Old 12-21-2011, 04:58 AM
Behmermaen Behmermaen is offline
Mein Auto: 2000 528i, 1985 635Csi
Airbag Warning Light?
I got a warning light this morning on my 00' e39 528i, it looks like a little stick man getting crushed by an airbag and its in the top right corner of the right cluster of warning lights. Does anyone know what it means and/or a fix for it?
Old 12-21-2011, 06:49 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
I have same car, never seen what you describe
when car is turned on to test idiot lights. PHOTO?
Old 12-22-2011, 11:44 AM
Sorry for the late response. Its after the idiot light test and it hasnt come back on since that one morning. Ill post a picture once im off work.
Old 12-22-2011, 12:41 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Hold on...let me see if I can find it in the owners manual. I'll be back.
EDIT: Is it the warning light at the bottom of the middle column?
Q {BMW CCA Member #191509}
(SOLD)
Old 12-22-2011, 04:05 PM
yep thats the one, i guess ill take it to my bmw mechanic and have him search the codes. Thanks for posting this
Old 12-22-2011, 04:08 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Yes, do. When that light is on, the SRS is inoperative, and the airbags won't deploy in an accident.
Old 12-23-2011, 11:15 AM
CoreyMNK's Avatar
CoreyMNK CoreyMNK is offline
Corey
Mein Auto: 2000 528i Step 215K Miles
In the manual it says that when this light it on the SRS system is not functioning properly and it may cause all of the airbags to go off during a crash.
In any case, OP have the codes checked out.
2000 BMW 528iA Step- 223K Miles- Aspen Silver
  • Dinan Engine Software
  • Smoked Sidemarkers
  • Smoked Turnsignals
  • Shadowline Trim (Plasti-Dip)
  • Fittipaldi Wheels
  • Muffler Delete
  • Beisan Vanos Seals
  • Umnitza MTech Rear Bumper
2004 Volvo V70R
2005 Nissan Armada SE OFF ROAD
Old 12-23-2011, 11:42 AM
QSilver7's Avatar
I wasn't going to comment...but then on 2nd thought...I thought I should interject the following comments into this discussion.
I do agree that the OP should definitely find someone that can scan the SRS system (if he doesn't have the equipment) to see what sensor or area of the supplemental restraint system registered the fault code(s).
But when the warning light appears (and see the actual page from the owners manual)...the air bag(s) may not deploy "within its normal response range". That doesn't mean that none of the bags will deploy...but rather refers to that the system may not respond as it was designed.
For instance, if the occupancy mat sensor for the front passenger seat has registered a fault...and the car was involved in a frontal collision...the front passenger air bags (dash/door/head) may all go off even if no one is sitting in the seat (ie bags not responding "within its normal response range"). If the occupancy sensor mat can't tell if someone is sitting in the seat or not...then it will deploy the bags as if someone where (this is "not operating within the normal response range").
(SOLD)
Old 12-23-2011, 11:45 AM
z168 z168 is offline
Mein Auto: 01 540i/6
This could just be the seat sensor right? I remember reading a thread about it...
Old 12-23-2011, 01:05 PM
Trebbia's Avatar
Trebbia Trebbia is offline
Mein Auto: BMW E39 I6
Did the op recently fix the doors or the seats?
Old 12-23-2011, 04:04 PM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
It's likely the passenger seat occupancy sensor if you're seeing the light primarily during and after you have weight in the passenger seat. Once the light is on, it will not clear until the next drive cycle when there is no weight in the passenger seat. The sensor is a grid of wires stuck to the cushion of the passenger seat. When occupied, it is expected to have 200 ohm of resistance. If the voltage drop is outside of the expected range, you get the light.
This sensor is easily damaged. I was fixing my sunroof and was applying a lot of force on my passenger seat. This likely broke one of the sensor wires.
I have not fixed mine since it is a $200 piece and a real bear to replace. See part #9 in diagram. Replacement involves pulling out the seat and removing most of the leather covers on the seat.
There is a workaround that involves soldering 2 x 100 ohm resistors and a diode to emulate the occupied seat. This means that the passenger airbag will always deploy in an accident. The airbag is costly to replace and may even be dangerous if you have younger kids in the passenger seat.
Also, don't quote me, but I seem to recall that even if the sensor is malfunctioning, the airbag will deploy since it knows that the seat is occupied. It's just an out of spec signal being received.
Old 12-23-2011, 04:31 PM
Fatass friends can also damage sensor wires i bet. Thanks everyone for the information
Old 01-09-2012, 01:56 AM
the_carouser the_carouser is offline
Mein Auto: e39 523i
I purchased an occupancy seat bypass unit from ebay for $20. I also purchased the Peake SRS code reader to diagnose and clear codes. The code reader came up with error codes for the occupancy seat, a disconnected rear passenger airbag and firing circuit belt tensioner in the passenger side. Oh dear! me thinks.
Airbag was disconnected when I repaired and modified my window regulators, so it was an easy fix- plugged it back in till it clicked in securely. The bypass unit threw no more error codes for the occupancy mat. But the belt tensioner was a worry. I tried several times to clear the codes after ensuring there were no loose wires under the seat. After plenty of research, I knew I had to take the seat out and find out whether it was the faulty wiring harness or the belt tensioner mechanism. On a last ditched effort to clear the codes before seat removal, I plugged the seatbelt buckle into the belt tensioner mechanism and cleared the codes on the reader. Scanned for codes and all is clear! Not sure why....?
This is the first time in 3 years that I didn't have that airbag warning light constantly in my face.
Now I don't have to worry about my fatass friends messing up my car.
Old 01-09-2012, 12:24 PM
Trebbia's Avatar
Mine went when I put my fatass knee on the seat while I was putting new interior bulbs in.
Moral of the story is to not put excessive force on the passenger seat cushion.
Old 01-09-2012, 12:50 PM
cn90 cn90 is online now
I placed a small piece of black electrical tape over the airbag light.....for now until I have time/energy to tackle it.
Old 01-10-2012, 11:38 AM
I don't know if these will help, and maybe we need to add to these links to really help, but, just in case it's useful ... here's what's currently in the bestlinks:
- What can cause an SRS airbag light (1) (2) (3) (4) (5) (6) & what tools reset the fault (1) (2) (3) (4) (5) & what happens when mechanics disconnect the airbag before the battery or they connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) & where to buy an airbag occupancy sensor bypass unit (1) (2).
Old 01-26-2012, 09:31 AM
MrTrouble MrTrouble is offline
Mein Auto: 1998 BMW 540I
I have the B800 Code reader and scanned the SRS system. My wife has misplaced my book, in which I wrote the codes, but they are to two drivers side issues. I checked them out and everthing seems fine.
Question though. The retractor on the driver's safety belt moves REALLY slow, as if the mechanism needs to be lubed or something. I seem to remember the word "accelerator" being included in one of the codes. Could that "sticky" seatbelt be the issue?
Thanks.
Old 02-19-2012, 04:47 AM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
so wait... basically since my airbag light is on i could say remove all my air bags ?
Since ya know they dont work anyway loosing 30lbs wouldn't hurt
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 02-23-2012, 10:19 AM
Spinout Spinout is offline
Mein Auto: '98 540i
Try this...
1. open you passenger side sun visor to the down position
2. on the back side of the pass. sun visor, now open the sliding mirror door so that the mirror is exposed and the vanity light is illuminated
3. slide the mirror door closed
4. return the sun visor to the up position
Did your airbag light warning go off after that excercise?
It works for me when mine comes on. The electrical portion of the ignition switch needs to be replaced. $100 part and a 30 min DIY task.
Old 02-23-2012, 11:06 AM
Originally Posted by Spinout View Post
Try this...
Are you serious or is that a joke?
Old 02-23-2012, 11:12 AM
Mein Auto: '98 540i
Serious as a heart attack. I thought the same thing until I tried it and it cleared my issues.
A lot of communications go through the ignition switch contacts. Search this board, there is a lot of documentation on this (bizarre) method.
Old 02-23-2012, 11:32 AM
Okay, I'll give it a shot. Is that with the key on or off, while in the driver's seat or in the passenger seat? Since it is rather bizarre, I guess I should have the process down to a "T"...
LOL...
Old 02-23-2012, 11:36 AM
Mein Auto: '98 540i
I do it with the car running and I'm sitting in the driver's seat. You could probably have a passenger do it as well although I've never tried it.
Good luck...
Old 02-23-2012, 11:48 AM
Good luck...
Thanks, I'll give it shot when I'm off this evening.
Old 02-23-2012, 11:54 AM
George16 George16 is offline
Mein Auto: 2003 530iA
I tried it on mine but unfortunately it didn't work. I followed the procedure to the "T".
