Old 12-21-2011, 10:35 AM
stoneman1027 stoneman1027 is offline
Stoneman1027
Mein Auto: 2001 BMW 530i
2001 530i question...
I got my 01 530i back in June and i still cant pass the emissions test. I had the oil separator valve replaced and i had to get a new valve cover gasket. The check engine light is off and the paper that i keep getting at the emissions place is saying the evap emission and secondary air arnt passing. My mechanic did a forced test on those 2 things and they passed but the car didnt accept that it was a "forced test", it needs to complete the drive cycle. that was over 3000 miles ago. he gave me a paper with the drive cycle on it but i cant do it all on public roads. Does anybody know how else to fix it?
Old 12-21-2011, 12:22 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
So let me get this right, you have driven the car 3000 miles after your mechanic tested it, you don't have a CEL but it doesn't pass the evap and secondary tests, right?
Am I missing something?
The secondary air blower and it's valve should come on when you start the engine from cold. Does that happen?
The evap circuit gets tested almost everytime you finish driving the car if it meets certain requirements. If it doesn't pass the CEL should come on, same for the secondary air system.
I guess you could probably drive the car at night when the lack of a current inspection sticker wouldn't be seen, to see if you can get it to pass.
Maybe find a different mechanic or bring it to BMW.
Old 12-21-2011, 12:37 PM
Fudman's Avatar
Fudman Fudman is offline
+1, something is not right. Is you car yielding any codes now? If not, then you should be good to go. If there are no codes, then you should pass inspection. Both of these issues would yield a code. So get your codes read and report back.
Old 12-21-2011, 04:18 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Have you had the car re-inspected?
Steve
OSRAM CBI
BMWCCA Member #337964
Old 12-21-2011, 08:58 PM
Stoneman1027
its not showing any codes and the check engine light is not on. when i first got it and it failed i took it to bmw and had it looked at and they said the oil separator valve was bad and the valve cover gasket needed to be replaced. i got them both fixed and took it back to the emissions testing place and it still failed. i called my mechanic and he said it has to go through the drive cycle and to drive it a few days and it should be fine. that was in august. ive been to the emission place around 7 or 8 times since then and it shows the same thing every time. my mechanic plugged up a computer to it that checks the system and it showed on his computer that my car hadent run the test on the secondary air and the evap emissions. he gave me a paper with a drive cycle and told me to do that but i cant do it all on the roads because it things like start the car cold and drive 25 for 1 min. then stop for 30 secs then go to 55 for so long then stop for 10 secs. there is a whole list of things on it. i cant do that on public roads.
Old 12-21-2011, 09:27 PM
First, you might want to call the TDEC mechanic at 1-866-329-9632 and ask them for advice. You might want to ask them for a waiver if you're having trouble getting your car registered because it failed emissions testing.
Second, what did the people at the testing station tell you is the reason that the car failed? Did they give you a printout?
Steve
OSRAM CBI
Old 12-21-2011, 09:41 PM
You don't need to follow the drive cycle as printed, just driving it for a few weeks will complete the testing.
Following the written instructions will make it pass quicker.
There is something wrong with your car that is not being addressed.
BMW or the mechanic should have know that the oil separator and the valve cover gasket has nothing to do with either the secondary air system or the evap emission.
Both of these circuits are not related.
Find someone who knows how these systems work.
Old 12-21-2011, 10:43 PM
Stoneman1027
i called the state mechanic and asked him what should i do and he said he doesnt work on them he just gives me advice. but all he said was if my mechanic gave me my car back without it able to pass then he didnt do his job. the printout said secondary air injection and evaporative emission system. bmw told me that the bad oil separator and the bad valve cover gasket was why it was failing but i took it to my mechanic told me that both of them dont have to do with why it was failing but he looked and they both did need to be replaced so he did. could my main computer be messed up and maybe not running the test?
Old 12-21-2011, 11:08 PM
Originally Posted by stoneman1027 View Post
I got my 01 530i back in June and i still cant pass the emissions test ... it needs to complete the drive cycle. that was over 3000 miles ago.
How long is the failed-inspection grace period in Tennessee anyway?
You're in Chattanooga for heaven's sake!
Even people in the middle of Los Angeles find a way to run the FTP drive cycle (see below):
Originally Posted by gonzilla View Post
- You must do it twice.
- It says don't go over 3000 rpm, but I don't go over 2700 rpm when I do it.
- You have to start each run from cold. In other words, you can't just turn the car off then back on and do it again. The car MUST be cold. The test requires an engine temp. between 12c and 60c which is 53f and 140f.
- if you mess up on part of it, you don't have to go back to the beginning. For instance, sometimes trying to find a place you can go 20-30 MPH is tough. I got about 2:50 in a few times until I finally was able to go the whole 3:15. The same went for the 40-60 MPH section. I attempted a few times before I was able to get through the whole 15 minutes.
- Having an OBDII code reader that can read individual readiness flags is a BIG help.
Lastly, if you're in Los Angeles, it can be difficult to find a place to do this. Here's my suggestion (along with a map):
For the 20-30 MPH section, I used Vista Del Mar (the beach road west of LAX) going north from Imperial to Culver (indicated in red). There isn't much traffic and people don't really care if you're only going 25. Stay to the right and you're golden. If you continue onto Culver (indicated in blue) you can hop on the 90 fwy east to do the 40-60 MPH section (indicated in green). Take the 90 to the 405 south. By the time I got to Western I was done with the 15 minutes of 40-60 MPH. Mind you, this was about 7:00am on a Saturday morning, but I did the same thing on a Thursday afternoon and was done with the 15 minute stretch by the Long Beach Airport. Hopefully this will help some of you Angelenos who are trying to set the codes!
Yep. Sort of.
I don't go to mechanics, so I don't know if they bother driving long enough to set all the registers for those states that fail you for incomplete drive cycles (of which California is one).
Time to bone up on both:
SAS:
- How to maintain (1) (2) (3) & replace (1) & troubleshoot the BMW E39 SAS SAP valve secondary air pump system (1) (2) (3) (4) & an SAP valve group buy (1)
EVAP:
- When will "CHECK FILLER CAP" EVAP fault codes go away on their own (1)
In the thread above, it took a few days of normal driving for me; but eventually the drive cycle (see QSilver7 chart below) was triggered:
- How to better understand the key EPA federal test procedure (FTP) concept of the BMW SES "drive cycle" (1)
Why not just run the same test I did in this thread?
- Experimental results removing the fuel filler cap (aka gas cap) on the BMW E39 with resulting OBDII DTC fault and drive cycle reset (1) (2)
That is, pull off your gas cap.
Then, just drive a few days.
You should eventually see a P0455 (large leak). If you see that, then you know your computer is working and that the drive cycle got to that point.
Or, even simpler.
Buy that $22 tester above from Amazon, and simply see if/when your data registers switch from "NOT READY" to "READY".
Old 12-21-2011, 11:15 PM
Jim is correct that the mechanics should have known that the problems they fixed had nothing to do with the problems that cause your car to fail the emissions test. You need a mechanic who knows that, but maybe the mechanic was fixing the VCG and CCV because they needed to be fixed.
Does the test report say that the SAP and EVAP systems were not ready? Can you type exactly what the report says or maybe scan a copy of the report?
Could you register the car? When you talked to the TDEC mechanic, did you discuss a waiver so you can register the car? I'm pretty sure that you spent more on repairs than the amount required to get a waiver.
Steve
OSRAM CBI
Old 12-21-2011, 11:41 PM
30 days. BTW only Memphis, the Chattnooga area, and the Nashville area have I/M programs, at least for now. No statewide testing in Tennessee,
Even people in the middle of Los Angeles find a way to run the FTP drive cycle...
Try driving North on US27. Drive 50 mph. By the time you get close to Dayton, you would probably have don ethe 15 minutes at 50 mph. So coast down to a stop and sit there a couple of minutes. You may have to do this twice because the EVAP system is only evaluated every other time the conditions are correct.
For the SAP, let the car sit overnight. Start it and let it idle for at least 2 minutes 13 seconds.
Steve
OSRAM CBI
Old 12-22-2011, 02:29 AM
Hi Steve,
I don't profess to understand how the SAS works ... so may I ask where does such a precise 133-second number come from?
EDIT: So as not to further hijack this thread ... I opened a separate thread on how the secondary air system works:
- Do we have a good description of how the BMW E39 Secondary Air System (SAS/SAP) works
Last edited by bluebee; 12-22-2011 at 03:32 AM. Reason: Opened a separate thread on how the SAS/SAP system works in the BMW E39.
Old 12-22-2011, 07:18 AM
Stoneman1027
i live in a neighborhood with a few stop signs ant when i get to the main road there is 3 red lights until i get to a road where i can do the 20-30 mph part. if i have to stop a few times my my engine might be warm by then. once i do the 20-30 part do i do the 40-60 as soon as that 3:15 is upon the first section? the road i will do the first test on leads to the interstate and i can probably stay between maybe 55 to close to 60 for 15 mins. i have one of the scanner things i got from auto zone for my other car but it was a obd2 so it will fit my bmw also. im going to try to upload a picture of the failed emissions paper. if it doesnt work ill type it word for word
Old 12-22-2011, 09:00 AM
Stoneman, you do not need to follow the drive cycle, if you have driven your car for a few weeks it will complete it if nothing is wrong.
Good to see you have a scan tool, here's what I would do.
1) Check to see if you have any other stored codes in the DME? Maybe something else is wrong with the car preventing it from completing the tests.
2) Can you hear the secondary air pump running when you start the car in the morning? If not either the fuse, relay, of pump motor is bad.
Once you answer the above we'll go on to checking the solenoid that supplies vacuum to the secondary air valve and then the evap emission circuit.
Old 12-22-2011, 09:01 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
No codes and no CEL.........does CEL come on in key position 2 BEFORE you start the car?
If CEL does indeed work, it sounds like an internal DME problem.
Disconnect the battery overnight, reconnect in the morning to reboot the DME.
Was car ever jump started?
Paul S
BMW CCA 69606
Old 12-22-2011, 09:19 AM
Stoneman1027
Yeah it comes on when i turn the key part way but once I start the car it goes off. If I disconnect the battery do I have to do anything special? I have a friend who tried that with his car and it wouldnt start back up and the dealer said it is a theft protection device that makes it do that. I got it in June and I haven't had to get it jumped. I dont know about the previous owner if he a to have it jumped or not.
Sent from my C771 using Bimmer
Old 12-22-2011, 09:27 AM
I've disconnected the battery on my car a few times and on friends E39's when doing repairs to them. All of the started up after re-connecting the battery.
Onen the trunk and wait 16 min for the trunk light to go out, then disconnect the negative lead.
You will need to reset your clock, the trip miles and MPG displays will reset back to 0.
Old 12-22-2011, 09:29 AM
Fudman's Avatar
Also check the integrity of your vacuum hose that leads to the SAP check valve. This short hose often cracks due to high heat exposure (it sits above the exhaust manifold). If this cracks, the valve will not actuate when the vacuum pump initiates, and will not allow the air pushed by the SAP to reach the exhaust system. However, any failure of the SAP system to properly function generates a code. If you are not getting a code, something strange is happening.
The simplest easiest thing to do is to open the hood and listen for the air pump activation on a cold start (it must be a COLD start).
1. If you hear the pump (located in front of the front passenger tire) activate, then the problem is with the check valve not activating. Check to see if there is a vacuum leak or if the vacuum pump is working.
2. If you don't hear the pump, then the pump may be dead. It could be a fuse or relay but it is more often caused by a failed check valve which allows exhaust to backflow into the pump, where moisture condenses and kills the pump. In this case, replacement of both pump and check valve are SOP.
Old 12-22-2011, 09:33 AM
Fudman's Avatar
If your pump activates but then does not run for the normal 1-2 minutes on a cold start, then there is your problem. This suggests a problem with the electrical circuit for the SAP. Sorry but electrical issues are not my forte.
Old 12-22-2011, 09:55 AM
Fudman, he said the CEL comes on when the key is turned but then goes off after the car is started.
He hasn't told us if the pump runs yet.
This is a pretty easy circuit to troubleshoot.
Old 12-22-2011, 10:48 AM
BMW CCA 69606
CEL turning on then off is a good sign. This reinforces the idea that there are no important codes stored. It's hard to believe you could have an Evap System leak or SAP problem for 3000 miles that wouldn't turn on the CEL. In addition to a DME problem, perhaps, as JimLev suggested, something that doesn't turn on CEL is preventing tests from being completed. For example, no vehicle speed signal to the DME, prevents DME from determining if vehicle has met the speed thresholds for tests. Of course I doubt vehicle speed is a requirement for Evap System leak or SAP tests. Disconnecting battery is a simple and cheap test. Personally I've never waited 16 minutes to disconnect battery.
What prompted you to get CVV and valve cover gasket changed when you first got the car? Was CEL on? What were the codes?
Yeah it comes on when i turn the key part way but once I start the car it goes off..........
Paul S
BMW CCA 69606
Old 12-22-2011, 12:56 PM
Stoneman1027
when i turn the car on i do hear the pump run for about a min. im going to try disconnecting my battery tonight and ill leave it over night.
Old 12-22-2011, 01:04 PM
Hi Steve,
From the diagram you posted, except I remember the number wrong. It should be 130 seconds.
Steve
OSRAM CBI
Old 12-22-2011, 01:08 PM
A failure of the SAP should set the CEL, right?
Steve
OSRAM CBI
Old 12-22-2011, 02:17 PM
Fudman's Avatar
Ha! Lol! I can't follow this string. Posts are going up too fast, Jim!
When I had my SAP issues, whenever the pump or valve did not activate, it always threw a CEL. I could occasionally get one or two trips out of it before the light would come on. But it would always come on.
That's a good sign. That suggests you SAP issue is related to the valve, which is a heck of a lot cheaper to replace than the pump. I suggest that you pry off the rubber vacuum tube connected to the check valve. If it crumbles when you remove it, it likely had a leak. See if you're getting vacuum on a cold start at the end of the hard plastic tube (which is connected to the valve via the short rubber vacuum tube). Replacement vacuum tube is over $10 for 36" at the stealer. You can use an alternate tube. Or PM me and I'll mail you a 6" piece.
