 05:30 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Thank you jsc.
Best regards.
Clear the breaks? Have no idea what this means.
Old 12-02-2011, 06:10 PM
1naztyx5 1naztyx5 is offline
Account Under Review
Mein Auto: E70 X5/E60 528i
really? he just wants to know if the 16 inch wheel will rub against his brake caliper.
Old 12-03-2011, 02:22 PM
perhaps my incorrect use of the word breaks instead of brakes caused the question.
Old 12-04-2011, 07:02 PM
Guam135i Guam135i is offline
Mein Auto: 08 135i Coupe
Originally Posted by prorail View Post
clear the breaks? Have no idea what this means.
sa
Old 12-16-2011, 10:15 PM
I am debating to purchase some 18" wheels from a Z3 coupe. They are 18x8 with 35 offset and 18x9 with a 38 offset. 225/40 front and 255/40 rear. Does anybody have an idea if this would fit a 135i or 128i.
Happy Holidays!
Old 12-17-2011, 11:18 AM
jsc's Avatar
jsc jsc is offline
Happy Holidays!
The rears probably will rub on the fenders quite a bit, the fronts may rub.
Old 12-18-2011, 02:59 PM
Thanks the car has the stock suspension.
