Homelink and Lift Master.... - Bimmerfest - BMW Forums
Old 03-07-2008, 05:19 AM
conrad27 conrad27 is offline
Mein Auto: 04 645 Convert, 05 745Li
I can't program my Home Link garage door opener on the 7 to work with my garage! I have a Lift Master garage door opener. The car is a 2005 model and I built the house in 2003. I went step-by-step through the instructions in the book several times with no luck. I even replaced the battery in the Lift Master transmitter with no luck.
Anyone have any experience with this?
THE SEARCH FUNCTION IS YOUR FRIEND.
Sorry.
I found the video! This board has everything.
Old 03-07-2008, 05:51 AM
sp7 sp7 is offline
Mein Auto: 745 li
so where did you find the video and does it work now? i have the same issues
Old 03-07-2008, 10:33 AM
745ByMySide 745ByMySide is offline
Mein Auto: 745Li, X5 3.0, A6 2.7t
Isn't there a button behind the motor housing?? After programming, just hit that button and it should work fine.
budder
Old 03-07-2008, 11:12 AM
sunny_j's Avatar
sunny_j sunny_j is offline
bmw addiction
Mein Auto: X5d
i can program my two garage doors no problem but i cant program my gate
2012 X5d | White on Black | Fully Loaded | Sport Package
Black Trim Painted White
-2009 E320 Diesel | White on Black | H&R Springs | Kleemann KD-Box | 20" Monarch Hamburg Rims
Black Roof | E63 Rear Lip | Hood Emblem Delete | Foglight Chrome Trim Delete Gone
-2003 760LI Titanium Gray Metallic | Every option | H&R Springs upfront , via computer in rear
OEM Style 128 21" wheels | 40% tint | AIB Angel Eye's w/ matching foglights Gone
Old 03-07-2008, 11:28 AM
L2C L2C is offline
Mein Auto: 745 Li
Is your garage a rolling code?
Old 03-07-2008, 12:14 PM
harjothundal's Avatar
harjothundal harjothundal is offline
E65/E66 Helper Man.......
Send a message via AIM to harjothundal Send a message via MSN to harjothundal
Mein Auto: BMW 745 Li
most openers nowadays are rolling code, which you must pair the homelink with the actual device... if its not rolling you can usually just use the remote to grab the frequency, though its hit and miss most of the time...
Old 03-07-2008, 12:21 PM
L2C L2C is offline
Mein Auto: 745 Li
u have to reset the homelink by pushing the outer 2 buttons until the light starts to blink, then u push the smart button on your garage opener, then the push button on your homelink u want connected
Old 03-07-2008, 02:22 PM
robertb_in_dc robertb_in_dc is offline
Mein Auto: 2009 335d SG/Black
You first have to pair the BMW with your liftmaster control. Instructions in the BMW manual. Then you must go to the Liftmaster and press the "Learn" button on back of the motor housing. Then you must get back to your car within 30 seconds and press the homelink button you'd paired with. The door should begin to operate from the homelink signal.
Old 03-07-2008, 03:56 PM
+1
budder
Old 03-07-2008, 05:13 PM
diana diana is offline
Mein Auto: 2008 535
About 15 minutes ago I programmed the Homelink on my new 535. I had tried twice unsuccessfully earlier in the week. Two tips from Homelink seemed to have made a difference: 1) Put a fresh battery in the remote/transmitter and 2) Try holding the remote at various angles and distances (1-3 inches) from the button you are trying to program. The angle that finally worked for me was holding the remote between the windshield and the rearview mirror but close to the button I was trying to program. Good luck!
Good dogs don't love bad people.--Lewis Grizzard
Old 03-07-2008, 06:19 PM
bimmer1904's Avatar
bimmer1904 bimmer1904 is offline
Certified Enthusiast
Mein Auto: E65 E30
in yo face!...lol
http://www.homelink.com/training/train.taf
Old 04-07-2008, 11:24 AM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
So, if I have you correct:
A) Press/hold buttons 1 & 3.
B) Press button on transmitter/remote as well as desired homelink/visor button and hold.
C) Get out of car and press the learn button on the opener/motor.
D) Return to car and press same button on visor that you pressed in B.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 04-07-2008, 11:28 AM
bimmer1904's Avatar
Mein Auto: E65 E30
Originally Posted by bimmer1904 View Post
^^^they have a video too....
Old 04-08-2008, 05:10 AM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
This should do it.
2012 535xi|Dark Graphite|Black Interior|M-Sport|
Prior BMW's: 1987 325e|1993 740i|1998 740il|2002 745li|2007 750li|2006 750li
Old 11-14-2011, 11:28 AM
spider28 spider28 is offline
Mein Auto: 328
Thanks for the tip. The part where you have to get (rather experiment) the right angle for garage door opener and the homelink button in the car is important. Been trying several times but got no success until I read this post suggesting to use a location between the windshield and the rearview mirror. Worked for me right away.
Old 11-14-2011, 06:04 PM
mrringtone mrringtone is offline
Mein Auto: 2007 Alpina B7
If you have your remote to open the garage the home link system can pick up that signal. The directions are in the manual.
Old 11-14-2011, 11:03 PM
revrun revrun is offline
Mein Auto: 2004 745i
I finally programmed my home link and lift master tonight after two years. Just goes to show that a three year old thread is not only useful but can also inspire.
Old 11-16-2011, 05:04 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
What this guy said ^^^^
Old 12-18-2011, 06:29 PM
brichter brichter is offline
Mein Auto: 2002 M3
Holy Dead Thread Revival, Batman!
But, if you have the Smart Control Panel for the Liftmaster you don't need to break out the ladder, there's a button on the side of the panel (labeled "Prog") that does the same thing as the "Learn" button.
Old 12-24-2012, 09:59 AM
21citgo 21citgo is offline
Mein Auto: 2012 X5 3.5d
[QUOTE=brichter;6509300]Holy Dead Thread Revival, Batman!
You can say that again. Just programmed my wifes 2010 328i and my 2012 X5 3.5d using tips from this thread. Wish I had found bimmerfest two years ago.
Thanks everyone!
Jon
Old 12-24-2012, 04:43 PM
First_745Li's Avatar
Mein Auto: 2007 Audi A8
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Last edited by First_745Li; 12-24-2012 at 04:44 PM. Reason: deleted. didn't realize it was an old thread
Old 01-12-2014, 06:13 AM
twentyinrims twentyinrims is offline
Mein Auto: truck and sports car
Yep, this works!!!
After all these years with my 2006 Bimma I finally tried to program it and I can't believe I didn't try this before. Lazy Lazy Lazy
