Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 12-11-2011, 04:00 PM
JŠnos's Avatar
JŠnos JŠnos is offline
Mein Auto: 335d, FIAT 500 Abarth
Originally Posted by Snipe656 View Post
Was it for the same reasons as the OP?
Exactly the same symptoms as noted by the OP but only the transmission was replaced, not the EGR valve or throttle body.
I don't know if he experienced this but the first thing I noticed was that the car would surge a bit after I'd stopped - usually after I'd come off the freeway or had been using sport mode. It was like that for a while since the mechanics couldn't duplicate it and it happened rather infrequently.
Then on two occasions it popped out of gear while traveling at the limit on the freeway. The mechanics couldn't replicate that either; after it happened two more times on the freeway (not a particulary fun experience!) they took the car right away and soon told me I'd be getting another transmission. I had to wait a week or so since it had to be shipped from Germany.
So far so good.
Old 12-11-2011, 04:16 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
Originally Posted by Flyingman View Post
Definitely makes the extended warranty look more attarctive.
This appears to be one of the first Tranny losses we've seen reported here.
If you've ever had a Auto-Tranny apart you can definitely understand what could possibly go wrong. It is a marvel of mechanical engineering.
Can't say our Tranny is any higher risk than any other automatic out there. Probably costs a lot more though.
Reminds me I need to get a quote on the extended warranty/maintenance soon!
425 Lb/ft. of torque has to put a bit of a strain on any tranny. Anyone know if the tranny in the 335d is any different from that in the 335i?
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 12-11-2011, 04:26 PM
JŠnos's Avatar
I believe it is different - someone here posted that it is also used in some of the 5 and/or 7 Series.
This thread probably has the details: 335d Transmission
Old 12-11-2011, 04:46 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Surprising to read about the trans fail.
Sorry to hear & glad you had coverage
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 12-11-2011, 05:56 PM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
My understanding is the tranny is very different than a regular 335i. I read (but don't remember where) the trans in the 335D was last used in the X5 4.8. Would make sense, as was probably the most HP/torque used in a regular automatic back when the 335D was being designed.
Old 12-12-2011, 06:16 AM
cssnms cssnms is offline
Mein Auto: '11 335d
It is completey different and built to handle the torque and then some. 335d's built up through 8/2009 had the ZF 6HP26Z which was then upgraded to the more stout ZF 6HP28 which has a higehr torque rating. The ZF 6HP26/6HP28 is also found on the E65 7-series, E63/64 6 series, E53 X5, E70 X5 4.8i, and whole slew of other cars by other manufactures including Maserati Quatroportte, Range Rover Sport etc
Here is the manual for the ZF 6HP26Z/6HP28.
http://www.zf.com/na/content/media/u...28_Catalog.pdf
Old 12-12-2011, 06:37 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
I am sure the transmission will handle the power of the car just fine.
I do think something to consider and no I did not go looking at any of those cars specs but something to consider is how the power comes on and where it hits. Back when I used to race Mustangs I used to always see people make the mistake of tossing a C4 transmission behind a turbocharged 302 ci motor. Their thought process was the C4 handled the HP and close to similar tq numbers with some bigger NA motors so should not be an issue. Those guys more times than not were always breaking their transmissions or having to freshen them up a ton more. They just did not take into account the differences in power generation and application. I only mention that because these 335d cars make a decent chunk of power but more importantly it comes on and peaks pretty quickly, must make for a rather strong transmission need.
--Admiral Aaron Rouse
Old 12-12-2011, 09:22 AM
lsupoppa lsupoppa is offline
Mein Auto: 2010 335d, 2004 745Li
As soon as I get the bill, I'll post the info. I was told to keep rocking the Mini Cooper S for another week while they wait for the transmission to be shipped from Germany. Apparently, none are available in the US?
Out of curiosity I'd like to know if they tell you how much the transmission would have been out of pocket to replace.
2010 335d
Old 12-12-2011, 09:25 AM
Any time my car has needed anything, it was not available in the US. Half wondering if in a couple weeks when I take it in for an oil change and rear blinker fix if they are going to tell me it needs a part shipped in from Germany. Kind of annoying when it is smaller things that I'd expect to be common. I could at least understand for not so common things like transmissions.
I usually take Rt. 85 down to River Road then cross the river at the American Legion bridge and avoid 270 during my commute to NoVa.
Originally Posted by 325xi_dc View Post
Thanks for the heads-up about the transmission. Me and the Big D moved to Frederick in August. Commuting downtown on the drag strip that is I-270, it seems I nearly get hit regardless of whether my car is in gear.
2010 335d
Old 12-12-2011, 09:26 AM
I never experienced the surge you describe. Odd.
So far so good.
2010 335d
Old 12-12-2011, 05:01 PM
JŠnos's Avatar
I wonder if my replacemed transmission was the upgraded one or if I got an exact replacement of the older model, since my car was built in 07/09. There are part numbers on the paperwork but they aren't those ZF 6HP26Z / 6HP28 numbers.
Old 12-13-2011, 06:11 AM
Mein Auto: '11 335d
I am sure BMW replaced your transmission with the same model that came in your car originally since the part is sourced by VIN#, not to mention there might be other physical differences between the two that would preclude them from installing the latest gen trans, although I would have certainly asked for the latest. Proprietary BMW part numbers are not the same as a model number for a particular transmission so it doesn't surprise me they don't match.
Old 12-16-2011, 12:51 PM
Legal Alien Legal Alien is offline
Mein Auto: 335D aka '3D'
While on the topic of trannys, but slightly different issue, was wondering if anyone gets a slight but distinct 'whine' from the tranny/tranny area around the low 70 MPH range? Notice it fairly consistently, when music is not too loud
Previous: 2001 Passat Wagon!
Old 12-16-2011, 03:18 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Hmm, the only "Whine" I hear at about 70mph is my wife telling me to slow down!
2016 Black 328D Sports Line/Premium, CPO (20k miles), Pirelli RFTs
2010 Black 335D Sport/Premium, Michelin PSS 235/265 (120k Club, now RET!)
2000 Silver Z3 3.0i (Ret)
1999 Silver R1200C (Ret)
1968 Black 1600 Coupe (Ret)
Old 12-16-2011, 03:28 PM
Mine a few times has not fully engaged in reverse. Only happens when the car has sat for a very long time and is just first started.
Old 12-18-2011, 03:20 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Joe,
So what is the status?
We missed you at the first S. Fla. reunion. All three (3) of us!
Old 12-18-2011, 07:13 PM
joeincs joeincs is offline
Sorry was supporting a software install for a hospital in NY. Worked round the clock for a couple of days and got home late Friday night. I will make the next one.
Joe
Old 12-19-2011, 04:24 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Originally Posted by joeincs View Post
They did not say anything about the JBD, said it was a sensor and then overnighted it. I do not think it was the JBD since it hase been in the car for months without any issue. Now a day later the SES is back on again. So this time I took it out and it goes back to the shop Monday.
So what did they conclude about this problem?
Old 12-19-2011, 09:02 AM
Took it back this morning first chance I had. Also Vista has a 1M on their showroom floor, $52K plus $20K MPA!!!
Old 12-21-2011, 04:47 AM
zach0726 zach0726 is offline
Mein Auto: 2010 335d, April build
My d developed a whine at 70mph (not the wife, this time ) Turned out to be a failed wheel bearing, drivers side rear. 26k miles on the d, at that time. Later on, the wine would come on around 50mph.
Old 12-21-2011, 10:04 AM
JŠnos's Avatar
A few times in the past month I have noticed a faint high-pitched whine just above 70mph. I wasn't sure if it was the engine or the transmission.
The conditions have to be just right in order to hear it, but with typical traffic conditions here that doesn't happen very often. I assumed it was nothing to worry about - I'll keep my fingers crossed.
Old 12-21-2011, 02:56 PM
DnA Diesel DnA Diesel is offline
Mein Auto: GLK250BT, 335d, Jetta TDI
I had this exact thing, replaced at 55,000km (left, rear bearing).
All-diesel fleet:
2016 GLE350d - Polar White, Dark Ash on Black
2014 GLK250 BlueTEC - Tenorite Grey, Dark Ash on Black
2009 335d Sport - Space Grey, Gloss Black, on Black (pics)
2006 Liberty CRD
2001 Jetta TDI
Old 12-22-2011, 08:30 AM
Axel61's Avatar
Axel61 Axel61 is offline
Mein Auto: 335d
I hope they dont catch the JBD that spells trouble and they try to blame it on the aftermarket JBD, cross your fingers on this!!!! Sorry to hear your issue, wish I could get a company to give extended warraties here in Puerto Rico, I do not know of any here, if your company does so REFER them to ME ok !!! I am willing to get one. Gracias!!! Hey if any of you SNOWBIRDS(LOL) decide to come to the Island let me know in advance so I can come meet you and you can see my RENNtech mod in my car ok!!!
Old 12-22-2011, 03:02 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
Wait, I thought BMW had a 5yr/60k powertrain warranty plus 4yr/50k B2B like Audi? Is this not true?
335d, throttle body, transmission
HTML code is Off
