E90/E91/E92/E93 (2006 - 2013)
Old 12-28-2011, 05:32 PM
Com1776 Com1776 is offline
Mein Auto: 2008 335i
2008 335i - 2,500 miles - maintenance?
I just bought my first BMW - 2008 335i, manual, with only 2500 miles believe it or not. I don't think it has ever been in the shop for maintenance, recall work etc. Really like the forum (oh yhea, the car too). A couple of questions:
1) What do I need to make sure the service department does when I take it in for the first time ... Fuel pump? Software updates? Other recalls? Suggestions given the miles / age?
2) Does BMW offer an extended warranty? Should I buy it?
3) Slight rattle, noticeable, from the center lower dash on some road surfaces (near radio). Live with it or fix it?
Old 12-28-2011, 05:56 PM
pointandgo's Avatar
pointandgo pointandgo is offline
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Your car is currently under recall (BMW NA) for the high pressure fuel pump and you should bring it in to have it replaced. No cost to you, and an extended warranty applies. You should certainly consider an extended warranty if you're going to keep the car. Do research on various plans, options. Unsure if your car still has any factory warranty remaining...if so, jump on any warranty issues NOW.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 12-28-2011, 06:05 PM
hpowders hpowders is offline
Bruins Beat Blackhawks!
Mein Auto: E90, Porsche 911, VW GTI
2008 335i. That's the sweet spot year. You probably have a HPFP recall on it. Call the BMW dealer and give him your vin# to verify.
There is no more beautiful car on Bimmerfest than my gorgeous Forest Green Porsche 911 coupe!
Obama is an incompetent liar!
Porsche: Accept no substitute, unless you're poor!
The E90 sedan is the last in the line of great 4 door 3 Series BMW's. Too bad.
"The VW GTI remains and will likely continue to be one of the finest compact sports cars in the world." Christian Seabaugh, Motortrend, March 27, 2012.
06/02/2005-03/02/2013: 7 3/4 Great years on Bimmerfest!!!
2008, 335i, maintenance
